Can I modify source code for the vitual com of nRF52833 USB CDC ACM in \examples\peripheral\usbd_cdc_acm?
   we are using D- and D+ in our nRf52833 board,    I want to use the CDC ACM USB class  as Virtual COM port.
  I found that there has a demo example in the \examples\peripheral\usbd_cdc_acm,  but it is only used for nRf52840,
  Could I modify it for nRF52833?
  • Hi Simonr,
        initialize() and start()  are about Mesh
    static void mesh_init(void)
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .models.config_server_cb = config_server_evt_cb
        uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
        switch (status)
            case NRF_ERROR_INVALID_DATA:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reset device before starting of the provisioning process.\n");
            case NRF_SUCCESS:
                ERROR_CHECK(status);
    #if 1//NRF_MESH_SERIAL_ENABLE
        ERROR_CHECK(nrf_mesh_serial_init(NULL));
        m_evt_handler.evt_cb = mesh_evt_handler;
        nrf_mesh_evt_handler_add(&m_evt_handler);
    static void initialize(void)
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
        __LOG_INIT(LOG_MSK_DEFAULT | LOG_SRC_DFU | LOG_SRC_APP | LOG_SRC_SERIAL, LOG_LEVEL_INFO, log_callback_rtt);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Bluetooth Mesh DFU Example -----\n");
        ble_stack_init();
        mesh_init();
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initialization complete!\n");
    static void start(void)
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data = static_auth_data,
                .prov_complete_cb = NULL,
                .prov_device_identification_start_cb = NULL,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = NULL,
                .p_device_uri = EX_URI_DFU
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Enabling serial interface...\n");
        ERROR_CHECK(nrf_mesh_serial_enable());
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        ERROR_CHECK(mesh_stack_start());
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "DFU with usb driver example started!\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "bootloader_id is 255\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "application_id is 255\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "other is same with srd3_radar_sensor\n");
  • Okay, so you're working on implementing Mesh into the USB/DFU project you've created, correct? Can you confirm that you've followed the Bluetooth Mesh user guide to integrate Mesh into nRF5 SDK examples? What SDK version (both nRF5 SDK and Mesh SDK version) are you using?
    Simon
  • Hi Simonr,
    Thanks for your reply.
    ===yes
    ====yes
    ===nRF52 SDK:  16.0.0
    ===Mesh SDK:     4.2.0
  • Hi
    The LPN example in the Mesh SDK uses the DFU from the nRF5 SDK, and we have a section on how you can configure DFU over BLE using the LPN example here. Alternatively, you can check out and implement the DFU example in the Mesh SDK and its user guide.
    Simon
