I am trying to test and develop the DFU-OTA in nRF CONNECT SDK for nRF52832
I followed these link to develop i am using NCS v1.4.2
1. I have copied the peripheral_lbs code to my workspace
2. Based on the link i have added few things and here i attached the related files
main.c
* Copyright (c) 2018 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
// For FOTA
#include <tinycbor/cbor.h>
#include "cborattr/cborattr.h"
#include <mgmt/mgmt.h>
#include <mgmt/mcumgr/smp_bt.h>
#include <mgmt/mcumgr/buf.h>
#include <mgmt/mcumgr/smp.h>
#include "os_mgmt/os_mgmt.h"
#include "os_mgmt/os_mgmt_impl.h"
#include "os_mgmt/os_mgmt_config.h"
#include "img_mgmt/image.h"
#include "img_mgmt/img_mgmt.h"
#include "img_mgmt/img_mgmt_impl.h"
#include "img_mgmt/img_mgmt_config.h"
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define CON_STATUS_LED DK_LED2
#define RUN_LED_BLINK_INTERVAL 1000
#define USER_LED DK_LED3
#define USER_BUTTON DK_BTN1_MSK
static bool app_button_state;
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
printk("Connection failed (err %u)\n", err);
return;
printk("Connected\n");
dk_set_led_on(CON_STATUS_LED);
printk("Disconnected (reason %u)\n", reason);
dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
enum bt_security_err err)
if (!err) {
printk("Security changed: %s level %u\n", addr, level);
} else {
printk("Security failed: %s level %u err %d\n", addr, level,
err);
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
printk("Pairing cancelled: %s\n", addr);
static void pairing_confirm(struct bt_conn *conn)
bt_conn_auth_pairing_confirm(conn);
printk("Pairing confirmed: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
.passkey_display = auth_passkey_display,
.cancel = auth_cancel,
.pairing_confirm = pairing_confirm,
.pairing_complete = pairing_complete,
.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
.led_cb = app_led_cb,
.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
if (has_changed & USER_BUTTON) {
bt_lbs_send_button_state(button_state);
app_button_state = button_state ? true : false;
static int init_button(void)
int err;
err = dk_buttons_init(button_changed);
if (err) {
printk("Cannot init buttons (err: %d)\n", err);
return err;
void main(void)
int blink_status = 0;
int err;
printk("Starting Bluetooth Peripheral LBS example\n");
printk("Application build time: %s %s \n", __DATE__, __TIME__);
err = dk_leds_init();
if (err) {
printk("LEDs init failed (err %d)\n", err);
return;
err = init_button();
if (err) {
printk("Button init failed (err %d)\n", err);
return;
bt_conn_cb_register(&conn_callbacks);
if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
bt_conn_auth_cb_register(&conn_auth_callbacks);
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return;
printk("Bluetooth initialized\n");
if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
err = bt_lbs_init(&lbs_callbacs);
if (err) {
printk("Failed to init LBS (err:%d)\n", err);
return;
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
sd, ARRAY_SIZE(sd));
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return;
printk("Advertising successfully started\n");
// For FOTA
os_mgmt_register_group();
img_mgmt_register_group();
smp_bt_register();
for (;;) {
dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
prj.conf
# # Copyright (c) 2018 Nordic Semiconductor # # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic # CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="Nordic_Blinky" # Enable the LBS service CONFIG_BT_LBS=y CONFIG_BT_LBS_POLL_BUTTON=y CONFIG_DK_LIBRARY=y # Added for FOTA CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUMGR=y CONFIG_MCUMGR_CMD_OS_MGMT=y CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_MCUMGR_SMP_BT=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
also added full .zip file here
3. After successful compilation of the code uploaded to the Empty nRF52 DK (there is no bootloader separately added before )
4. Successfully showing the services in the nRF connect APP while entering into DFU
5. On the other-side i have just changed the device name to dfu_nrf_blinky
6. taken the build and app_update.bin is taken to mobile device
7. While initialize the DFU it asked for pairing and also paired with the device with valid key.
8. And on entering to start DFU it was disconnected like this and video is linked below with respective log
Log in the serial
*** Booting Zephyr OS build v2.4.0-ncs2 *** [00:00:00.528,289] [0m<inf> mcuboot: Starting bootloader[0m [00:00:00.534,576] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m [00:00:00.545,043] [0m<inf> mcuboot: Boot source: none[0m [00:00:00.550,781] [0m<inf> mcuboot: Swap type: none[0m [00:00:00.844,512] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m [00:00:00.852,508] [0m<inf> mcuboot: Jumping to the first image slot[0m *** Booting Zephyr OS build v2.4.0-ncs2 *** Starting Bluetooth Peripheral LBS example Application build time: Mar 15 2021 14:36:28 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ff0 I: data wra: 0, 0 I: SoftDevice Controller build revision: I: cf 5c 0f 11 88 9c d7 02 |.\...... I: 15 27 c7 c3 ca 60 19 85 |.'...`.. I: b7 c4 50 e3 |..P. I: No ID address. App must call settings_load() Bluetooth initialized Advertising successfully started Connected Passkey for 7e:2a:18:a3:a2:3c (random): 757200 Security changed: 7e:2a:18:a3:a2:3c (random) level 4 Pairing completed: 7c:78:7e:78:66:b3 (public), bonded: 1 Disconnected (reason 19) Connected Security changed: 7c:78:7e:78:66:b3 (public) level 4 Disconnected (reason 19) Connected Security changed: 7c:78:7e:78:66:b3 (public) level 4 Disconnected (reason 19) Connected Security changed: 7c:78:7e:78:66:b3 (public) level 4
Log from the nrf connect APP
nRF Connect, 2021-03-15
Nordic_Blinky (FB:B4:FA:11:EB:63)
V 14:54:14.912 Connecting to FB:B4:FA:11:EB:63...
D 14:54:14.912 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 14:54:15.042 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D 14:54:15.096 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I 14:54:15.097 Connected to FB:B4:FA:11:EB:63
D 14:54:15.099 wait(1600ms)
D 14:54:15.360 [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D 14:54:15.421 [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I 14:54:15.421 Device bonded
I 14:54:15.616 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I 14:54:16.023 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
V 14:54:16.700 Discovering services...
D 14:54:16.700 gatt.discoverServices()
D 14:54:16.713 [Callback] Services discovered with status: 0
I 14:54:16.714 Services discovered
V 14:54:16.737 Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic LED Button Service (00001523-1212-efde-1523-785feabcd123)
- Button [N R] (00001524-1212-efde-1523-785feabcd123)
- LED [W] (00001525-1212-efde-1523-785feabcd123)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D 14:54:16.738 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D 14:54:16.740 gatt.setCharacteristicNotification(00001524-1212-efde-1523-785feabcd123, true)
I 14:54:20.973 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V 14:54:22.707 [McuMgr] Connecting...
D 14:54:22.720 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D 14:54:22.751 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I 14:54:22.767 [McuMgr] Connected to FB:B4:FA:11:EB:63
D 14:54:22.786 [McuMgr] wait(1600)
V 14:54:24.400 [McuMgr] Discovering services...
D 14:54:24.418 [McuMgr] gatt.discoverServices()
I 14:54:24.472 [McuMgr] Services discovered
V 14:54:24.483 [McuMgr] Primary service found
I 14:54:24.500 [McuMgr] Service Changed characteristic found on a bonded device
D 14:54:24.513 [McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V 14:54:24.550 [McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D 14:54:24.561 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I 14:54:24.662 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I 14:54:24.672 [McuMgr] Service Changed notifications enabled
V 14:54:24.695 [McuMgr] Requesting new MTU...
D 14:54:24.705 [McuMgr] gatt.requestMtu(515)
I 14:54:24.797 [McuMgr] MTU changed to: 65
D 14:54:24.807 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V 14:54:24.831 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D 14:54:24.852 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I 14:54:24.979 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I 14:54:24.992 [McuMgr] Notifications enabled
V 14:54:25.034 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 14:54:25.047 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 14:54:25.066 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A 14:54:25.106 [McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Command Id: 0 (STATE)
Message: {}" sent
I 14:54:25.124 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I 14:54:25.161 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I 14:54:25.174 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 14:54:25.209 [McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V 14:54:25.227 [McuMgr] Uploading firmware...
I 14:54:46.130 Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A 14:54:46.130 "Button pressed" received
I 14:54:46.488 Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A 14:54:46.488 "Button released" received
I 14:54:47.030 Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A 14:54:47.030 "Button pressed" received
I 14:54:47.431 Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A 14:54:47.431 "Button released" received
V 14:54:55.459 [McuMgr] Connecting...
D 14:54:55.711 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D 14:54:55.828 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I 14:54:55.853 [McuMgr] Connected to FB:B4:FA:11:EB:63
D 14:54:55.887 [McuMgr] wait(1600)
I 14:54:55.906 [McuMgr] MTU changed to: 65
V 14:54:57.503 [McuMgr] Discovering services...
D 14:54:57.522 [McuMgr] gatt.discoverServices()
I 14:54:57.542 [McuMgr] Services discovered
V 14:54:57.558 [McuMgr] Primary service found
I 14:54:57.589 [McuMgr] Service Changed characteristic found on a bonded device
D 14:54:57.602 [McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V 14:54:57.643 [McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D 14:54:57.659 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I 14:54:57.739 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I 14:54:57.748 [McuMgr] Service Changed notifications enabled
V 14:54:57.779 [McuMgr] Requesting new MTU...
D 14:54:57.796 [McuMgr] gatt.requestMtu(515)
I 14:54:57.873 [McuMgr] MTU changed to: 65
D 14:54:57.884 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V 14:54:57.913 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D 14:54:57.923 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I 14:54:58.053 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I 14:54:58.063 [McuMgr] Notifications enabled
V 14:54:58.092 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 14:54:58.103 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 14:54:58.118 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A 14:54:58.132 [McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I 14:54:58.206 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I 14:54:58.252 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I 14:54:58.267 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 14:54:58.316 [McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V 14:54:58.335 [McuMgr] Uploading firmware...
V 14:55:15.765 Disconnecting...
D 14:55:15.765 gatt.disconnect()
D 14:55:15.809 [Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I 14:55:15.809 Disconnected
D 14:55:16.833 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
V 15:07:18.490 [McuMgr] Connecting...
D 15:07:18.500 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D 15:07:18.520 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I 15:07:18.534 [McuMgr] Connected to FB:B4:FA:11:EB:63
D 15:07:18.548 [McuMgr] wait(1600)
V 15:07:20.167 [McuMgr] Discovering services...
D 15:07:20.176 [McuMgr] gatt.discoverServices()
I 15:07:20.198 [McuMgr] Services discovered
V 15:07:20.229 [McuMgr] Primary service found
I 15:07:20.257 [McuMgr] Service Changed characteristic found on a bonded device
D 15:07:20.268 [McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V 15:07:20.290 [McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D 15:07:20.299 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I 15:07:20.379 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I 15:07:20.390 [McuMgr] Service Changed notifications enabled
V 15:07:20.417 [McuMgr] Requesting new MTU...
D 15:07:20.427 [McuMgr] gatt.requestMtu(515)
I 15:07:20.514 [McuMgr] MTU changed to: 65
D 15:07:20.525 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V 15:07:20.561 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D 15:07:20.577 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I 15:07:20.741 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I 15:07:20.760 [McuMgr] Notifications enabled
V 15:07:20.816 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 15:07:20.832 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I 15:07:20.853 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A 15:07:20.874 [McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I 15:07:20.923 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I 15:07:20.938 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I 15:07:20.978 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 15:07:21.028 [McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V 15:07:21.044 [McuMgr] Uploading firmware...
