ble_db_discovery_start doesn't complete with specific phone
My project uses nRF52840-DK to connect, bond and discover a custom service with two characteristics (TX and RX) and RX Characteristic has a CCCD (0x2902).
The flow of the software goes as follow:
1) the nRF connects to the phone
2) the nRF bonds to the phone
3) the nRF starts discovery of the service
4) the nRF reads/writes from/to the phone using the service
This works as expected with different phones I tried (Galaxy S6, S6 Edge and S7, android versions 7.0, 7.0 and 8.0). but when using Galaxy A31 android version 10.0 I can't complete discovery. I added a print to ble_db_discovery_on_ble_evt() and noticed that with the issued phone I don't get the events with BLE_GATTC_EVT_CHAR_DISC_RSP (50) and BLE_GATTC_EVT_DESC_DISC_RSP (51) which I do get with the working phones.
Furthermore, the issued phone gets a disconnect after some time with error BLE_HCI_CONNECTION_TIMEOUT, which I believe happens because the discovery prevents the nRF to maintain the connection (I saw that with out calling  ble_db_discovery_start the connection doesn't disconnect after a long time).
Does anyone have an idea why this happens?
Thanks in advance
Log of working phone:
<debug> ble_db_disc: Starting discovery of service with UUID 0x1101 on connection handle 0x0.
<debug> nrf_ble_gq: Adding item to the request queue
<debug> nrf_ble_gq: GATTC Primary Services Discovery Request
<debug> nrf_ble_gq: Processing the request queue...
<debug> ble_db_disc: XXXX: ble_db_discovery_on_ble_evt 48
<debug> ble_db_disc: Found service UUID 0x1101.
<debug> nrf_ble_gq: GATTC Characteristic Discovery Request
<debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0.
<debug> ble_db_disc: XXXX: ble_db_discovery_on_ble_evt 50
<debug> nrf_ble_gq: GATTC Characteristic Descriptor Request
<debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0.
<debug> ble_db_disc: XXXX: ble_db_discovery_on_ble_evt 51
<info> ble_db_disc: 0 cccd_handle 43
<debug> ble_db_disc: Discovery of service with UUID 0x1101 completed with success on connection handle 0x0.
<info> app: Discovery complete.
Log of issued phone:
****AFTER A FEW SECONDS*****
<debug> ble_db_disc: XXXX: ble_db_discovery_on_ble_evt 17
<info> app: Disconnected. conn_handle: 0x0, reason: 0x8
  • Thanks for your help,
    I tried the same flow (connect, bond, discovery, indicate enable, read/write) with BT900 and it does work with Android 9+. The BT900 doesn't use CAR, that's why i started suspecting it.
    From the reading of this and this posts, I'm assuming the new android doesn't clear the attribute cache. And only a reset does that. so I think the only way for me to solve this is to change the app on the android to clear the cache after every disconnect.
  • Hey ,
    I digged deep into the sniffer to understand the difference between the times it works and not.
    It always works when nRF is unpaired and phone is after Reset.
    I noticed the not working sniffed log always has this line which the working sniffed log doesn't:
    slave	master	ATT	37	Rcvd Handle Value Indication, Handle: 0x0003 (Unknown)
    on the other hand, the working log has this section which the non-working does not:
    master	slave	ATT	37	Sent Read By Type Request, Central Address Resolution, Handles: 0x0001..0xffff
    slave	master	ATT	35	Rcvd Read By Type Response, Attribute List Length: 1
    master	slave	ATT	33	Sent Read Request, Handle: 0x001a (Generic Attribute Profile: Unknown: Central Address Resolution)
    slave	master	ATT	32	Rcvd Read Response, Handle: 0x001a (Generic Attribute Profile: Unknown: Central Address Resolution)
    This section is related to the CAR so I'm still thinking it has something to do with the problem. any idea why I don't get this section on the failed trials?
    adding both sniffed logs:
    working:
    549	22.702720	master	slave	ATT	33	Sent Exchange MTU Request, Client Rx MTU: 247
    551	22.702720	master	slave	LE LL	35	Control Opcode: LL_LENGTH_REQ
    552	22.702720	slave	master	LE LL	35	Control Opcode: LL_SLAVE_FEATURE_REQ
    553	22.718353	master	slave	LE LL	28	Control Opcode: LL_UNKNOWN_RSP
    554	22.718353	slave	master	LE LL	35	Control Opcode: LL_LENGTH_RSP
    556	22.718353	slave	master	LE LL	32	Control Opcode: LL_VERSION_IND
    557	22.733969	master	slave	LE LL	32	Control Opcode: LL_VERSION_IND
    558	22.733969	slave	master	ATT	33	Rcvd Exchange MTU Response, Server Rx MTU: 247
    566	22.765219	slave	master	ATT	37	Rcvd Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    567	22.765219	master	slave	ATT	44	Sent Read By Group Type Response, Attribute List Length: 2, Generic Access Profile, Generic Attribute Profile
    570	22.765219	slave	master	L2CAP	42	Connection Parameter Update Request
    571	22.780849	master	slave	L2CAP	36	Connection Parameter Update Response (Accepted)
    572	22.780849	slave	master	ATT	37	Rcvd Read By Type Request, GATT Include Declaration, Handles: 0x0001..0x0009
    573	22.780849	master	slave	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_REQ
    575	22.796477	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access Profile)
    578	22.796477	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0x0009
    579	22.812149	master	slave	LE LL	53	L2CAP Fragment Start
    581	22.812149	master	slave	ATT	33	Sent Read By Type Response, Attribute List Length: 4, Device Name, Appearance, Peripheral Preferred Connection Parameters, Central Address Resolution
    584	22.812149	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0009..0x0009
    585	22.827719	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0009 (Generic Access Profile: Central Address Resolution)
    588	22.827719	slave	master	ATT	37	Rcvd Read By Type Request, GATT Include Declaration, Handles: 0x000a..0xffff
    589	22.843341	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x000a (Generic Attribute Profile)
    592	22.843341	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x000a..0xffff
    593	22.858968	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x000a (Generic Attribute Profile)
    596	22.858968	slave	master	L2CAP	42	Connection Parameter Update Request
    597	22.874591	master	slave	L2CAP	36	Connection Parameter Update Response (Accepted)
    599	22.874591	master	slave	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_REQ
    673	23.390272	master	slave	SMP	37	Sent Pairing Request: AuthReq: Bonding | Initiator Key(s): LTK, IRK | Responder Key(s): LTK, IRK
    886	24.983927	slave	master	SMP	37	Rcvd Pairing Response: AuthReq: Bonding, MITM | Initiator Key(s): LTK, IRK | Responder Key(s): LTK, IRK
    887	24.983927	master	slave	SMP	47	Sent Pairing Confirm
    1026	26.030844	slave	master	SMP	47	Rcvd Pairing Confirm
    1027	26.046469	master	slave	SMP	47	Sent Pairing Random
    1030	26.062093	slave	master	SMP	47	Rcvd Pairing Random
    1033	26.093297	master	slave	LE LL	49	Control Opcode: LL_ENC_REQ
    1036	26.108908	slave	master	LE LL	39	Control Opcode: LL_ENC_RSP
    1038	26.124533	slave	master	LE LL	27	Control Opcode: LL_START_ENC_REQ
    1039	26.124533	master	slave	LE LL	27	Control Opcode: LL_START_ENC_RSP
    1042	26.140159	slave	master	LE LL	27	Control Opcode: LL_START_ENC_RSP
    1044	26.155782	slave	master	SMP	47	Rcvd Encryption Information
    1047	26.187098	slave	master	SMP	41	Rcvd Master Identification
    1049	26.202723	slave	master	SMP	47	Rcvd Identity Information
    1051	26.218348	slave	master	SMP	38	Rcvd Identity Address Information
    1052	26.233972	master	slave	SMP	47	Sent Encryption Information
    1054	26.233972	master	slave	SMP	41	Sent Master Identification
    1056	26.249531	master	slave	SMP	47	Sent Identity Information
    1058	26.249531	master	slave	SMP	38	Sent Identity Address Information
    1060	26.249531	master	slave	ATT	37	Sent Read By Type Request, Central Address Resolution, Handles: 0x0001..0xffff
    1063	26.265216	slave	master	ATT	35	Rcvd Read By Type Response, Attribute List Length: 1
    1064	26.280848	master	slave	ATT	33	Sent Read Request, Handle: 0x001a (Generic Attribute Profile: Unknown: Central Address Resolution)
    1067	26.296472	slave	master	ATT	32	Rcvd Read Response, Handle: 0x001a (Generic Attribute Profile: Unknown: Central Address Resolution)
    1108	26.608915	master	slave	ATT	53	Sent Find By Type Value Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    1111	26.624540	slave	master	ATT	35	Rcvd Find By Type Value Response
    1112	26.640165	master	slave	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0028..0xffff
    1115	26.655832	slave	master	LE LL	50	L2CAP Fragment Start
    1117	26.671458	slave	master	ATT	50	Rcvd Read By Type Response, Attribute List Length: 2, Unknown, Unknown
    1118	26.687082	master	slave	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x002e..0xffff
    1121	26.702706	slave	master	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x002e (Generic Attribute Profile: Unknown: Unknown)
    1122	26.718333	master	slave	ATT	35	Sent Find Information Request, Handles: 0x002b..0x002b
    1125	26.733957	slave	master	ATT	36	Rcvd Find Information Response, Handle: 0x002b (Generic Attribute Profile: Unknown: Client Characteristic Configuration)
    1126	26.749580	master	slave	ATT	35	Sent Find Information Request, Handles: 0x002e..0xffff
    1127	26.749580	slave	master	ATT	39	Rcvd Find By Type Value Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    1128	26.765214	master	slave	ATT	35	Sent Find By Type Value Response
    1129	26.765214	slave	master	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x002e (Generic Access Profile: Unknown: Unknown)
    1131	26.780830	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0xffff
    1132	26.796463	master	slave	LE LL	53	L2CAP Fragment Start
    1134	26.796463	master	slave	ATT	33	Sent Read By Type Response, Attribute List Length: 4, Device Name, Appearance, Peripheral Preferred Connection Parameters, Central Address Resolution
    1137	26.812088	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0009..0xffff
    1138	26.827713	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0009 (Generic Access Profile: Central Address Resolution)
    1202	27.296452	master	slave	ATT	35	Sent Write Request, Handle: 0x002b (Generic Access Profile: Unknown: Client Characteristic Configuration)
    1205	27.312070	slave	master	ATT	31	Rcvd Write Response, Handle: 0x002b (Generic Access Profile: Unknown: Client Characteristic Configuration)
    1342	28.765170	master	slave	ATT	53	Sent Write Command, Handle: 0x002d (Generic Access Profile: Unknown)
    1357	28.890176	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1358	28.905801	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1363	28.937050	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1364	28.952672	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1367	28.968298	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1368	28.983924	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1371	28.999548	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1372	29.030796	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1375	29.046423	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1376	29.062046	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1379	29.077672	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1380	29.093268	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1383	29.108855	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1384	29.108855	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1387	29.140112	slave	master	ATT	37	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1388	29.218254	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1393	29.249536	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1394	29.327666	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1397	29.343291	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1398	29.421417	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1401	29.437039	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1402	29.452666	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1405	29.468223	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1406	29.483915	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1409	29.515097	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1410	29.515097	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1413	29.546353	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1414	29.546353	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1417	29.624472	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1418	29.640097	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1423	29.718247	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1424	29.733910	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1427	29.827659	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1428	29.890157	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1431	29.905716	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1432	29.983906	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1435	29.999530	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1436	30.093280	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1439	30.108903	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1440	30.124527	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1443	30.186999	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1444	30.202614	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1447	30.280774	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1448	30.296334	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1451	30.312024	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1452	30.390146	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1457	30.483896	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1458	30.499522	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1461	30.577579	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1462	30.593281	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1465	30.655729	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1466	30.671327	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1471	30.765141	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1472	30.780765	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1477	30.812017	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1478	30.827639	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1483	30.858890	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1484	30.874515	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1487	30.890140	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1488	30.968266	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1491	30.983838	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1492	30.983838	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1495	31.062009	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1496	31.077635	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1501	31.124507	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1502	31.140134	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1505	31.155696	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1506	31.186998	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1509	31.265126	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1510	31.280692	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1513	31.296316	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1514	31.311970	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1517	31.327564	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1518	31.343219	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1521	31.358815	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1522	31.421341	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1525	31.437002	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1526	31.452631	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1529	31.530753	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1530	31.546379	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1535	31.577628	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1536	31.593253	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1539	31.608877	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1540	31.624502	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1543	31.640126	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1544	31.733846	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1549	31.765064	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1550	31.827584	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1555	31.921371	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1556	31.936997	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1561	31.968246	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1562	31.999494	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1569	32.108857	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1570	32.124491	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1581	32.280691	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1582	32.296316	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1597	32.499419	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1598	32.499419	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1617	32.686981	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1618	32.702606	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1635	32.890037	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1636	32.890037	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1639	32.905663	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1640	32.968227	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1649	33.093226	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1650	33.186969	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1659	33.280722	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1660	33.296281	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1669	33.546343	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1670	33.561966	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1681	33.686967	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1682	33.702586	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1697	33.874423	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1698	33.952546	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1703	33.983768	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1704	33.983768	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1715	34.140082	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1716	34.155709	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1729	34.311952	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1730	34.343202	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1743	34.483787	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1744	34.499411	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1757	34.686945	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1758	34.702572	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1775	34.874377	slave	master	ATT	53	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1776	34.890062	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1779	34.905643	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1780	34.936941	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1795	35.108748	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1796	35.124373	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1813	35.296311	slave	master	ATT	42	Rcvd Handle Value Indication, Handle: 0x002a (Generic Access Profile: Unknown)
    1814	35.311936	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x002a (Generic Access Profile: Unknown)
    1825	35.483740	slave	master	ATT	37	Rcvd Handle Value Indication, Handle: 0x0003 (Generic Access Profile: Device Name)
    1826	35.499368	master	slave	ATT	31	Sent Handle Value Confirmation, Handle: 0x0003 (Generic Access Profile: Device Name)
    1903	36.483791	slave	master	LE LL	28	Control Opcode: LL_TERMINATE_IND
    not working:
    7538	76.189737	master	slave	ATT	33	Sent Exchange MTU Request, Client Rx MTU: 247
    7540	76.205312	master	slave	LE LL	35	Control Opcode: LL_LENGTH_REQ
    7541	76.205312	slave	master	LE LL	35	Control Opcode: LL_SLAVE_FEATURE_REQ
    7542	76.205312	master	slave	LE LL	28	Control Opcode: LL_UNKNOWN_RSP
    7543	76.205312	slave	master	LE LL	35	Control Opcode: LL_LENGTH_RSP
    7545	76.220936	slave	master	LE LL	32	Control Opcode: LL_VERSION_IND
    7546	76.220936	master	slave	LE LL	32	Control Opcode: LL_VERSION_IND
    7547	76.220936	slave	master	ATT	37	Rcvd Handle Value Indication, Handle: 0x0003 (Unknown)
    7549	76.236614	slave	master	ATT	33	Rcvd Exchange MTU Response, Server Rx MTU: 247
    7551	76.236614	slave	master	ATT	37	Rcvd Read By Group Type Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    7552	76.252177	master	slave	ATT	44	Sent Read By Group Type Response, Attribute List Length: 2, Generic Access Profile, Generic Attribute Profile
    7553	76.252177	slave	master	L2CAP	42	Connection Parameter Update Request
    7554	76.252177	master	slave	L2CAP	36	Connection Parameter Update Response (Accepted)
    7555	76.252177	slave	master	ATT	37	Rcvd Read By Type Request, GATT Include Declaration, Handles: 0x0001..0x0009
    7556	76.252177	master	slave	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_REQ
    7558	76.267804	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access Profile)
    7561	76.267804	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0x0009
    7562	76.283427	master	slave	LE LL	53	L2CAP Fragment Start
    7564	76.283427	master	slave	ATT	33	Sent Read By Type Response, Attribute List Length: 4, Device Name, Appearance, Peripheral Preferred Connection Parameters, Central Address Resolution
    7567	76.283427	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0009..0x0009
    7568	76.299085	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0009 (Generic Access Profile: Central Address Resolution)
    7571	76.299085	slave	master	ATT	37	Rcvd Read By Type Request, GATT Include Declaration, Handles: 0x000a..0xffff
    7572	76.314737	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x000a (Generic Attribute Profile)
    7575	76.314737	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x000a..0xffff
    7576	76.330359	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x000a (Generic Attribute Profile)
    7579	76.330359	slave	master	L2CAP	42	Connection Parameter Update Request
    7580	76.345985	master	slave	L2CAP	36	Connection Parameter Update Response (Accepted)
    7582	76.345985	master	slave	LE LL	38	Control Opcode: LL_CONNECTION_UPDATE_REQ
    7666	76.939723	master	slave	SMP	37	Sent Pairing Request: AuthReq: Bonding | Initiator Key(s): LTK, IRK | Responder Key(s): LTK, IRK
    7933	78.924058	slave	master	SMP	37	Rcvd Pairing Response: AuthReq: Bonding, MITM | Initiator Key(s): LTK, IRK | Responder Key(s): LTK, IRK
    7934	78.939679	master	slave	SMP	47	Sent Pairing Confirm
    8063	79.908362	slave	master	SMP	47	Rcvd Pairing Confirm
    8064	79.923998	master	slave	SMP	47	Sent Pairing Random
    8067	79.939619	slave	master	SMP	47	Rcvd Pairing Random
    8070	79.970869	master	slave	LE LL	49	Control Opcode: LL_ENC_REQ
    8073	79.986486	slave	master	LE LL	39	Control Opcode: LL_ENC_RSP
    8075	80.002100	slave	master	LE LL	27	Control Opcode: LL_START_ENC_REQ
    8076	80.002100	master	slave	LE LL	27	Control Opcode: LL_START_ENC_RSP
    8079	80.033350	slave	master	LE LL	27	Control Opcode: LL_START_ENC_RSP
    8081	80.033350	slave	master	SMP	47	Rcvd Encryption Information
    8083	80.048974	slave	master	SMP	41	Rcvd Master Identification
    8085	80.064639	slave	master	SMP	47	Rcvd Identity Information
    8087	80.080283	slave	master	SMP	38	Rcvd Identity Address Information
    8088	80.095907	master	slave	SMP	47	Sent Encryption Information
    8090	80.111473	master	slave	SMP	41	Sent Master Identification
    8092	80.111473	master	slave	SMP	47	Sent Identity Information
    8094	80.111473	master	slave	SMP	38	Sent Identity Address Information
    8142	80.455275	master	slave	ATT	53	Sent Find By Type Value Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    8145	80.470901	slave	master	ATT	35	Rcvd Find By Type Value Response
    8146	80.486524	master	slave	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x0028..0xffff
    8149	80.502147	slave	master	LE LL	50	L2CAP Fragment Start
    8151	80.517772	slave	master	ATT	50	Rcvd Read By Type Response, Attribute List Length: 2, Unknown, Unknown
    8152	80.533399	master	slave	ATT	37	Sent Read By Type Request, GATT Characteristic Declaration, Handles: 0x002e..0xffff
    8155	80.549022	slave	master	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x002e (Generic Attribute Profile: Unknown: Unknown)
    8156	80.564648	master	slave	ATT	35	Sent Find Information Request, Handles: 0x002b..0x002b
    8159	80.580270	slave	master	ATT	36	Rcvd Find Information Response, Handle: 0x002b (Generic Attribute Profile: Unknown: Client Characteristic Configuration)
    8160	80.595897	master	slave	ATT	35	Sent Find Information Request, Handles: 0x002e..0xffff
    8163	80.611520	slave	master	ATT	35	Rcvd Error Response - Attribute Not Found, Handle: 0x002e (Generic Attribute Profile: Unknown: Unknown)
    8165	80.627146	slave	master	ATT	39	Rcvd Find By Type Value Request, GATT Primary Service Declaration, Handles: 0x0001..0xffff
    8166	80.642772	master	slave	ATT	35	Sent Find By Type Value Response
    8169	80.658397	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0001..0xffff
    8170	80.674018	master	slave	LE LL	53	L2CAP Fragment Start
    8172	80.674018	master	slave	ATT	33	Sent Read By Type Response, Attribute List Length: 4, Device Name, Appearance, Peripheral Preferred Connection Parameters, Central Address Resolution
    8175	80.689646	slave	master	ATT	37	Rcvd Read By Type Request, GATT Characteristic Declaration, Handles: 0x0009..0xffff
    8176	80.705271	master	slave	ATT	35	Sent Error Response - Attribute Not Found, Handle: 0x0009 (Generic Access Profile: Central Address Resolution)
    8192	80.814585	master	slave	ATT	35	Sent Write Request, Handle: 0x002b (Generic Access Profile: Unknown: Client Characteristic Configuration)
    8195	80.830267	slave	master	ATT	31	Rcvd Write Response, Handle: 0x002b (Generic Access Profile: Unknown: Client Characteristic Configuration)
    8330	82.267735	master	slave	ATT	53	Sent Write Command, Handle: 0x002d (Generic Access Profile: Unknown)
    8795	88.517565	slave	master	LE LL	28	Control Opcode: LL_TERMINATE_IND
    any ideas will help,
    Thanks
    I am going to order a galaxy A31 to look into this. Is there any example in the nRF5 SDK I can use as-is to recreate your issue?
    Kenneth
  • Thanks !
    This issue happens in all Android 9+ (I saw in in every android 9 and 10 I checked), so you don't have to use A31.
    This project is a mix of SDK examples but I will try to make a minimal example that will demonstrate the issue you could use.
    Thanks again,
    Robbie
