using external flash MX25R1635FZUIL0 with nrf52 - having issues of writting and reading when multiple tasks are using the flash
Hello, I am using MX25R1635FZUIL0 with nrf52  and my device is working with freertos.  I have three different tasks using/accessing  the flash functions but when i read back the data for all the 3 tasks i read some values as 0 and some as 0xFF and some correct values. But I need 100% correct data.my task 1 n 2 are sampling data at a speed of 256 Hz and then calling flash write function so when these two works together my error rate reduces but when i start the 3rd task which samples data at 16kHz i get only 1-2 % correct data for task 1 n 2 and almost all 0xFF for task 3. Can anyone please help me what should i do to get all the data correctly from flash
  • Sara,
    If the tasks are holding the semaphore for the whole transaction for that sensor (read/write/read_write) then you should not see any issues here. I think, the issue here is that the semaphore is being released too early and the other task is starting a read/write/read_write operation when the sensor has not still not finished completely from the previous operation. I would focus a bit more on the logic you have around releasing/locking this semaphore. Probably the sensor takes few us/ms more than what you think a read/write transaction needs from your driver? Try adding some timer delay (NOT busy loop) before and after every transaction (read/write/read_write) to fake extra time given for the transaction to complete and see if that helps. If it  does then you need to reconsider your semaphore release/locking logic
  • Hello Susheel,
    for delay u meant to use nrf_delay_ms(). ??
  • yes, busy delay would be easiest here just to give the external sensor time to complete the previous transaction. In any case comparing the timings of a transaction on the logic analyzer would have made your job easier to see why introduction of  MIC task  changes the states/timing of the data exchanged.
