I2C implementation between nrf52832 and cypress capsense button CY8CMBR2110-24LQ.
Hello!!
I want to implement I2C between nrf52832 and capsense button (CY8CMBR2110-24LQ) and want to put it to sleep mode so that I could get ~2-3uA  if there is no activity. Previously, I was using bsp_evt_handler() but wasn't able to achieve low power mode on nrf52832. The capsense is going to be pull up ( default ).
I would appreciate any soon response.
1. Capsense I2C lines are connected to  nrf52832 I2C lines.
2. 10 Capsense Buttons are pull up.
3. One Bi-color LED will be there.
4. Need to put in sleep mode for inactivity.
Thanks
  • Hi !!
    You need to ask the sensor producers what commands to use to read and write to the values that you are trying to acheive
    I got this and was able to use read and write function properly. I was getting ~1.2uA when I used only initializing twi_init(); nrf_drv_twi_tx(); & nrf_drv_twi_rx();
    After adding this to my original code in modified ble_app_beacon example, the current consumption increased to ~1.2mA. I also tried with disabling other functions such as ble stack, advertising and the current consumption gets lower to ~400uA. After debugging I found that nrf52832 chip isn't going to sleep mode.
    I am attaching my main.c below so that you could suggest why nrf52832 chip is not going to sleep mode.
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    /******** Ble_beacon_remote **********/
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "ble_advdata.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_clock.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "nrf.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "DeviceName"
    #define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(5000)              /**< Battery level measurement interval (ticks). */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(400, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
    #define APP_COMPANY_IDENTIFIER          0x0059
    #define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                               /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
    #define ADC_PRE_SCALING_COMPENSATION    6                                 /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
    #define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270                               /**< Typical forward voltage drop of the diode . */
    #define ADC_RES_10BIT                   1024                              /**< Maximum digital value for 10-bit ADC conversion. */
    volatile uint16_t remote_led_indication;
    //static uint8_t      packet_buf;          /****** TX buffer for buttons ******/
    static uint8_t      packet_buf[2];          /****** TX buffer for buttons ******/
    /**@brief Macro to convert the result of ADC conversion in millivolts.
     * @param[in]  ADC_VALUE   ADC result.
     * @retval     Result converted to millivolts.
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
            ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
    #define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define HIGH        1
    #define LOW         0
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    static nrf_saadc_value_t m_adc_buf;
    APP_TIMER_DEF(m_battery_timer_id);                                         /**< Battery timer. */
    static void battery_level_meas_timeout_handler(void * p_context);
    212
    213
    214
     *          the device. It also sets the permissions and appearance.
    215
       uint32_t err_code;
       ble_gap_conn_sec_mode_t     sec_mode;
       err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME,
       strlen(DEVICE_NAME));
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
    /**@brief Function for handling the ADC interrupt.
     * @details  This function will fetch the conversion result from the ADC, convert the value into
     *           percentage and send it to peer.
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
            nrf_saadc_value_t adc_result;
            uint16_t batt_lvl_in_milli_volts;
            uint8_t percentage_batt_lvl;
            uint32_t err_code;
            adc_result = p_event->data.done.p_buffer[0];
            batt_lvl_in_milli_volts =
            ADC_RESULT_IN_MILLI_VOLTS(adc_result) + DIODE_FWD_VOLT_DROP_MILLIVOLTS;
            NRF_LOG_INFO("Battery Level Measurement : %d [mV]", batt_lvl_in_milli_volts);
            if(batt_lvl_in_milli_volts != 0)
              remote_led_indication = batt_lvl_in_milli_volts;
        else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
            nrf_delay_ms(1);
            battery_level_meas_timeout_handler(NULL);
            NRF_LOG_INFO("SAADC calibration complete");
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code = nrf_drv_saadc_buffer_convert(&m_adc_buf, 1);
        err_code = nrf_drv_saadc_sample();
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
    static void advertising_data_update(void)
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        manuf_specific_data.data.p_data = (uint8_t *) &packet_buf;
        manuf_specific_data.data.size   = sizeof(packet_buf);
        advdata.p_manuf_specific_data = &manuf_specific_data;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_FULL_NAME;
        advdata.flags                 = flags;
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 400;       // Broadcast for 4 sec.
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
       ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        printf("led_indication = %d\n\r", remote_led_indication);
    /**** LED indication while advertising ****/
        if (remote_led_indication <= 1920)
            nrf_gpio_pin_write(LED_1, LOW);   // Green Led will Blink on less than 10% battery
            nrf_delay_ms(50);
            nrf_gpio_pin_write(LED_1, HIGH);
            nrf_delay_ms(50);
            NRF_LOG_INFO("More than 10 percent battery level");
        if (remote_led_indication > 1920)
            nrf_gpio_pin_write(LED_2, LOW);   // Red Led will Blink on more than 10% battery
            nrf_delay_ms(50);
            nrf_gpio_pin_write(LED_2, HIGH);
            nrf_delay_ms(50);
            NRF_LOG_INFO("Less than 10 percent battery level");
    static void advertising_stop()
        err_code = sd_ble_gap_adv_stop(m_adv_handle);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling bsp events.
    void bsp_evt_handler(bsp_event_t evt)
        switch (evt)
              case BSP_EVENT_KEY_0:
              packet_buf[0] = BSP_EVENT_KEY_0;
              packet_buf[1]++;
              case BSP_EVENT_KEY_1:
              packet_buf[0] = BSP_EVENT_KEY_1;
              packet_buf[1]++;
              case BSP_EVENT_KEY_2:
              packet_buf[0] = BSP_EVENT_KEY_2;
              packet_buf[1]++;
              case BSP_EVENT_KEY_3:
              packet_buf[0] = BSP_EVENT_KEY_3;
              packet_buf[1]++;
              case BSP_EVENT_KEY_4:
              packet_buf[0] = BSP_EVENT_KEY_4;
              packet_buf[1]++;
              case BSP_EVENT_KEY_5:
              packet_buf[0] = BSP_EVENT_KEY_5;
              packet_buf[1]++;
              case BSP_EVENT_KEY_6:
              packet_buf[0] = BSP_EVENT_KEY_6;
              packet_buf[1]++;
              case BSP_EVENT_KEY_7:
              packet_buf[0] = BSP_EVENT_KEY_7;
              packet_buf[1]++;
              case BSP_EVENT_KEY_8:
              packet_buf[0] = BSP_EVENT_KEY_8;
              packet_buf[1]++;
              case BSP_EVENT_KEY_9:
              packet_buf[0] = BSP_EVENT_KEY_9;
              packet_buf[1]++;
              case BSP_EVENT_KEY_10:
              packet_buf[0] = BSP_EVENT_KEY_10;
              packet_buf[1]++;
        (void)sd_ble_gap_adv_stop(m_adv_handle);
        advertising_data_update();
        advertising_start();
    /**@brief Function for initializing LEDs. */
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
        // Create timers.
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        // Start application timers.
        err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    /**@brief Function for configuring ADC to do battery level conversion.
    static void adc_configure(void)
        ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
        nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
        config.burst = NRF_SAADC_BURST_ENABLED;
        err_code = nrf_drv_saadc_channel_init(0, &config);
        err_code = nrf_drv_saadc_calibrate_offset();
            nrf_pwr_mgmt_run();
     * @brief Function for application main entry.
        // Initialize.
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        (void)sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
        leds_init();
        uint8_t err_code = NRF_SUCCESS;
        err_code = bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler);
        //err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_evt_handler);
        adc_configure();
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        application_timers_start();
        // Enter main loop.
        for (;; )
            idle_state_handle();
    I would appreciate soon response so that I could get low power mode.
    Thanks
     What sleep mode? System on or system off?
    If system off: Where do you put it in system off mode?
    if system on: are you sure? How do you determine this?
  •  What sleep mode? System on or system off?
    System OFF Sleep Mode
    sdk_config.h
    // <e> NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_ENABLED - Enable standby timeout.
    #ifndef NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_ENABLED
    #define NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_ENABLED 1
    // <o> NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_S - Standby timeout (in seconds).
    // <i> Shutdown procedure will begin no earlier than after this number of seconds.
    #ifndef NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_S
    #define NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_S 20
    I managed to solve that issue. I just changed the pull up into pull down configuration and it is going to deep sleep mode (cypress capsense)  and system OFF sleep mode in nrf52832.
    But our custom board has pull up capsense button so cypress chip will not go into deep sleep mode until I need to pull down it but if I do so it won't work as it needs active low signal to get interrupt from capsense buttons. So any suggestion how could I do that ?
    Secondly, if I put capsense IC into deep sleep mode and so I need to wakeup by giving low signal to attention pin but in deep sleep mode capsense won't work and nrf52832 will be stay in sytem OFF sleep until it gets interrupt. So any suggestion how to wakeup the nrf52832 sot that it could give active low signal to attention pin?
    thanks
     Not sure I understand the issue. But you can put whatever pull configuration on the pins. I am no HW expert, but do you mean that you have an external pull up resistor on your custom PCB?
