nRF52840 multiperipheral with very low power sleep mode
Hello, I want to make multiperipheral system with nRF52840 (Im using 4x nRF52840DK). Im using latest SDK17. I wrote criteria i want to put to this system below:
1. Devices are supposed to be connected with BLE
- One central device
- Minimum three peripheral devices
2. Peripheral devices are supposed to be in sleep mode
- Sleep time ~1min
- System ON, full 256kB RAM retention, wake on GPIOTE - PORT event (power consumption in sleep mode less than 3uA)
- I don't want any advertising in sleep mode
3. Peripheral devices are supposed to be wake up with port event and then i want to send 8kB of data over BLE from RAM
- uint8_t data[8192];
- data need to be send with the highest througput posibble
4. Central device is supposed to only recieve data
- not needed sleep mode
- data need to be written in internal RAM (uint8_t data[3][8192];) or something similar
And my questions are:
How to start?
What are the best examples to modify?
It is posibble to achieve constant 3uA current consumption in sleep (1min) and after wake up send the data in 60ms (after that again go to sleep)?
Best regards
Rafał Dolny
  • I'm trying something like this:
    1. Turn on power on peripheral
    2. I have global variable static volatile bool ble_connected (after reset is false)
    3. In main function after all initializations i'm advertising with advertising_start() function
    4. Now im sitting in main -> while(!ble_connected ) until BLE_GAP_EVT_CONNECTED (there im changing ble_connected to true)
    5. After that im waiting with nrf_delay_ms for send data with function ble_nus_data_send
    6. After transmission i'm using sd_ble_gap_adv_stop() but i see NRF_ERROR_INVALID_STATE
    It is a proper thinking? Where or when i can use sd_ble_gap_adv_stop() without errors?
    Without nrf_delay_ms device wasn't transmitting any data. How can I check proper moment for sending for achieve possible short time?
    Best regards
    Rafał Dolny
     That is because you are not advertising. By default it will stop advertising when you enter the connection. Try sd_ble_gap_disconnect() to disconnect. Just note that when you disconnect, the BLE_GAP_EVT_DISCONNECTED event will by default start advertising (not from your main.c file, but from the ble_advertising.c file).
    To disable this, set ble_adv_on_disconnect_disabled = true in advertising_init():
    init.config.ble_adv_on_disconnect_disabled = true;
  • I've tried to disconnect with function sd_ble_gap_disconnect() and it works but i have problem with one thing. When I'm disconnecting peripheral and I want to connect it again and send data  i'm observing minimum 300ms of time between wake up to finish sending. I'm negotiating 2Mbps phy also and I think that connecting in that way is way too long. Can You tell me what exactly cause those spikes in interval connection period? This is advertising?
    Best regards
    Rafał Dolny
  • Hi Rafał,
    Can you say what exactly happens during this time? What is your connection parameters? Do you pair? Do service discovery? Other things? How much data do you send and how? All this is needed in order to understand why the time is so long (and if anything could be done about it). Also, a sniffer trace is very useful to understand what happens.
    The spikes you refer to, is that current spikes? If so, it could be advertising, I cannot say without knowing more. Can you share a plot?
    Einar
  • Hi Einar,
    In first stage i see the connection have 1Mbps phy. To change to 2Mbps it needs arround 300ms. In the next step I see another 100-300ms then peripheral does not transmitt any data. After that I can see transmission.
    Im using ble_app_uart with 2Mbps phy, delay for viewing on oscilloscope and your suggestion with advertising_init().
    Best regards
    Rafał Dolny
