MQTTS connection speed that does not require any certificate is very slow.
I verify the TLS connection without a certificate in the matt_samples routine. I found that the connection to the server is very slow, it takes more than 20 seconds, how can I solve this problem?
I use NBIOT and ncs1.5.0.
Here is my mqtt_init:
static int client_init(struct mqtt_client *client)
	int err;
	mqtt_client_init(client);
	err = broker_init();
	if (err) {
		LOG_ERR("Failed to initialize broker connection");
		return err;
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (uint8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
	static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
	LOG_INF("TLS enabled");
	client->transport.type = MQTT_TRANSPORT_SECURE;
	tls_cfg->peer_verify = TLS_PEER_VERIFY_NONE;
	tls_cfg->cipher_count = 0;
	tls_cfg->cipher_list = NULL;
	tls_cfg->sec_tag_count = 0;
	tls_cfg->sec_tag_list = NULL;
	tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
	tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
					    TLS_SESSION_CACHE_ENABLED :
					    TLS_SESSION_CACHE_DISABLED;
	return err;
prj.conf:
# Copyright (c) 2020 Nordic Semiconductor ASA
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_LEGACY_PCO_MODE=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# Modem library
CONFIG_NRF_MODEM_LIB=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_MQTT_CLEAN_SESSION=y
# Application
CONFIG_MQTT_PUB_TOPIC="my/publish/topic"
CONFIG_MQTT_SUB_TOPIC="my/subscribe/topic"
CONFIG_MQTT_CLIENT_ID="my/test/id"
CONFIG_MQTT_BROKER_HOSTNAME="47.106.164.80"
CONFIG_MQTT_BROKER_PORT=18883
# Button support
CONFIG_DK_LIBRARY=y
# Enable logging
CONFIG_LOG=y
CONFIG_MQTT_SIMPLE_LOG_LEVEL_DBG=y
# Memory
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=2048
Serial log:
Non-secure callable region 0 placed in flash region 0 with size 32.
[17:52:21.884]收←◆SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0xc000
SPM: NS MSP at 0x20019740
SPM: NS reset vector at 0x10021
SPM: prepare to jump to Non-Secure image.
[17:52:22.196]收←◆*** Booting Zephyr OS build v2.4.99-ncs1  ***
[17:52:23.200]收←◆[00:00:00.205,413] <inf> mqtt_simple: The MQTT simple sample started
[00:00:00.205,413] <inf> mqtt_simple: Provisioning certificates
[00:00:00.205,413] <inf> mqtt_simple: Disabling PSM and eDRX
[00:00:00.207,000] <inf> mqtt_simple: LTE Link Connecting...
[00:00:00.216,705] <inf> lte_lc: Using legacy LTE PCO mode...
[17:52:23.946]收←◆+CEREG:
[17:52:23.978]收←◆2,"1D2C","0D61D950",9,0,0,"11100000","11100000"
[17:52:24.560]收←◆+CSCON: 1
[17:52:26.341]收←◆+CEREG: 1,"1D2C","0D61D950",9,,,"11100000","11100000"
[17:52:26.516]收←◆+CSC
[17:52:26.544]收←◆ON: 0
[17:52:27.346]收←◆[00:00:04.35
[17:52:27.372]收←◆0,799] <inf> mqtt_simple: LTE Link Connected!
[00:00:04.351,196] <inf> mqtt_simple: IPv4 Address found 47.106.164.80
[00:00:04.351,226] <inf> mqtt_simple: TLS enabled
[17:52:29.634]收←◆+CSCON: 1
[17:52:29.955]收←◆+CSCON: 0
[17:52:32.176]收←◆+CSCON: 1
[17:52:34.195]收←◆+CSCON: 0
[17:52:37.291]收←◆+CSCON: 1
[17:52:39.053]收←◆+CSCON: 0
[17:52:42.416]收←◆+CSCON:
[17:52:42.436]收←◆ 1
[17:52:43.329]收←◆+CSCON: 0
[17:52:44.995]收←◆+CSCON: 1
[17:52:46.699]收←◆+CSCON: 0
[17:52:47.531]收←◆+CSCON: 1
[17:52:47.669]收←◆+CSCON: 0
[17:52:54.576]收←◆+CSCON: 1
[17:52:54.754]收←◆+CSCON: 0
[17:52:57.772]收←◆+CSCON: 1
[17:52:58.029]收←◆+CSCON: 0
[17:53:00.354]收←◆+CSCON: 1
[17:53:00.673]收←◆+CSCON: 0
[17:53:02.896]收←◆+CSCON:
[17:53:02.923]收←◆ 1
[17:53:03.164]收←◆+CSCON: 0
[17:53:03.191]收←◆
[17:53:04.045]收←◆[00:00:41.050,811] <inf> mqtt_simple: MQTT client connected
[00:00:41.050,842] <inf> mqtt_simple: Subscribing to: my/subscribe/topic len 18
[17:53:05.474]收←◆+CSCON:
[17:53:05.496]收←◆ 1
[17:53:06.164]收←◆+CSCON: 0
[17:53:06.642]收←◆[00:00:43.647,888] <inf> mqtt_simple: SUBACK packet id: 1234
I use MQTT BOX for connection test, the connection speed is very fast. The following are my configuration parameters.
  • Hi again,
    the modem trace you provide does not contain the necessary information about the connection attempt.
    "Modem trace is only 15 seconds long and contains 2 DNS queries sent by application. Not a sign for TLS connection establishment. Signal level seems to be in good level."
    It would be nice if you could take a new trace and get all the details from the connection attempt.
  • int mqtt_client_tls_connect(struct mqtt_client *client)
    	const struct sockaddr *broker = client->broker;
    	struct mqtt_sec_config *tls_config = &client->transport.tls.config;
    	int ret;
    	client->transport.tls.sock = zsock_socket(broker->sa_family,
    						  SOCK_STREAM, IPPROTO_TLS_1_2);
    	if (client->transport.tls.sock < 0) {
    		return -errno;
    	MQTT_TRC("Created socket %d", client->transport.tls.sock);
    #if defined(CONFIG_SOCKS)
    	if (client->transport.proxy.addrlen != 0) {
    		ret = setsockopt(client->transport.tls.sock,
    				 SOL_SOCKET, SO_SOCKS5,
    				 &client->transport.proxy.addr,
    				 client->transport.proxy.addrlen);
    		if (ret < 0) {
    			return -errno;
    	/* Set secure socket options. */
    	ret = zsock_setsockopt(client->transport.tls.sock, SOL_TLS, TLS_PEER_VERIFY,
    			       &tls_config->peer_verify,
    			       sizeof(tls_config->peer_verify));
    	if (ret < 0) {
    		goto error;
    	if (tls_config->cipher_list != NULL && tls_config->cipher_count > 0) {
    				       TLS_CIPHERSUITE_LIST, tls_config->cipher_list,
    				       sizeof(int) * tls_config->cipher_count);
    		if (ret < 0) {
    			goto error;
    	if (tls_config->sec_tag_list != NULL && tls_config->sec_tag_count > 0) {
    				       TLS_SEC_TAG_LIST, tls_config->sec_tag_list,
    				       sizeof(sec_tag_t) * tls_config->sec_tag_count);
    		if (ret < 0) {
    			goto error;
    	if (tls_config->hostname) {
    				       TLS_HOSTNAME, tls_config->hostname,
    				       strlen(tls_config->hostname));
    		if (ret < 0) {
    			goto error;
    	if (tls_config->session_cache == TLS_SESSION_CACHE_ENABLED) {
    				       TLS_SESSION_CACHE,
    				       &tls_config->session_cache,
    				       sizeof(tls_config->session_cache));
    		if (ret < 0) {
    			goto error;
    	size_t peer_addr_size = sizeof(struct sockaddr_in6);
    	if (broker->sa_family == AF_INET) {
    		peer_addr_size = sizeof(struct sockaddr_in);
    	ret = zsock_connect(client->transport.tls.sock, client->broker,
    			    peer_addr_size);
    	if (ret < 0) {
    		goto error;
    	MQTT_TRC("Connect completed");
    	return 0;
    error:
    	(void) zsock_close(client->transport.tls.sock);
    	return -errno;
    The problem lies in the zsock_connect() function on line 77.
    Finally, through breakpoint debugging, it is found that the nrf_modem_os_errno_set() function in the nrf_modem_os.c file will set errno = EOPNOTSUPP
    What is the reason for errno = -45?
     It is usually a certificate issue. The best to know for sure is to do a proper modem trace to get the details from the TLS handshake.
  • I think this is a SDK bug, not a modem firmware problem. I reacquired the modem trace.trace-2021-04-28T02-21-08.402Z.bin
    This is a demo.6661.mqtt_simple_test.rar
