Long time to disconnect
Our NRF52840 (running 14.2) often takes a very long time to disconnect, from when a disconnection is initiated by the phone. It can take 30s, sometimes even more, for the disconnect to happen. Sometimes the disconnect happens immediately like it should, but I would say that it is more common for the disconnect to take a long time than for the disconnect to be normal.
I installed the NRF Sniffer and have done a capture, but I am not really sure what to make of the result.
The below was a bad disconnect. Here, the highlighted line was about when the disconnect was initiated on the phone (image 1). Then I got "Empty PDU" for a long time. The empty PDU continues for a long time, with only one "encrypted packet decrypted incorrectly" in between, then in the second image, the highlighted line shows when the disconnect actually happens. There is ~13 sec in between the initiation and the actual disconnect.
By contrast, this was one of the times that I got a normal disconnection.
The above was done with our custom app. The issue also happens when using the NRF Connect App for iOS. For reference, below is the capture when the disconnect was initiated by the NRF app:
I pressed the disconnect button around the time of this highlighted line:
There is no command of any kind here though; the closest command is this one (but I don't know if they're even related, this is just the first command I found when scrolling up):
The disconnect comes what looks like 23 seconds later:
My questions:
(MAIN QUESTION) How can I find out why it is taking a long time to disconnect? Note that it happens with different phones, but we have only been able to test with iPhones so far.
AUXILLIARY QUESTIONS:
1. What are control opcodes and why do they only show up in the test using the NRF app, but not our custom app? Should we do something to enable these opcodes?
2. What is empty PDU?
3. What is "bad MIC"?
4. Where do I learn about how to interpret the captured packets? I read this but it doesn't really explain what I should be looking for.
Thanks!
  • nordev said:
    My sniffer is a Rigado BMD Development Kit with NRF52840 on it.
    Which sniffer firmware and software are you using?
    As far as I know the nRF Sniffer is only compatible with the nRF52840 PCA10056 and PCA10059.
    Are you able to successfully sniff any other pairing process? i.e if you flash your DK with an unmodified example from the SDK, and connect to it with your phone, are you able to sniff this connection just fine?
    nordev said:
    I am not sure how to make sure my peripheral is only advertising on 1Mbps or that my sniffer is compatible with 2Mbps. Do you have guidance on this?
    The nRF52840 is compatible with 2 Mbps PHY, so that is fine.
    Are you able to see the PHY used for the advertising of each packet in Wireshark? I.e when you see an advertising packet, are you able to tell with PHY it is being advertised on?
    The advertised PHY is what will be used when connecting.
    nordev said:
    I am sorry, what is LTK?
    Sorry, it is the long term encryption key. It is possible to provide this directly to the sniffer, if the sniffer is unable to sniff the bonding (such as when using LESC security). We should however first see if we can get the sniffer to work as expected, before moving to this approach.
    Karl
  • Hi Karl,
    This is the sniffer hex file I am using. I followed the sniffer setup steps months ago, so I don't remember exactly where I got it from. But the instructions I used were here. I am not sure that I got it from the SDK, but I am sure I got it straight from a Nordic source, and I definitely did not modify the sniffer prior to using it.
    I don't know what changed, but suddenly I seem able to sniff the connection as expected:
    The problem is if I let the phone screen go dark, it turns back to "bad mic"
    But I can just delete the bonds from the phone and let the sniffer sniff the pairing process. this should be good enough for testing, I think!
    Advertising PHY is LE 1M. What does that mean? Low Energy 1Mbps?
    Sample captures while disconnecting are below:
    When I press disconnect BEFORE the 30s is up, I get a lot of Empty PDU after I press disconnect on the phone.
    A) Then I eventually got this (#21714, time 209.819):
    B) Then I get this later (#21889, time 212.578)
    I tried again keeping better track of time this time:
     all this stuff happened ~504 (pairing)
    @ 512, got this:512.641 Master_0x5065659d Control Opcode: LL_CHANNEL_MAP_IND
     ~519 pressed disconnect. Got this (mostly empty PDU, all packets were Bad Mic from 515 onward, but they are very sparse -- maybe 3 total packets before the final disconnection)
    ~537 finally disconnected  Same kind of packet flow as B above, except instead of the actual opcode, I got "bad mic" this time for the last message (I assume it was the termination opcode though)
    If I wait MORE than 30s to disconnect, then I get this and it disconnects immediately.
    Any ideas what is happening? Is there other data you want me to collect?
  • Hello again Nordev,
    This seems to be our official sniffer firmware, yes. Thank you for clarifying.
    I am glad to hear it is working as expected now, at least.
    For future reference, it would be better if you uploaded the trace instead of screenshots, so I may take a look at it myself.
    Are you saying that the sniffer will start reading bad mic packages if you let the screen on your phone go dark? Is this consistently happening?
    It would be great if you could upload a sniffer trace of this, and indicate which packet number this behavior starts on, so I may take a closer look.
    This sounds very strange to me, and I have never heard of anything like it before, but if this turns out to be correlated I suppose there have to be some other power saving setting setting in at the same time as the screen goes dark. Again, this sounds very strange to me, and I'd love to see a trace of this so I may try to understand it better.
    Bad mic packets primarily happens when the sniffer is unable to decrypt the packet, so unless the devices update this (without the sniffer seeing it), I dont immediately see how this could happen.
    Correct.
    Great detail to your explanation! It is good that you relate everything to the packet number. However, here it would be great for me to have the sniffer trace myself, so I can see more than just the packets included in the screenshot.
    Could you please provide me the complete trace - use the "Insert -> File" option here on DevZone - so I may go through your detailed explanation here, but rather see it in the trace directly? This would make the debugging much easier.
    nordev said:
    time 209.819
    Please be advised that the 'time' column is USB time (i.e when wireshark reads it from the sniffer device), and it is thus not as accurate as the delta time column, for example.
    It is unfortunately not immediately clear from the description and screenshots alone. I find it very strange that the sniffer suddenly is unable to decrypt the packets, so it would be great to have a look at the packets leading up to this.
    Please provide the full trace file(s), so I may take a look for myself.
    I look forward to getting to the bottom of this weird behavior you describe in your comment! Slight smile
    Karl
