Hi the flash_fstorage example isn't working properly as expected.
I am running read str 0x3e000 12 via UART line but there is nothing which gets printed on the terminal.
Even if i write some hex value to a particular flash memory location and read that also the data is completely different
  • Hi I am not connecting via UART, I am just putting a breakpoint after write function and i am viewing the memory browser but still data isn't correct. This is the example from SDK v17 where you can see after ble_stack_init(), they are writing  0xDEADBEEF into memory location 0x3e100, I am putting a breakpoint just after that process is done which means even wait_for_flash() function is also executed but when i see the memory browser the data isn't correct
        ret_code_t rc;
    #ifndef SOFTDEVICE_PRESENT
        clock_init();
        timer_init();
        log_init();
        cli_init();
        NRF_LOG_INFO("fstorage example started.");
        nrf_fstorage_api_t * p_fs_api;
    #ifdef SOFTDEVICE_PRESENT
        NRF_LOG_INFO("SoftDevice is present.");
        NRF_LOG_INFO("Initializing nrf_fstorage_sd implementation...");
        /* Initialize an fstorage instance using the nrf_fstorage_sd backend.
         * nrf_fstorage_sd uses the SoftDevice to write to flash. This implementation can safely be
         * used whenever there is a SoftDevice, regardless of its status (enabled/disabled). */
        p_fs_api = &nrf_fstorage_sd;
    #else
        NRF_LOG_INFO("SoftDevice not present.");
        NRF_LOG_INFO("Initializing nrf_fstorage_nvmc implementation...");
        /* Initialize an fstorage instance using the nrf_fstorage_nvmc backend.
         * nrf_fstorage_nvmc uses the NVMC peripheral. This implementation can be used when the
         * SoftDevice is disabled or not present.
         * Using this implementation when the SoftDevice is enabled results in a hardfault. */
        p_fs_api = &nrf_fstorage_nvmc;
        rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
        APP_ERROR_CHECK(rc);
        print_flash_info(&fstorage);
        /* It is possible to set the start and end addresses of an fstorage instance at runtime.
         * They can be set multiple times, should it be needed. The helper function below can
         * be used to determine the last address on the last page of flash memory available to
         * store data. */
        (void) nrf5_flash_end_addr_get();
        /* Let's write to flash. */
        NRF_LOG_INFO("Writing \"%x\" to flash.", m_data);
        rc = nrf_fstorage_write(&fstorage, 0x3e000, &m_data, sizeof(m_data), NULL);
        wait_for_flash_ready(&fstorage);
        NRF_LOG_INFO("Done.");
        /* Enable the SoftDevice and the BLE stack. */
        NRF_LOG_INFO("Enabling the SoftDevice.");
        ble_stack_init();
        m_data = 0xDEADBEEF;
        rc = nrf_fstorage_write(&fstorage, 0x3e100, &m_data, sizeof(m_data), NULL);
        printf("%d",rc);
    The data type of m_data has to be a uint32_t. I tested this and verified that it works:
     * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @brief fstorage example main file.
     * This example showcases fstorage usage.
    #include <stdint.h>
    #include <stdbool.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_soc.h"
    #include "nordic_common.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "nrf_fstorage.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_fstorage_sd.h"
    #else
    #include "nrf_drv_clock.h"
    #include "nrf_fstorage_nvmc.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define BUTTON_DETECTION_DELAY  APP_TIMER_TICKS(50)
    #define APP_BLE_CONN_CFG_TAG    1
    /* Defined in cli.c */
    extern void cli_init(void);
    extern void cli_start(void);
    extern void cli_process(void);
    static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
    NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
        /* Set a handler for fstorage events. */
        .evt_handler = fstorage_evt_handler,
        /* These below are the boundaries of the flash space assigned to this instance of fstorage.
         * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
         * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
         * last page of flash available to write data. */
        .start_addr = 0x3e000,
        .end_addr   = 0x3ffff,
    #define TEST
    #ifdef TEST
    static uint32_t m_data          = 0x11;
    #else
    /* Dummy data to write to flash. */
    static uint32_t m_data          = 0xBADC0FFE;
    static char     m_hello_world[] = "hello world";
    /**@brief   Helper function to obtain the last address on the last page of the on-chip flash that
     *          can be used to write user data.
    static uint32_t nrf5_flash_end_addr_get()
        uint32_t const bootloader_addr = BOOTLOADER_ADDRESS;
        uint32_t const page_sz         = NRF_FICR->CODEPAGESIZE;
        uint32_t const code_sz         = NRF_FICR->CODESIZE;
        return (bootloader_addr != 0xFFFFFFFF ?
                bootloader_addr : (code_sz * page_sz));
    /**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
        ret_code_t rc;
        uint32_t   ram_start;
        /* Enable the SoftDevice. */
        rc = nrf_sdh_enable_request();
        rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
        rc = nrf_sdh_ble_enable(&ram_start);
    #else
    static void clock_init(void)
        /* Initialize the clock. */
        ret_code_t rc = nrf_drv_clock_init();
        // Wait for the clock to be ready.
        while (!nrf_clock_lf_is_running()) {;}
    /**@brief   Initialize the timer. */
    static void timer_init(void)
    /**@brief   Sleep until an event is received. */
    static void power_manage(void)
        (void) sd_app_evt_wait();
    #else
        __WFE();
        if (p_evt->result != NRF_SUCCESS)
            NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
            return;
        switch (p_evt->id)
            case NRF_FSTORAGE_EVT_WRITE_RESULT:
                NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
                             p_evt->len, p_evt->addr);
            } break;
            case NRF_FSTORAGE_EVT_ERASE_RESULT:
                NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
            } break;
    static void print_flash_info(nrf_fstorage_t * p_fstorage)
        NRF_LOG_INFO("========| flash info |========");
        NRF_LOG_INFO("erase unit: \t%d bytes",      p_fstorage->p_flash_info->erase_unit);
        NRF_LOG_INFO("program unit: \t%d bytes",    p_fstorage->p_flash_info->program_unit);
        NRF_LOG_INFO("==============================");
    void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
        /* While fstorage is busy, sleep and wait for an event. */
        while (nrf_fstorage_is_busy(p_fstorage))
            power_manage();
    static void log_init(void)
        ret_code_t rc = NRF_LOG_INIT(NULL);
        ret_code_t rc;
        clock_init();
        timer_init();
        log_init();
        cli_init();
    #else
         * store data. */
        ble_stack_init();
        NRF_LOG_INFO("Writing \"%s\" to flash.", m_hello_world);
        rc = nrf_fstorage_write(&fstorage, 0x3f000, m_hello_world, sizeof(m_hello_world), NULL);
        NRF_LOG_INFO("Use 'read' to read bytes from the flash.");
        NRF_LOG_INFO("Use 'write' to write bytes to the flash.");
        NRF_LOG_INFO("Use 'erase' to erase flash pages.");
        NRF_LOG_INFO("Use 'flasharea' to print and configure the flash read boundaries.");
        cli_start();
        /* Enter main loop. */
        for (;;)
            if (!NRF_LOG_PROCESS())
                power_manage();
            cli_process();
