Debug stack corruption problem?
I've got an issue where calling a function is overwriting a variable in the calling function. See attached screenshots. In the first, byte is 0x1b. After stepping into the function (without any more code being executed) byte is overwritten with 0x0. I don't know where to start to debug this issue! Fortunately it is easily reproducible (in my firmware), and happens every time. Any suggestions? I'm using GNU Arm Embedded Toolchain 10-2020-q4-major, debugging here with arm-none-eabi-gdb in CLion. Stepping over instructions I can see the corruption occurs during the bl instruction:
0x0004f492 <+6>:	ldrb.w	r0, [r0, #512]	; 0x200
=> 0x0004f496 <+10>:	bl	0x28b64 <min_tx_byte> // stepi triggers corruption
However, this doesn't occur every time this function is called, only during a few specific calls. The calling function is in a linked library, and the called function is in my main application, not sure if that makes any difference but explains the large delta in the bl instruction. I've checked the softdevice ram allocation (it requested 0x3120 bytes, so RAM size is 0xcee0, and I've defined __HEAP_SIZE=0 __STACK_SIZE=0x2000).
  • Dump of min_tx_byte for  completeness:
    Dump of assembler code for function min_tx_byte:
    => 0x00028b64 <+0>:	push	{r4, lr}
       0x00028b66 <+2>:	mov	r4, r1
       0x00028b68 <+4>:	ldr	r3, [pc, #28]	; (0x28b88 <min_tx_byte+36>)
       0x00028b6a <+6>:	ldr	r3, [r3, #0]
       0x00028b6c <+8>:	cmp	r3, #254	; 0xfe
       0x00028b6e <+10>:	bhi.n	0x28b7e <min_tx_byte+26>
       0x00028b70 <+12>:	ldr	r2, [pc, #20]	; (0x28b88 <min_tx_byte+36>)
       0x00028b72 <+14>:	ldr	r3, [r2, #0]
       0x00028b74 <+16>:	ldr	r1, [pc, #20]	; (0x28b8c <min_tx_byte+40>)
       0x00028b76 <+18>:	strb	r4, [r1, r3]
       0x00028b78 <+20>:	adds	r3, #1
       0x00028b7a <+22>:	str	r3, [r2, #0]
       0x00028b7c <+24>:	pop	{r4, pc}
       0x00028b7e <+26>:	ldr	r1, [pc, #16]	; (0x28b90 <min_tx_byte+44>)
       0x00028b80 <+28>:	movs	r0, #129	; 0x81
       0x00028b82 <+30>:	bl	0x264e4 <assert_nrf_callback>
       0x00028b86 <+34>:	b.n	0x28b70 <min_tx_byte+12>
       0x00028b88 <+36>:	strh	r0, [r4, r7]
       0x00028b8a <+38>:	movs	r0, #0
       0x00028b8c <+40>:	strh	r0, [r4, r3]
       0x00028b8e <+42>:	movs	r0, #0
       0x00028b90 <+44>:	ldr	r2, [pc, #624]	; (0x28e04 <_generic_hvx+32>)
       0x00028b92 <+46>:	movs	r5, r0
    Yes execution does continue with a value of 0, which is how I got to this point – some of the values sent on the wire are different to the values used to compute the crc (next line after min_tx_byte is called).
    Bluetooth is not active, so the softdevice should not really be doing anything much, but the fact this happens at to the exact same bytes every time (and repeatedly, because this sequence of bytes is sent repeatedly on timer) indicates it is probably not related to interrupt activity, and anyway I think the debugger would follow the interrupt if it occurred while stepping(?). The only interrupts are through app_timer (RTC) and libuarte. I'm not using heap at all.
    The calling function is open source: github.com/.../min.c It used to work, so something changed around it (a lot has changed around it, but not the calling or called functions)
    Thanks. From what I understand, the called function should be responsible for keeping registers r4 and higher. That's why at the beginning of both stuffed_tx_byte and min_tx_byte, various registers are pushed onto the stack. However, it looks like the two functions are not using the same convention. It looks like stuffed_tx_byte expects r5 not to get changed by called functions, while min_tx_byte in fact does change r5 in the final instruction (movs r5, r0), without having previously pushed that register to the stack, or otherwise keeping its value for the return. It may almost look like it rather uses r5 for a return value? That looks a bit strange. So this looks like a compiler / toolchain issue. Are both files compiled using the same toolchain, and which one?
    Terje
  • % /usr/local/bin/arm-none-eabi-gcc -v
    Using built-in specs.
    COLLECT_GCC=/usr/local/bin/arm-none-eabi-gcc
    COLLECT_LTO_WRAPPER=/usr/local/Cellar/arm-none-eabi-gcc/10-2020-q4-major/gcc/bin/../lib/gcc/arm-none-eabi/10.2.1/lto-wrapper
    Target: arm-none-eabi
    Configured with: /tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/src/gcc/configure --target=arm-none-eabi --prefix=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native --libexecdir=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/lib --infodir=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/share/doc/gcc-arm-none-eabi/info --mandir=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/share/doc/gcc-arm-none-eabi/man --htmldir=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/share/doc/gcc-arm-none-eabi/html --pdfdir=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --enable-plugins --disable-decimal-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libquadmath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared --disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-newlib --with-headers=yes --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/install-native/arm-none-eabi --build=x86_64-apple-darwin10 --host=x86_64-apple-darwin10 --with-gmp=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/build-native/host-libs/usr --with-mpfr=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/build-native/host-libs/usr --with-mpc=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/build-native/host-libs/usr --with-isl=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/build-native/host-libs/usr --with-libelf=/tmp/jenkins-GCC-10-pipeline-48_20201124_1606180639/build-native/host-libs/usr --with-host-libstdcxx='-static-libgcc -Wl,-lstdc++ -lm' --with-pkgversion='GNU Arm Embedded Toolchain 10-2020-q4-major' --with-multilib-list=rmprofile,aprofile
    Thread model: single
    Supported LTO compression algorithms: zlib
    gcc version 10.2.1 20201103 (release) (GNU Arm Embedded Toolchain 10-2020-q4-major)
    To make min.c.obj:
    C_DEFINES = -DTARGET_KFSHARED_COMPONENTS
    C_INCLUDES = -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/lib/min
    C_FLAGS = --std=gnu99 -Wall -Wno-attributes -Wno-format -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -Og -g3 -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DDEBUG=1 -DMAX_NUM_CONNECTIONS=1 -DTARGET_KFSHARED_COMPONENTS -DCONFIG_GPIO_AS_PINRESET -DENABLE_LESC=0 -Wno-unknown-pragmas -std=gnu11
    /usr/local/bin/ccache /usr/local/bin/arm-none-eabi-gcc $(C_DEFINES) $(C_INCLUDES) $(C_FLAGS) -o CMakeFiles/min.dir/target/min.c.obj -c /Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/lib/min/target/min.c
    To make KFPAL_Nordic_serial.c.obj:
    C_DEFINES = -DBOARD_PCA10040 -DCONFIG_GPIO_AS_PINRESET -DDEBUG=1 -DKFASSERTHANDLER_ENABLE=1 -DKF_CRYPTO_LIB_UECC -DKF_FIRMWARE=1 -DKF_FIRMWARE_VERSION=1.0.0-a.1 -DKF_MODEL=DevKit -DKF_MODEL_DevKit -DKF_SDK_VERSION=1,s132_7.2.0 -DKF_SERVER_MESSAGE -DKF_USER_MESSAGE -DMAX_NUM_CONNECTIONS=1 -DMAX_PAYLOAD=244 -DMBEDTLS_CONFIG_FILE=\"/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/nrf_tls/mbedtls/nrf_crypto/config/nrf_crypto_mbedtls_config.h\" -DMIN_DEBUG_PRINTING=1 -DNRF52832 -DNRF52832_XXAA -DNRF52_SERIES -DNRF_SD_BLE_API_VERSION=7 -DS132 -DSOFTDEVICE_PRESENT -DUSE_APP_CONFIG -D__HEAP_SIZE=0 -D__STACK_SIZE=0x2000 -DuECC_SUPPORTS_secp160r1=0 -DuECC_SUPPORTS_secp192r1=0 -DuECC_SUPPORTS_secp224r1=0 -DuECC_SUPPORTS_secp256k1=0
    C_INCLUDES = -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/src -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/src/BLEServices -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/src/HardwareCustomisations -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/balloc -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/memobj -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/strerror -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/ringbuf -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/fprintf -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/include -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/util -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic_flags -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/common -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/common -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/nrf_ble_qwr -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/mutex -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/pwr_mgmt -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/mem_manager -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic_fifo -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fds -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fstorage -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/experimental_section_vars -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/include -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/segger_rtt -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/hardfault -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/prs -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/libuarte -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/queue -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/scheduler -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/hal -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/cc310 -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/cc310_bl -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/cifra -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/mbedtls -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/micro_ecc -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/nrf_hw -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/nrf_sw -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/oberon -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/optiga -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/stack_info -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/integration/nrfx/legacy -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/timer -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_advertising -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_link_ctx_manager -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/nrf_ble_gatt -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dis -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dfu -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/svc -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/bootloader -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/bootloader/dfu -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/bootloader/ble_dfu -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/s132/headers -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/s132/headers/nrf52 -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/mdk -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/toolchain/cmsis/include -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/toolchain/gcc -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/toolchain/cmsis/dsp/GCC -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/boards -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/integration/nrfx -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/delay -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/mbedtls/include -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/src -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/src/DeviceCustomisations -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/src/Algorithms -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/src/../UmbrellaHeaders -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Foundation -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/BLE -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/DeviceDefaults -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/DeviceTypes -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Cryptography -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Messages -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Messages/User -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Messages/Server -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/OBDConfig -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Logs -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/Configuration -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/SharedMessages -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/OBDProtocol/MessageHandler -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/OBDProtocol/Messages -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/src/../UmbrellaHeaders/Firmware -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/lib/micro-ecc -I/Users/nick/Documents/Repos/KeyFreeOBDFirmware/lib/KeyFreeFirmwareCommon/lib/KeyFreeSharedComponents/lib/min
    /usr/local/bin/ccache /usr/local/bin/arm-none-eabi-gcc $(C_DEFINES) $(C_INCLUDES) $(C_FLAGS) -o CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_serial.c.obj -c /Users/nick/Documents/Repos/KeyFreeOBDFirmware/src/KFPAL_Nordic_serial.c
    Main link.txt:
    /usr/local/bin/ccache /usr/local/bin/arm-none-eabi-gcc --std=gnu99 -Wall -Wno-attributes -Wno-format -ffunction-sections -fdata-sections -fno-strict-aliasing -fno-builtin --short-enums -Og -g3 -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Wl,--gc-sections --specs=nano.specs -L"/Users/nick/Documents/Repos/KeyFreeOBDFirmware/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/mdk" "-L/Users/nick/Documents/Repos/KeyFreeOBDFirmware/src/linker" -Xlinker -Map="/Users/nick/Documents/Repos/KeyFreeOBDFirmware/cmake-build-debug-arm-none-eabi/src/KeyFreeOBDFirmwareProject_DevKit.map" -T"/Users/nick/Documents/Repos/KeyFreeOBDFirmware/src/linker/nrf52832_xxAA_s132_7.2.0.ld" -u _printf_float CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/lib/KeyFreeFirmwareCommon/src/DeviceCustomisations/KFDeviceCustomisationDevKit.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/HardwareCustomisations/KFHardwareCustomisationDevKit.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/main.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_app_scheduler.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_bluetooth.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_crypto.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_flash.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_log.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_mem.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_power.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_provisioning.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_serial.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_shared.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_timer_keep_active.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/KFPAL_Nordic_timers.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/BLEServices/ble_kf_common.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/BLEServices/ble_kf_service.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/balloc/nrf_balloc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/memobj/nrf_memobj.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/strerror/nrf_strerror.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic/nrf_atomic.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/ringbuf/nrf_ringbuf.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/fprintf/nrf_fprintf.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/fprintf/nrf_fprintf_format.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_str_formatter.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_frontend.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_default_backends.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_backend_flash.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_backend_rtt.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_backend_serial.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/log/src/nrf_log_backend_uart.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/util/app_error.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/util/app_error_weak.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic_flags/nrf_atflags.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/util/app_util_platform.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/experimental_section_vars/nrf_section_iter.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/common/nrf_sdh_soc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/common/nrf_sdh_ble.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/softdevice/common/nrf_sdh.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/common/ble_conn_state.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/common/ble_conn_params.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/common/ble_advdata.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/common/ble_srv_common.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/nrf_ble_qwr/nrf_ble_qwr.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/mem_manager/mem_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/atomic_fifo/nrf_atfifo.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fds/fds.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fstorage/nrf_fstorage.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fstorage/nrf_fstorage_sd.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/fstorage/nrf_fstorage_nvmc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_timer.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/external/segger_rtt/SEGGER_RTT.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_rtc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/hardfault/hardfault_implementation.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/hardfault/nrf52/handler/hardfault_handler_gcc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/prs/nrfx_prs.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_uart.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_uarte.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_gpiote.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_ppi.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/libuarte/nrf_libuarte_drv.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/queue/nrf_queue.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/libuarte/nrf_libuarte_async.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/scheduler/app_scheduler.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/hal/nrf_nvmc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/mbedtls/mbedtls_backend_init.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/mbedtls/mbedtls_backend_aes_aead.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_aead.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_init.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_shared.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/mbedtls/mbedtls_backend_hash.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_hash.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/mbedtls/mbedtls_backend_hmac.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_hmac.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_rng_mbedtls.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/backend/nrf_hw/nrf_hw_backend_init.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/crypto/nrf_crypto_rng.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/drivers/src/nrfx_rng.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/integration/nrfx/legacy/nrf_drv_rng.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/timer/app_timer.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_advertising/ble_advertising.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/nrf_ble_gatt/nrf_ble_gatt.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dis/ble_dis.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dfu/ble_dfu.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dfu/ble_dfu_bonded.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/ble_services/ble_dfu/ble_dfu_unbonded.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/svc/nrf_svc_handler.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/bootloader/nrf_bootloader_info.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/bootloader/dfu/nrf_dfu_svci.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/auth_status_tracker.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/gatt_cache_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/gatts_cache_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/id_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/nrf_ble_lesc.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/peer_data_storage.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/peer_database.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/peer_id.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/peer_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/peer_manager_handler.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/pm_buffer.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/security_dispatcher.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/ble/peer_manager/security_manager.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/mdk/system_nrf52.c.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/modules/nrfx/mdk/gcc_startup_nrf52.S.obj CMakeFiles/KeyFreeOBDFirmwareProject_DevKit.dir/__/toolchains/nRF5/nRF5_SDK_17.0.2_d674dde/components/libraries/util/app_error_handler_gcc.c.obj -o KeyFreeOBDFirmwareProject_DevKit.elf  mbedtls/library/libmbedcrypto.a KeyFreeFirmwareCommon/src/libKeyFreeFirmwareCommon.a KeyFreeFirmwareCommon/src/KeyFreeSharedComponents/src/libKeyFreeSharedComponentsFirmware.a KeyFreeFirmwareCommon/src/KeyFreeSharedComponents/src/liblibuECC.a KeyFreeFirmwareCommon/src/KeyFreeSharedComponents/src/min/libmin.a
    libmin.a link.txt:
    /usr/local/bin/ccache /usr/local/bin/arm-none-eabi-ar qc libmin.a CMakeFiles/min.dir/target/min.c.obj
    /usr/local/bin/ccache /usr/local/bin/arm-none-eabi-ranlib libmin.a
    I'm using CMake to generate makefiles, and the CMake scripts from the nRF mesh SDK (with my project here).
    I'm not sure all the disassembly I pasted for min_tx_byte is relevant, you can see it uses pop and ldr and then only after that is r5 present, I think the assembly after this (+36 onwards) could be for another function? I'm not sure. generic_hvx is never called in the C code though, and as you can see in my previous message min_tx_byte only has 3 lines of code and is a void return function
  • I stepped through the instructions and printed the value of $r5 and it didn't change, so I think this might have been a debugger issue (even though I thought it wasn't at first). I realised that my definition of MAX_PAYLOAD was different in the two C files. This led to the buffer size being allocated on the stack as 244 bytes, but min.c was expecting it to be 255 bytes, and so was overwriting the following members of the struct. Apologies for wasting time!
