nRF9160 RSA signing data CC310
I am currently working on a project that involves RSA signing data before POSTing it to a PHP web server.
I believe this uses the CC310 cryptography hardware in the nRF9160, but even if the RSA signature takes time to complete it is not an issue.
I have dug around a lot today and have come up with what I think is a good start for this, at this link.
https://devzone.nordicsemi.com/f/nordic-q-a/69657/mbedtls-rsa-trouble-mbedtls_rsa_import-mbedtls_rsa_complete-fails/287781#287781
I am currently using nRF9160 SDK v1.5.0 and have been trying to compile a working sample.  I am uploading the file.
Ultimately the goal is to be able to sign arbitrary data to be POSTed to a PHP server with an RSA private key and using this as a starting point for that development, does this seem possible?
Then the nRF9160 will retrieve the result from the server and write the data to an SD card (the SD card functionality has no issues).
The error that I am encountering is
/opt/nordic/ncs/v1.5.0/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: modules/nrfxlib/nrf_security/src/mbedtls/libmbedtls_base_vanilla.a(entropy.c.obj): in function `mbedtls_entropy_init':
/opt/nordic/ncs/v1.5.0/mbedtls/library/entropy.c:115: undefined reference to `mbedtls_hardware_poll'
The zip project should be extracted here and use the following command to build it.
/opt/nordic/ncs/v1.5.0/nrf/samples/nrf9160/rsa_test
6470.rsa_test_20210328.zip
west build -b nrf9160dk_nrf9160ns -p
I am also copying the proj.conf here as I believe the issue is in this file, but I don't know what to change.
# Logging
CONFIG_LOG=y
CONFIG_LOG_IMMEDIATE=y
# Debugging
CONFIG_ASSERT=y
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_LOG_PRINTK=y
# Heap
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
# Entropy
CONFIG_ENTROPY_GENERATOR=y
#CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=32
#CONFIG_ENTROPY_NRF5_THR_THRESHOLD=16
# Crypto
CONFIG_NORDIC_SECURITY_BACKEND=y
CONFIG_CC3XX_BACKEND=n
CONFIG_OBERON_BACKEND=y
CONFIG_MBEDTLS_VANILLA_BACKEND=n
# build\modules\nrfxlib\nrf_security\include
CONFIG_MBEDTLS_CFG_FILE="../../../../config-mbedtls.h"
