the fatfs example is work ,but dont work in my project
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup fatfs_example_main main.c
 * @ingroup fatfs_example
 * @brief FATFS Example Application main file.
 * This file contains the source code for a sample application using FAT filesystem and SD card library.
#include "bsp.h"
#include "diskio_blkdev.h"
#include "ff.h"
#include "nrf.h"
#include "nrf_block_dev_sdc.h"
#include "app_usbd.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_core.h"
#include "app_usbd_serial_num.h"
#include "app_usbd_string_desc.h"
#include "nrf_drv_usbd.h"
#include "nrf_gpio.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_gpiote.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SDC_SCK_PIN NRF_GPIO_PIN_MAP(1, 13)  ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN NRF_GPIO_PIN_MAP(1, 15) ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN NRF_GPIO_PIN_MAP(0, 2)  ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN NRF_GPIO_PIN_MAP(1, 10)   ///< SDC chip select (CS) pin.
// #define BUTTON_1 NRF_GPIO_PIN_MAP(1, 6)
#define TEST_TIME_DELAY NRF_GPIO_PIN_MAP(0, 13)
#define FILE_NAME "NORDIC.TXT"
#define TEST_STRING "Hello world."
#define LED_USB_RESUME (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX (BSP_BOARD_LED_3)
#define BTN_CDC_DATA_SEND 0
#define BTN_CDC_NOTIFY_SEND 1
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
// UARTUI
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const *p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE 0
#define CDC_ACM_COMM_EPIN NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE 1
#define CDC_ACM_DATA_EPIN NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT NRF_DRV_USBD_EPOUT1
#define READ_SIZE 64
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[READ_SIZE];
static void fatfs_example();
 * @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
 * @brief  SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
    m_block_dev_sdc,
    NRF_BLOCK_DEV_SDC_CONFIG(
        SDC_SECTOR_SIZE,
        APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)),
    NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00"));
    app_usbd_cdc_acm_t const *p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
    case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
        bsp_board_led_on(LED_CDC_ACM_OPEN);
        /*Setup first transfer*/
        ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                               m_rx_buffer,
                                               READ_SIZE);
        UNUSED_VARIABLE(ret);
    case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
        bsp_board_led_off(LED_CDC_ACM_OPEN);
    case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
        // nrfx_gpiote_out_clear(TEST_TIME_DELAY);
        bsp_board_led_invert(LED_CDC_ACM_TX);
    case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
        ret_code_t ret;
        //            NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
        app_usbd_cdc_acm_bytes_stored(&m_app_cdc_acm);
        do
            /*Get amount of data transfered*/
            size_t size = app_usbd_cdc_acm_rx_size(&m_app_cdc_acm);
            //                NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
            /* Fetch data until internal buffer is empty */
                                        m_rx_buffer,
                                        READ_SIZE);
        } while (ret == NRF_SUCCESS);
        memcpy(m_tx_buffer, m_rx_buffer, READ_SIZE);
        app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, READ_SIZE); //
        bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
    case APP_USBD_EVT_DRV_SUSPEND:
        bsp_board_led_off(LED_USB_RESUME);
    case APP_USBD_EVT_DRV_RESUME:
        bsp_board_led_on(LED_USB_RESUME);
    case APP_USBD_EVT_STARTED:
    case APP_USBD_EVT_STOPPED:
        app_usbd_disable();
        bsp_board_leds_off();
    case APP_USBD_EVT_POWER_DETECTED:
        //            NRF_LOG_INFO("USB power detected");
        if (!nrf_drv_usbd_is_enabled())
            app_usbd_enable();
    case APP_USBD_EVT_POWER_REMOVED:
        //            NRF_LOG_INFO("USB power removed");
        app_usbd_stop();
    case APP_USBD_EVT_POWER_READY:
        //            NRF_LOG_INFO("USB ready");
        app_usbd_start();
/// end for USB CDC
void clocks_start(void)
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
//-----------------------GPIO-----------------------------
static void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    if (pin == BUTTON_1)
        // bsp_board_led_invert(LED_CDC_ACM_RX);
        fatfs_example();
void gpio_init(void)
    ret_code_t err_code;
    //        APP_ERROR_CHECK(err_code);
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(BUTTON_1, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(BUTTON_1, true);
 * @brief Function for demonstrating FAFTS usage.
static FATFS fs;
static DIR dir;
static FILINFO fno;
static FIL file;
static void fatfs_init()
    uint32_t bytes_written;
    FRESULT ff_result;
    DSTATUS disk_state = STA_NOINIT;
    // Initialize FATFS disk I/O interface by providing the block device.
    static diskio_blkdev_t drives[] =
            DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)};
    diskio_blockdev_register(drives, ARRAY_SIZE(drives));
    NRF_LOG_INFO("Initializing disk 0 (SDC)...");
    for (uint32_t retries = 3; retries && disk_state; --retries)
        disk_state = disk_initialize(0);
    if (disk_state)
        NRF_LOG_INFO("Disk initialization failed.");
        return;
    uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
    uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
    NRF_LOG_INFO("Capacity: %d MB", capacity);
    NRF_LOG_INFO("Mounting volume...");
    ff_result = f_mount(&fs, "", 1);
    if (ff_result)
        bsp_board_led_invert(1);
        NRF_LOG_INFO("Mount failed.");
        return;
    NRF_LOG_INFO("\r\n Listing directory: /");
    ff_result = f_opendir(&dir, "/");
    if (ff_result)
        NRF_LOG_INFO("Directory listing failed!");
        return;
    do
        ff_result = f_readdir(&dir, &fno);
        if (ff_result != FR_OK)
            NRF_LOG_INFO("Directory read failed.");
            return;
        if (fno.fname[0])
            if (fno.fattrib & AM_DIR)
                NRF_LOG_RAW_INFO("   <DIR>   %s", (uint32_t)fno.fname);
                NRF_LOG_RAW_INFO("%9lu  %s", fno.fsize, (uint32_t)fno.fname);
    } while (fno.fname[0]);
    NRF_LOG_RAW_INFO("");
    FRESULT ff_result;
    NRF_LOG_INFO("Writing to file " FILE_NAME "...");
    ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
        NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".");
        sprintf(m_tx_buffer,"ff_result = %d", ff_result);
        app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, sizeof(m_tx_buffer));
        return;
    ff_result = f_write(&file, TEST_STRING, sizeof(TEST_STRING) - 1, (UINT *)&bytes_written);
        NRF_LOG_INFO("Write failed\r\n.");
        NRF_LOG_INFO("%d bytes written.", bytes_written);
    (void)f_close(&file);
    return;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler};
    nrf_drv_clock_init();
    clocks_start();
    gpio_init();
    NRF_LOG_INFO("FATFS example started.");
    app_usbd_serial_num_generate();
    app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const *class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    app_usbd_class_append(class_cdc_acm);
    if (USBD_POWER_DETECTION)
        app_usbd_power_events_enable();
        app_usbd_enable();
        app_usbd_start();
    fatfs_init();
    while (true)
        __WFE();
id my code ,please help me
  • Hi
    Sorry about the delayed reply, but we're currently investigating what this could be. It does not seem to be related to the priority. What it could be though, is a bug with the nrf_block_dev_qspi.c, where any access of the files via USB will demolish the file system. You can try adding the following code snippet at the beginning of block_dev_qspi_uninit() in nrf_block_dev_qspi.c:
    if ((p_work->state != NRF_BLOCK_DEV_QSPI_STATE_IDLE))
    Unknown macro: { wait_for_idle(p_qspi_dev); }
    Simon
  • Thanks for reply, I wonder that can I transfer data to pc via USB and store the data to sd card at the same time .
  • Hi
    I've asked one of our experts on the matter for some input on this issue and will get back to you when I hear back from them. Thank you for your patience.
    Simon
  • Hi
    Simon
    UPDATE: If the USB does not use QSPI in any way, fatfs should be able to use it. Thus, what you're decribing should be possible. After another look at your initial code upload, it seems like you try calling some fatfs functions before initializing Fatfs with the fatfs_init() function, which could be the reason of this NOT_READY errors you're seeing. Please make sure that the fatfs is properly initialized before trying to access the file system.
    Simon
  • Many Thanks,at my code, if I commented out this code
    app_usbd_class_inst_t const *class_inst_msc = app_usbd_msc_class_inst_get(&m_app_msc);
        app_usbd_class_append(class_inst_msc);
            app_usbd_enable();
            app_usbd_start();
            m_usb_connected = true;
    the fatfs can work normally. And I don't use  the QSPI in my code.
