nRF9160 and SPI (CS control inhibited (no GPIO device)
I'm struggling with SPI and nRF9160. I've used an old sample (which didn't compile right of the bat):
github.com/.../spi
Seems the CS pin isn't passed on and I'm getting the "spi_nrfx_spim: CS control inhibited (no GPIO device)" error. It fails the check:
if (ctx->config->cs && ctx->config->cs->gpio_dev)
since
ctx->config->cs = 0
ctx->config->cs->gpio_dev = 536877096
If i "fake it" in spi_context.h and hardcode in the cs config:
const struct device *port;
port = device_get_binding(DT_LABEL(DT_NODELABEL(gpio0)));
gpio_pin_configure(port, 13, GPIO_OUTPUT_INACTIVE);
It throws the CS line low (since initial state of GPIO_OUTPUT_INACTIVE is low) and it stays low. If i set it GPIO_OUTPUT_INIT_HIGH, CS stays high. Which is not so strange, since the driver isn't able to hook into the cs pin.
What am I missing?
I read somewhere that SPI only works non-secure, but I see correct data with my Saleae Logic both when building secure and non-secure.
NCS v1.5.0.
West version: v0.10.1
Here is my main.c:
* Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
#define DT_DRV_COMPAT bosch_bmi160 //just for experimenting with DT macros
static const struct spi_config spi_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
		     SPI_MODE_CPOL | SPI_MODE_CPHA,
	.frequency = 1000000,
	.slave = 0,
	.cs = NULL,
struct device * spi_dev;
static void spi_init(void)
	const char* const spiName = "SPI_3";
	spi_dev = device_get_binding(spiName);
	if (spi_dev == NULL) {
		printk("Could not get %s device\n", spiName);
		return;
void spi_test_send(void)
	int err;
	static int8_t tx_buffer[1];
	static int8_t rx_buffer[1];
	const struct spi_buf tx_buf = {
		.buf = tx_buffer,
		.len = sizeof(tx_buffer)
	const struct spi_buf_set tx = {
		.buffers = &tx_buf,
		.count = 1
	struct spi_buf rx_buf = {
		.buf = rx_buffer,
		.len = sizeof(rx_buffer),
	const struct spi_buf_set rx = {
		.buffers = &rx_buf,
		.count = 1
	err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
	if (err) {
		printk("SPI error: %d\n", err);
	} else {
		/* Connect MISO to MOSI for loopback */
		printk("TX sent: %x\n", tx_buffer[0]);
		printk("RX recv: %x\n", rx_buffer[0]);
		tx_buffer[0]++;
void main(void)
	spi_init();
	while (1) {
        	spi_test_send();
		k_sleep(K_MSEC(1000));
nrf9160dk_nrf9160.overlay and nrf9160dk_nrf9160ns.overlay are identical:
&uart3{
	status = "disabled";
&spi3{
	status = "okay";
	sck-pin = <10>;
	mosi-pin = <11>;
	miso-pin = <12>;
	cs-gpios =	<&gpio0 13 GPIO_ACTIVE_LOW>,
			<&gpio0 7 GPIO_ACTIVE_LOW>,
			<&gpio0 8 GPIO_ACTIVE_LOW>,
			<&gpio0 9 GPIO_ACTIVE_LOW>;
	accelerometer: bmi160@0 {
		compatible = "bosch,bmi160";
		status = "okay";
		reg = <0>;
	        spi-max-frequency = <1000000>;
		label = "BMI160";
		int-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
	pressure: lps22hb-press@1 {
		compatible = "st,lps22hb-press";
		status = "okay";
		reg = <1>;
		label = "LPS22HB";
	flashchip: at25sf321bsshbb@2 {
		compatible = "jedec,spi-nor";
		label = "AT25SF321BSSHBB";
		status = "okay";
		reg = <2>;
		size = <0x10000000>;
		has-dpd;
		t-enter-dpd = <1000>;
		t-exit-dpd = <30000>;
		jedec-id = [1F 47 01];
        memorycard: sdhc@3 {
                compatible = "zephyr,mmc-spi-slot";
                reg = <3>;
                status = "okay";
                label = "SDHC0";
prj.conf:
CONFIG_GPIO=y
CONFIG_SERIAL=y
#Debug Specific
CONFIG_DEBUG=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_LOG_MAX_LEVEL=4
CONFIG_LOG_BACKEND_UART=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_SPI_3=y
CONFIG_NRFX_SPIM3=y
CONFIG_MAIN_STACK_SIZE=4096
