iOS BLE not showing passcode popup
Hi Guys,
I need to connect to a BLE device using NRF52480 using passcode (6 digit pincode)
on Android it works just fine, I attempt to connect and displays the popup for entering the code.
on iOS nothing happens, I can only see the UART service and cannot connect.. I also tried to read, write, subscribe to the cccd but nothing happens.
I have tried to discover services but I cannot because I am not connected... (see logs below)
I have searched everywhere and in all related question in Nordic Q&A forum and couldn't find any solution for my issue.
I have also checked the glucose example you provided and it failed.
This is very urgent for my company and I need to get this working ASAP. Please help me
I am using iPhone 11 with iOS 14.4
Is there a specific configuration that you know of that I need to set in the peripheral in order for it to work? I have tried a lot of combinations with no success.
I get the following errors on the mobile side:
discoverServices, ERROR: PlatformException(flutter_reactive_ble.Central.(unknown context at $1079e3cf0).Failure:1, The operation couldn’t be completed. (flutter_reactive_ble.Central.(unknown context at $1079e3cf0).Failure error 1.), {}, null)
flutter: readCharacteristic, err: Exception: GenericFailure<CharacteristicValueUpdateError>(code: CharacteristicValueUpdateError.unknown, message: "A peripheral F4A9ECC7-D985-E28A-18F6-9C35F931679A is unknown (make sure it has been discovered)")
Asaf
  • In addition - when replacing all the services in Glucose example with one NUS service - it doesn't work anymore
  • Hi Edvin - issue is solved.
    The problem was that the case of BLE_GAP_EVT_PHY_UPDATE_REQUEST event was under #ifdef S140, so it was a disabled code.
    Can you please explain what is the propose of this code, and how did it work with Android?
    Another fix was setting SEC_PARAM_MITM and SEC_PARAM_LESC to 1, and SEC_PARAM_IO_CAPABILITIES to BLE_GAP_IO_CAPS_DISPLAY_ONLY. Again - I can't understand how did it work with Android.
    Finally - under nfc_ble_pair_lib.c file - I had to set m_sec_param.mitm to 1, under case NFC_PAIRING_MODE_LESC_JUST_WORKS and NFC_PAIRING_MODE_LESC_OOB, even though I don't think it's the right thing to do, but it's the only way to fix that.
    Can you please give me your inputs regarding the fixes? Can I do something else regarding the last one?
    Thanks!!
  • This is a bit outside the topic of the issue in this post. Probably, the reason that it behaved different was because one phone requested 2MBPS, and the other one didn't.
    Why are you using the NFC pairing file? Note that you didn't mention NFC until now. NFC is an OOB in itself, so it wouldn't typically prompt a passkey. I suggest you fetch your inspiration from the ble_app_gls example, which requires a passkey.
    Edvin
  • Ok,
    Can you please tell me about BLE_GAP_EVT_PHY_UPDATE_REQUEST? What does it do and what is the reason that Android didn't require that?
    Thanks for your help!
  • That is also outside this topic, but it is a request to change the PHY (physical layer) from the default 1MBPS and probably to 2MBPS. It gives a more efficient link with higher throughput. As long as the devices are fairly close, it also gives a lower power consumption, because it spends less time on the radio transmitting the same amount of data.
