OTA Thread DFU: Merge SDK example with custom application
Hi all!
I'm able to fully test the SDK example https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v3.2.0%2Fthread_example_dfu.html and it works pretty well.
Now, the next step is the integration of this OTA DFU over Thread example in my custom application (that already exploits Thread and MQTT-SN protocol).
I haven't found a tutorial that explains step-by-step this kind of operation.
Basically I need some help to integrate the DFU client with the user application. I think the key point is the IoT SDK CoAP library that implement a DFU algorithm that should run concurrently to the user application, but I'm a bit confused about merging process.
Thanks in advance,
Alessio
  • Are you using the same sdk_config.h configurations in your application as the Thread DFU client example? If you could post your full project, it would be easier to debug the application and help you find the root cause of the issue. If you do not want to share in public, I can convert the case to a private one.
  • Hi Jorgen,
    unfortunatly at the moment I can't share the project with third parties, I need to check the policy with my company.
    I compared the Thread DFU client sdk_config (that I copied-pasted in my project) with the one of my project. I found these main differences (other small differences are about LOG but I think they are useless)
    This is what I have in the Thread DFU client sdk_config:
    // <e> MEM_MANAGER_ENABLED - mem_manager - Dynamic memory allocator
    #ifndef MEM_MANAGER_ENABLED
    #define MEM_MANAGER_ENABLED 1
    // <o> MEMORY_MANAGER_SMALL_BLOCK_COUNT - Size of each memory blocks identified as 'small' block.  <0-255>
    #ifndef MEMORY_MANAGER_SMALL_BLOCK_COUNT
    #define MEMORY_MANAGER_SMALL_BLOCK_COUNT 8
    // <o> MEMORY_MANAGER_SMALL_BLOCK_SIZE -  Size of each memory blocks identified as 'small' block.
    // <i>  Size of each memory blocks identified as 'small' block. Memory block are recommended to be word-sized.
    #ifndef MEMORY_MANAGER_SMALL_BLOCK_SIZE
    #define MEMORY_MANAGER_SMALL_BLOCK_SIZE 128
    // <o> MEMORY_MANAGER_MEDIUM_BLOCK_COUNT - Size of each memory blocks identified as 'medium' block.  <0-255>
    #ifndef MEMORY_MANAGER_MEDIUM_BLOCK_COUNT
    #define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT 4
    // <o> MEMORY_MANAGER_MEDIUM_BLOCK_SIZE -  Size of each memory blocks identified as 'medium' block.
    // <i>  Size of each memory blocks identified as 'medium' block. Memory block are recommended to be word-sized.
    #ifndef MEMORY_MANAGER_MEDIUM_BLOCK_SIZE
    #define MEMORY_MANAGER_MEDIUM_BLOCK_SIZE 256
    // <o> MEMORY_MANAGER_LARGE_BLOCK_COUNT - Size of each memory blocks identified as 'large' block.  <0-255>
    #ifndef MEMORY_MANAGER_LARGE_BLOCK_COUNT
    #define MEMORY_MANAGER_LARGE_BLOCK_COUNT 2
    // <o> MEMORY_MANAGER_LARGE_BLOCK_SIZE -  Size of each memory blocks identified as 'large' block.
    // <i>  Size of each memory blocks identified as 'large' block. Memory block are recommended to be word-sized.
    #ifndef MEMORY_MANAGER_LARGE_BLOCK_SIZE
    #define MEMORY_MANAGER_LARGE_BLOCK_SIZE 1024
    This is what I have in my application:
    #define MEMORY_MANAGER_SMALL_BLOCK_COUNT 64
    #define MEMORY_MANAGER_SMALL_BLOCK_SIZE 64
    #define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT 16
    #define MEMORY_MANAGER_LARGE_BLOCK_COUNT 4
    #define MEMORY_MANAGER_LARGE_BLOCK_SIZE 512
    Do you think this could have an impact?
    Another question, I thought that the DFU process (at least the single bank approach) was carried out by bootloader (so the application is stopped). So what's the meaning of this macro?
    // <q> NRF_DFU_IN_APP  - Specifies that this code is in the app, not the bootloader, so some settings are off-limits.
    // <i> Enable this to disable writing to areas of the settings that are protected
    // <i> by the bootlader. If this is not enabled in the app, certain settings write
    // <i> operations will cause HardFaults or will be ignored. Enabling this option
    // <i> also causes postvalidation to be disabled since this is meant to be done
    // <i> in the bootloader. NRF_BL_DFU_ALLOW_UPDATE_FROM_APP must be enabled in the bootloader.
    #ifndef NRF_DFU_IN_APP
    #define NRF_DFU_IN_APP 1
    And why it is called "background" DFU if the application is stopped anyway?
    If the application is carrying out the DFU process is pretty easy to understand that I can't use the single bank approach (since che app can't erase itself if it is running). I need some clarifications about this.
    Thanks in advance,
    Alessio
    Ok, it would help a lot if your could be allowed to share the project. Everything is treated confidentially by Nordic, and other users will not have access to the content of this ticket if I convert it to private.
    It could be related, check out the suggestions in this post.
    The DFU libraries contains code for both Bootloader and application parts of the process. This config is used to determine if the build is an application or the bootloader.
    Thread secure DFU only supports dual-bank DFU. In order to support single-bank DFU, the transport layer (Thread protocol in this case) must be supported in the bootloader, if not you risk "bricking" the device if the DFU process fails. The OpenThread libraries are too large to fit in the bootloader, and are not a separate module (like for instace our BLE softdevice, which is stored in a separate location in flash, fully detached from the application. So for Thread DFU, the application is not stopped until the entire new application is received. When the application is received, the application will reset and bootloader will handle swapping of application images.
    Yes, the application is responsible for receiving the DFU image. Bootloader is responsible for swapping images.
    Jørgen
  • Hi Jorgen,
    So are you saying that I can't perform a single bank DFU with Thread protocol?
    How can I manage the issue that in the flash I can't storage the current FW and the DFU image (lack of memory space)?
    I can attach some debug log about my error
    Alessio
    EDIT:
    I tried with a DFU image that fits my memory space with the NRF_DFU_FORCE_DUAL_BANK_APP_UPDATES macro set and I have the crash problem anyway. So probably I'm facing at the moment a different problem than the lack of memory space.
  • UPDATE
    I want to summarize the main issues I'm facing at the moment so people can help with a clear vision of my scenario
    • More theoretical issue: can I implement single-bank approach exploiting Thread DFU example? I don't have enough space in my flash to store both old FW and new DFU image so dual-bank approach is unfeasible. Any workaround to this?
    • Let's pretend that I can implement a dual bank approach (I'm using a dummy DFU image so it can fit in my flash and I can isolate the issue explained above). I had some tries with two version of my application: an older one that exploits BLE and Thread protocol in a "switched mode" and a more recent version where I implemented the multiprotocol approach (BLE and Thread together).
      The DFU starts correctly with the first version (the older one). It works (reset and run the new application) only if I put --sd-req 0x00 when I generate the package, if I put --sd-req 0xCA (that is the SD I'm using in my application) the DFU starts and ends, but the new application is not run.
      Instead, the DFU doesn't start at all with the second version (the more recent one with the multiprotocol implementation)
      The main difference between the two versions is how I exploit the SD, so I'm pretty confident that my issue is someway related to SD.
      Moreover, as you can see from debug logs, the cache_adress changes between the two versions: in the switched case it is 0xC2000 (that is the first free flash page after my current flashed fw), in the multiprotocol case it is 0x27000 (that is the start of my current flashed fw). I think 0xC2000 should be the correct adress in a dual-bank scenario (let me know if I'm wrong), but I can't get why in the multiprotocol version the starting adress is 0x27000 (I think the solution crashes because the application tries to overwrite itself someway).
    Thanks in advance,
    Alessio
