NRF_ERROR_TIMEOUT when executing advertising example given in pc-ble-driver-py
hello,
I'm working with nRF52840 dongle, i installed nRF Connect for desktop v3.6.1 on ubunto 18.4 and i am using python3. After programming  connectivity_4.1.4_usb_with_s132_5.1.0.hex and installling pc-ble-driver version 0.15.0, i tried to execute the example (Advertising)  given in pc-ble-driver i got this error when i type the comand
python3 ./advertising.py NRF52 /dev/ttyACM0
Serial port used: /dev/ttyACM0
  File "./advertising.py", line 107, in <module>
    main(sys.argv[2])
  File "./advertising.py", line 65, in main
    driver.open()
  File "/home/my_pc/.local/lib/python3.6/site-packages/pc_ble_driver_py/ble_driver.py", line 107, in wrapper
    error_code=err_code,
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: NRF_ERROR_TIMEOUT
i have obtained the same error with sudo python3 ./advertising.py NRF52 /dev/ttyACM0
Has anyone else had an issue like this ?
  • Thank you,
    it return this :
    total 0
    lrwxrwxrwx 1 root root 13 mai    7 09:43 usb-Nordic_Semiconductor_Open_DFU_Bootloader_D6F9B927D70E-if00 -> ../../ttyACM0
    i executed it by using this command : sudo python3 ./advertising.py NRF52 /dev/ttyACM0
    but it is the same thing, i don't understand the reason.
        main(sys.argv[2])
        driver.open()
      File "/home/My-pc/.local/lib/python3.6/site-packages/pc_ble_driver_py/ble_driver.py", line 107, in wrapper
  • Nordic_Semiconductor_Open_DFU_Bootloader_D6F9B927D70E
    This means that you are in bootloader mode, and the connectivity firmware is not running.
    Is the LED on the dongle blinking red ?
    Could you try to program the connectivity_4.1.4_usb_with_s132_5.1.0.hex again, with nRF Connect programmer app?
  • yes, the led is blinking red. when i programmed the  connectivity_4.1.4_usb_with_s132_5.1.0.hex i got this:
    12:53:50.161
    Application data folder: /home/My-pc/.config/nrfconnect/pc-nrfconnect-programmer
    12:53:50.202
    Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6
    12:53:52.408
    Using USB SDFU protocol to communicate with target
    12:53:52.415
    Protocol Version: 1 found
    12:53:52.416
    Hardware: 52840 found
    12:53:52.424
    Firmware: Bootloader found
    12:53:52.424
    Firmware: SoftDevice found
    12:53:52.424
    Firmware: Application found
    12:54:05.224
    Parsing HEX file: /home/My-pc/Downloads/connectivity_1.0.0_usb_with_s132_5.1.0.hex
    12:54:05.259
    File was last modified at 1/18/2019, 10:39:36 AM
    12:54:05.349
    SoftDevice detected, id 0xA5 (S132 v5.1.0)
    12:54:07.659
    Does not need to be reloaded: /home/My-pc/Downloads/connectivity_1.0.0_usb_with_s132_5.1.0.hex
    12:54:07.663
    SdReq for SoftDevice is set as 0x00.
    12:54:07.664
    Hash is generated by SHA256
    12:54:07.665
    12:54:07.671
    Performing DFU. This may take a few seconds
    12:54:07.684
    DFU procedure starts. This may take a few seconds.
    12:54:14.951
    DFU for SoftDevice completed successfully!
    12:54:14.952
    1 dfu package(s) left.
    12:54:14.952
    Waiting for device
    12:54:15.069
    12:54:24.750
    DFU for Application completed successfully!
    12:54:24.750
    0 dfu package(s) left.
    12:54:24.750
    Waiting for device
    12:54:25.855
    All dfu images have been written to the target device.
    12:54:25.856
    DFU trigger interface found, changing to bootloader...
    12:54:26.801
    12:54:26.804
    12:54:26.804
    12:54:26.806
    12:54:26.806
    12:54:26.807
    12:54:26.812
    it was the same thing that i had before
  • 1) Why does it say "connectivity_1.0.0_usb_with_s132_5.1.0" in your log? It should be "connectivity_4.1.4_usb_with_s132_5.1.0.hex" ?
    2) After programming the dongle, if you plug it out from the computer, and then plug it back in, does the LED still blink red?
  • 1) i have tried different connectivity. Now i'm working with "connectivity_4.1.4_usb_with_s132_5.1.0.hex" and it works also
    2) No, it is not blinking when i plug it out from the computer, and then plug it back in.
