Dear Community;
I am trying to send some data via Lora with a nRF9160 connected with SPI to RF95W Lora module. The transmitter is a nRF9160 with a RF95W, and the receiver is a Raspberry Pi, also with a RF95W.
My transmitter code for nRF9160 is the one located in /zephyr/samples/drivers/lora/send:
* Copyright (c) 2019 Manivannan Sadhasivam
#include <device.h>
#include <drivers/lora.h>
#include <errno.h>
#include <sys/util.h>
#include <zephyr.h>
#define DEFAULT_RADIO_NODE DT_ALIAS(lora0)
BUILD_ASSERT(DT_NODE_HAS_STATUS(DEFAULT_RADIO_NODE, okay),"No default LoRa radio specified in DT");
#define DEFAULT_RADIO DT_LABEL(DEFAULT_RADIO_NODE)
#define MAX_DATA_LEN 10
#define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
#include <logging/log.h>
LOG_MODULE_REGISTER(lora_send);
char data[MAX_DATA_LEN] = {'h', 'e', 'l', 'l', 'o', 'w', 'o', 'r', 'l', 'd'};
void main(void)
printk("\nStarting...\n");
const struct device *lora_dev;
struct lora_modem_config config;
int ret;
lora_dev = device_get_binding(DEFAULT_RADIO);
if (!lora_dev) {
printk("%s Device not found", DEFAULT_RADIO);
return;
//config.frequency = 865100000;
config.frequency = 868000000;
config.bandwidth = BW_125_KHZ;
config.datarate = SF_10;
config.preamble_len = 8;
config.coding_rate = CR_4_8;
config.tx_power = 17;
config.tx = true;
ret = lora_config(lora_dev, &config);
if (ret < 0) {
printk("LoRa config failed");
return;
while (1) {
ret = lora_send(lora_dev, data, MAX_DATA_LEN);
if (ret < 0) {
printk("LoRa send failed");
return;
printk("\nData sent!");
/* Send data at 1s interval */
k_sleep(K_MSEC(1000));
this is the .overlay file:
aliases {
lora0 = &lora;
&uart0 {
current-speed = <115200>;
status = "okay";
tx-pin = <23>;
rx-pin = <24>;
&uart1 {
status = "disabled";
&spi3 {
status = "okay";
sck-pin = <20>;
mosi-pin = <21>;
miso-pin = <22>;
cs-gpios = <&gpio0 19 GPIO_ACTIVE_LOW>;
lora: sx1276@0 {
compatible = "semtech,sx1276";
reg = <0>;
label = "sx1276";
reset-gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
dio-gpios = <&gpio0 1 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>,
<&gpio0 2 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>,
<&gpio0 3 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>,
<&gpio0 4 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>,
<&gpio0 5 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
spi-max-frequency = <1000000>;
power-amplifier-output = "pa-boost";
The connection between nRF and RF95W is the following:
3V --> 3V
GND --> GND
MOSI --> MOSI
MISO --> MISO
SCK --> SCK
GPIO 19 --> NSS(Chip select)
Then, I have an antenna connected to RF95W antenna pin.
Firts thing I don´t understand is regarding to this piece of code:
if (!lora_dev) {
return;
The program never enters in that if statement, also with the RF95W module completely disconnected... Also with the RF95W completely disconnected, I don´t get any error at lora_config() or lora_send() functions.
I only thing I have noticed is that if I have the RF95W and nRF9160 well conneted I see this information:
I: SX1276 Version:12 found
If I disconnect NSS(Chip select) I get:
I: SX1276 Version:ff found
If I disconnect 3V I get:
I: SX1276 Version:00 found
However, as mentioned before, I don´t get any errors in the program and I get "Data Sent!" print.
I also know that the Raspberry + RF95W receiver works fine, because we have been able to transmit data to it from another Raspberry + RF95W from 1km distance.
It is very important to us making RF95W work, and we don´t know that else we can try, best regards.
