BLE lost messages
Hi, as part of my project i have 2 nordic 52dks one as a pheripheral (sending) and on as a client (recieving). where i am sening a buffer of 8, in the order
buffer[0] = 10
buffer[1}= X gyro lsb
buffer[2] = X gyro msb
buffer[3] = y gyro lsb
buffer[4] = y gyro msb
buffer[5] = z gyro lsb
buffer[6] = z gyro msb
buffer[7] = 36   //terminator $
however sometimes i seem to lose a byte over ble such that the next byte received will be less and hence the order is correupted thus making processing rather and unpredictable for a large sample size like 1000000 samples.
how may i ensure that my ble settings are correct such that i ensure to limit this issue.
my code was based of the examples ble_app_uart and ble_app_uart_c for the peripheral and client respectivly.
thank u in advance
  • Hello again,
    NikTheNordicUser said:
    update: I managed to successfully install the sniffer and program another nrf52dk with the hex file and im seeing packets being transfered.
    I am happy to hear that you were able to resolve your issues setting up the sniffer, and that you now have it working! :)
    1. How can i know for sure which is my device as im seeing packets from multiple devices
    I suppose you have already figured this out, but you need to select your device in the device dropdown menu. You need to do this prior to establishing a connection to make the sniffer follow into the connection.
    2. Howcome the lengths of packets varry between 21-37 if i should be sending 242 bytes from the pheripheral ( confirmed by the uart of the client)
    howcome i dont always recive the same amount of data (should i not always recieve 242 bytes at once)
    Please send the trace, and illustrate this with specific packets in the trace.
    the speed is set at 1MBPS and i set it in both codes as 2 howcome i still get 1 MBPS.
    You can send an PHY update request if your connection is not using the PHY you would like See how the BLE_GAP_EVT_PHY_UPDATE_REQUEST (received request) is handled in the central's ble_evt_handler.
    Brief googling also yielded this very good third party tutorial on how to achieve maximum throughput for BLE 5. I highly recommend that you have a read through this, to better understand the meaning of the different parameters, and how to set them for maximum throughout. The tutorial also links to our throughput and long range demo, which could be very useful for you to have a look at at this point in your project.
    i hope that its visable but
    Sorry, I am not able to see anything in the video you have provided.
    Please share the trace file instead, and make comments with references to packet numbers etc.
    For example, "The behavior can be seen in the exchange starting on packet 112256, and lasts until packet 112300", or similar.
    Karl
  • wsh.pcapng
    ive attached the wireshark hope that it can be opened form your end... if we look at for example number 226 the packets are being fragmented, should i not be recvieng 242 bytes + any overheads creating by ble (which i think totals to 249 bytes) is this fragmentation normal ?
    also as can be seen in the PHY colomn it says 1M but i configured both sdks (central and pheripheral) as 2Mbps and you have told me to update request, should it not alwasy be 2Mpbs if i configured them as 2Mbps if not how do i update the request please?
    also one final thing please, how am i apple to calculate th exact speed cause i know ill never achieve the 2Mbps mark so i would like to include the actual speed im transfering at.
    Thank you and good day
  • also as i told you previously, i have set both peripheral and client to 50ms conn interval as can be seen below
    Pheripheral:
    client
    why is that if i change the event length seen below i do not get a connection between the devices can you explain please?
    Yes, I am able to open the wireshark capture, thank you.
    Fragmentation is normal, yes. Your total frame length is 249.
    See the initial packets in your trace. Your MTU is set to 247.
    You are correct that it adds 7 bytes overhead total - 3 byte ATT header, 4 byte L2CAP header.
    Please have a look at this ticket for a more detailed explanation.
    This is exactly why having the sniffer trace is a great tool. We can here see that there is never any PHY update request for 2 Mbps. So we know that this procedure is never initiated, and thus the PHY will not change from its original PHY, which in all SDK examples are 1 Mbps.
    Could you tell me exactly what you have done to change your PHY to 2 Mbps?
    As I understand it, you have only changed the SCAN_PHY define that you shared a screenshot of earlier - i.e which PHY the central will scan on, and not actually implemented the PHY update procedure that I asked you to earlier?
    If there is no PHY Update request, the PHY will be the same as the peripheral was advertising with. It appears from your provided trace that this is 1 Mbps.
    Please have a look at this other ticket, which discusses PHY's and how configuring them work.
    The link provided by Vidar is broken, but this is the message sequence chart he is referring to.
    This is successful, and we can see from packet #76 that your devices are communicating with 50 ms connection interval.
    What do you change it to? Is this on the peripheral or central side?
    What does the trace say when you have changed this? Are you able to see the peripheral advertise, but not connect? Or do you not see it advertise at all when you've made this change? Is there an error generated?
    The more specific information you provide, the easier it will be for us to resolve the issue.
    Please have a look at the examples referenced in this tutorial - especially the throughput example. Have a look at how they implement the throughput calculations to see how you may proceed with this yourself.
    Karl
