Documentation about the sdk_config.h file; remove unnecessary project files.
I am trying to port an nRF51 project that runs on the nRF51 DK using Keil to the nRF52840 DK using Segger Embedded Studio. Clearly the best way to start is to take an example from the SDK which has all the Segger-specific stuff and hardware specific stuff and change those few files which the app developer actually writes (like main.c) and update for the new SoftDevice
In my case the Keil project uses SoftDevice calls for all the Bluetooth functionality and Flash. It handles the sd_ble_evt_get() and dispatching of events.  I know I will have to make a few modifications because there are changes in SoftDevice s130 to SoftDevice s140 but they are not extensive. However, the sdk_config.h file changes ARE huge and I don't know what 90% of it means. Is there any detailed documentation describing what all these config parameters mean? A few are obvious to me like turning off the service support like CTS, DIS, BATtery, etc. This project is an implementation of a proposed protocol and there is no support in the SDK for it. So I want to turn off all those items in the sdk_config.h file that I don't need, but I don't want to mess up something that will mess up that which is needed for the chip on the DK.
Eventually I want to remove all the files in the project that I don't need - that's not too easy either. It would be nice to have a final project which ONLY contains those files necessary to build this project.
How to proceed?
    brianreinhold said:
    That did not exist in 12.3.0 and since GATT has always been around, why is this present but not before.
    In SDK 13, a "GATT module" was introduced and is enabled by default. This module enables MTU request and Data Packet Length Extension (DLE). For all phones supporting BLE 4.2 and above, the examples in the SDK will work out of the box.
    For phones that support BLE 4.0 and/or BLE 4.1 only, MTU requests and DLE will not work. In that case, you will have to disable it in the SDK example: all you need to do is to comment out gatt_init(). See SDK13.0 Migration guide/GATT module
    brianreinhold said:
    What will cause conflicts if enabled but I don't use? If the advertisement module is enabled but I use sd_ calls to create and start my advertisments, will that cause a problem? Will it bloat the final built project?
    To enable the configs in the SDK can let you use the specific modules/libraries/features/drivers. It won't cause an issue in that case.
    Would you like to migrate the porject to SDK17.0.2  or start a new porject from SDK17.02? What is your application? I would suggest start from a similiar example to know what configs and features you would need.
    -Amanda H.
  • In the end I ported my source code from Keil 12.3.0 (SoftDevice only for BTLE and Flash) to Segger 17.2.0 (SoftDevice only for BTLE and Flash), replacing the source files for the hts demo of 17.2.0. The part that caused me the greatest difficulty was the logging and the initialization of SoftDevice. In the end it turned out to be just two calls to SoftDevice that I needed and the removal of an SDK module that was getting called under the hood that was trapping and processing BTLE events before I could get them. Once I got logging and debugging to work I found that module was getting set up in the original ble_stack_init(). Otherwise the rest of SoftDevice API changes between s130 and s140 were minimal.
    By trial and error I have removed files from the build and have reduced the size considerably. Most of the options in SDK_config.h are now disabled. It turns out I need to enable FPRINTF in order to use NRF_LOG. I don't think this was intended but the NRF Log source file for strings makes calls into FPRINTF so enabling NRF_LOG and disabling FPRINT will give you build errors. I don't think the reverse is true.
    The project then built in Keil without an issue except it was 200 bytes too large to build in the size-limited free version that I have. Oh well, Segger does the job.
    I think it would be nice if you had an example that used JUST SoftDevice as there are many advantages of such a project - especially when migrating between versions and/or platforms. SoftDevice changes little -  the SDK changes dramatically and the footprint is much smaller.
    In my case I am working on a new standard for health devices and there is no support for it in the SDK. For experimental work, using SoftDevice only has great advantages!
  • Some examples under examples\peripheral just use SoftDevice. Hope they can help you.
    -Amanda H.
  • Which ones? There are a fair number!! I see mostly nrf_* SDK calls in the few I looked at. If there is a BTLE example using SoftDevice only that would be helpful though at this stage I have got it mostly working (but I may have done things that will come back and bite me).
    The best help I got was the example using the pc-ble-driver. My first work I did was to write a set of BLE health devices using the nrf52840 dongle with that package and that's all soft device. However, there are special initialization routines (clearly) in the pc-ble-driver which don't carry over to writing directly on the MCU. And that's where I encountered most of my difficulties. So seeing examples of that would still be advantageous.
  • Unfortunately, they are for hardware peripheral instead of BTLE. Some of the them implements with softdevice like Blinky Example, under nRF5_SDK_17.0.2_d674dde\examples\peripheral\blinky\pca10040\s132.
    -Amanda H.
