Dear !!
Good day!!
I want to change the device name using command from mobile along wither after setting the device name i want update the Password, so can you share any example code.
Regards
Chandru
Dear !!
Good day!!
Regards
Chandru
Dear sir,
Device name set code is below, and i'm able to change the device name but once reset or OF/ON conditions the existing name is coming, what to to??
static void setDeviceName(uint8_t *device_name)
/* Change device name */
uint32_t err_code = sd_ble_gap_device_name_set(&sec_mode,
(const uint8_t *)device_name,
strlen(device_name));
/* Store Current connection state od adv lib */
uint16_t m_adv_current_slave_link_conn_handle_saved = m_advertising.current_slave_link_conn_handle;
/* Re-initialize advertising module */
advertising_init();
/* Re-store Current connection state lib */
m_advertising.current_slave_link_conn_handle = m_adv_current_slave_link_conn_handle_saved;
printf("Name has been set %s \n",device_name);
nrf_gpio_pin_clear(GREEN_LED);
Thanks & Regards
Chandru.A
Then I suggest you start by fixing the errors so that it builds without warnings. If it still does not work, then please let me know how you test in detail. Also you cannot ignore return values. How do you know that sd_ble_gap_device_name_set() is successfull?
