Bandwidth drop with more than 1024 bytes with TCP or UDP sockets (nRF9160 DK)
I am doing tests on nRF9160 DK and I observe that if I send more than 1024 bytes on a TCP or UDP socket, the bandwidth drops.
Here are some numbers :
for TCP :
Payload size [B] Throughput [KB/s]
1000 15.32
1023 15.61
1024 15.57
1025 3.17
1050 3.18
for UDP :
1000 24.19
1023 25.44
1024 25.01
1025 12.37
1050 12.58
We can see that the bitrate drops after 1024 bytes. Do you have any idea why ? and if it is possible to avoid that ?
I am using :
- nRF COnnect SDK v1.4.99-dev1
- nRF9160 DK
- BSD library (CONFIG_BSD_LIBRARY=y) & standard POSIX
Here is the loop I'm using to send the payload
The parameter SIZE_BUFFER represents the size of payload.
Thanks
  • Here are some comments about the trace;
    "The difference in throughput comes outside from modem. In 1024B, the first 10 packets are sent from application to modem in 0.5 seconds. The first 10 packets in 1025B log takes 2,5 seconds to arrive from application to modem.
    Customer should check the functionality of the application. Why it is feeding data to modem slower when packet size increases from 1024 Bytes."
  • Thanks for news,
    " Why it is feeding data to modem slower when packet size increases from 1024 Bytes." This is part of my first question.
    Like we can see in the picture on the first post, it's a while loop and there isn't difference in my application between feeding data to modem with 1024B or 1025B, but the size of the buffer. But its slower when packet size increases from 1024 Bytes...
    Anyway, since i moved to NCS1.5.0, the problem is no longer there.
