DFU on nRF Master Control Panel (andriod version)
Dear all.
I have some test result on DFU feature. Please any comment on this issue.
test condition
  • Mater control panel (64-bit version)
  • nRFgo studio (64-bit version) : 1.19.0.7
  • Smart Beacon Kit : PCA20006
  • Pre-compiled binary within Smart Beacon Kit v1.1.0
test result
  • With PCA10000 dongle : The DFU is successful with all binaries.
  • nRF Master Control Panel v2.1.1 (android version)
    Only application DFU is successful. The DFU with bootloader and softdevice is NOT successful. Remote DFU Invalid CRC error happen so that I captured log files for two cases.
dfu-android-bootloader-Log 2015-06-01 210155.txt
dfu-android-sd-Log 2015-06-01 210410.txt
BR
oceanide
  • Hi, the Error 0x85 (error 133) happens occasionally sometimes. Also, I think, it may happen when the device is not reachable. If you are dealing with the DFU bootloader from SDK 8+ you should remember that the DFU advertises with an address incremented by 1 when entered with a button (not the buttonless DFU) or in case the softdevice was updated (as it removes the app). This causes a situation when you may send the SD+BL to a device with normal address (when the buttonless update was used) and then an application to a device with address incremented. This issue has been fixed in the new releases of all the Android apps. But it only applies to a situation when you flash SD+BL+App in a single ZIP file after using buttonless update.
    If you want to verify the CRC the best way is to use the nrf utility tool. I gave a link to some documentation above.
