NRF52840 DK log file
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
we bought NRF52840 to test other boards, firstly a problem happened, when change a new NRF52840 the testing could pass, so we doubt the firmware inside it was lost, how could we solve this problem?
  • Hi Amanda,
    Thank you for your kind prompt reply.
    Tried with your suggestion, problem still exist as below:
    C:\Users\Administrator>nrfjprog -v
    nrfjprog version: 10.12.1
    JLinkARM.dll version: 6.88a
    C:\Users\Administrator>nrfjprog --recover
    ERROR: nrfjprog could not identify the target device. This may be due to an
    ERROR: invalid family argument, a problem with your device, or nrfjprog may
    ERROR: not yet support your device.
    ERROR: Please check the family argument passed, or upgrade nrfjprog to a more
    ERROR: recent version.
    C:\Users\Administrator>nrfjprog --recover --log
    Thanks and Best Regards
    Pan Yinliang
  • Hi Pan,
    Are you using nRF52840 DK?
    Please make sure the power supply is 3.3v. You can check by the J-Link Commander to see the detected VTref.
    Please upload the file named log.log under C:\Users\Administrator. Thanks.
    -Amanda H.
  • Hi Amanda,
    Thank you for your kind reply.
    Yes, we are using nRF52840 DK, the power supply is around 5V as we connected the board to PC through USB cable.  The new error is as below after tying the command as you suggested, could you pls help check what happened?
    [2021-Mar-17 21:02:18] [ info] --------------------------------------------------------------------------------
    [2021-Mar-17 21:02:18] [ info] nrfjprog --recover --log
    [2021-Mar-17 21:02:18] [ info] nrfjprog version 10.12.1
    [2021-Mar-17 21:02:18] [debug] [ nRF0x0] - open_dll
    [2021-Mar-17 21:02:18] [ info] [ nRF0x0] - Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\JLINKARM_UNKNOWN_NRFJPROG.dll.
    [2021-Mar-17 21:02:18] [ info] [ nRF0x0] - Library loaded, loading member functions.
    [2021-Mar-17 21:02:18] [ info] [ nRF0x0] - Member functions succesfully loaded.
    [2021-Mar-17 21:02:18] [ info] [Backend] - Logger callback at 0xe22020 registered in Segger backend logger.
    [2021-Mar-17 21:02:18] [ info] [ JLink] - [Info ] [JLink ] Logger callback at 0xe22020 registered in JLink logger.
    [2021-Mar-17 21:02:18] [debug] [nRFUnknown] - Just_open_dll_tagged_callback
    [2021-Mar-17 21:02:18] [debug] [Backend] - open_dll
    [2021-Mar-17 21:02:18] [ info] [Backend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2021-Mar-17 21:02:18] [ info] [Backend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLinkARM.dll.
    [2021-Mar-17 21:02:18] [ info] [Backend] - Library loaded, loading member functions.
    [2021-Mar-17 21:02:18] [ info] [Backend] - Member functions succesfully loaded.
    [2021-Mar-17 21:02:18] [debug] [Backend] - dll_version
    [2021-Mar-17 21:02:18] [ info] [Backend] - Segger dll version 6.88.a loaded.
    [2021-Mar-17 21:02:18] [debug] [Backend] - set_core_data
    [2021-Mar-17 21:02:18] [debug] [ nRF0x0] - enum_emu_snr
    [2021-Mar-17 21:02:18] [debug] [nRFUnknown] - Just_enum_emu_snr
    [2021-Mar-17 21:02:18] [debug] [Backend] - enum_emu_snr
    [2021-Mar-17 21:02:18] [debug] [Backend] - ---just_enum_emu_snr
    [2021-Mar-17 21:02:18] [debug] [Backend] - ---just_get_num_emus
    [2021-Mar-17 21:02:18] [debug] [ nRF0x0] - connect_to_emu_with_snr
    Pan Yinliang
  • Hi Pan,
    Please modify the power to 3.3v.
    The log is not completed. Please upload the file named log.log under C:\Users\Administrator. Thanks.
    -Amanda H.
  • Hi Amamder,
    Could you pls tell us how to upload the log file? Since it's just a text file, kindly pls check it in attachment.0511.log.log
    Pan Yinliang
