Ensure GPIO initializes to default low
Using: NRF52840, SDK 14.2, S140
My GPIO initialization code is as follows. This is the first thing that happens in main.c.
nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(1, 0));
nrf_gpio_pin_clear(NRF_GPIO_PIN_MAP(1, 0));
nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(1, 14));
nrf_gpio_pin_set(NRF_GPIO_PIN_MAP(1, 14));
Here are logic analyzer traces of 2 GPIOs (I can also scope them soon). Top one (P1.0) should be initialized low, bottom one (P1.14) should be initialized high.
PROBLEM 1: You can see in this picture that something spurious happens to both GPIOs upon powerup, where they both look like they're being initialized to the wrong value for ~4ms before being set to the proper values. This may be clearer in this zoom in view of the little blip at time B above:
This blip lasts about 4 ms. Below is an example measured from a different trial. Across multiple trials, it appears that P1.0 always goes high before it goes low. This is concerning, because there can be suboptimal system behavior if P1.0 is not initialized properly. Why might this be happening?
PROBLEM 2: there is also a consistent blip high AFTER the device is powered off (or generally upon poweroff, hard to tell exact sequence) -- see time point A in the first image. What might this be?
Thank you!
