nRF9160 connectivity & configuration help
We are working to improve our connectivity globally, and have some questions about how we might improve our firmware.
We are using the nRF9160 to connect via LTE-M (CAT-M1) using a SIM that allows us to roam across multiple networks. This SIM has a feature that allows it to rotate through several profiles in order to find a network that we can connect to.
The initialization of the nRF9160 modem (FW 1.2.0) is done via the following AT commands:
  • AT%CESQ=1
  • AT+CPSMS=1,,,"01100000","00000000"
  • AT+CSCON=3
  • AT+CNEC=24
  • AT%XSYSTEMMODE=1,0,0,0
  • AT+CGDCONT=0,"IP","[APN]"
  • AT+CEREG=5
  • AT+CFUN=1
Our questions are:
  1. What should we do about +CEREG status = 4 (“Unknown”)?
    Whilst the modem is searching and attempting to connect to a network (+CEREG: 2), we occasionally see +CEREG status messages indicating “Unknown” status.
    Example message: +CEREG: 4,"FFFE","FFFFFFFF",7,0,15,"11100000","11100000"
    Our question is what to do in this case? Is this an error, meaning we should try again (maybe turn the modem off, then on again), or should we just let the modem continue to search? Our interpretation of this above message is that the network search has completed, but no available networks were found (reject_cause=15, indicates “No suitable cells in tracking area”). Will the modem continue to search? We’ve also seen reject_cause=11 (“PLMN not allowed”) and have similar questions.
  2. Is it possible to do a factory reset for the modem?
    One thing that makes debugging difficult is that we aren’t sure what settings are stored/cached in the modem’s NVM. This makes it difficult to compare device behavior across multiple devices.
  3. When should we transition into AT+CFUN=0 and when should we transition to AT+CFUN=4?
    Several of the AT commands state that settings are written to NVM when transitioning to CFUN=0. Is there guidance on when it’s best to transition to off vs. airplane mode? Our approach has been to transition to airplane mode when we wish to save power, but when an unpredictable reset happens (via a user event), we want to be able to reasonably quickly connect to the network again.
  4. Why does it sometimes take about 60 seconds from CFUN=1 to the first status update message (example: %CESQ: 14,0,0,0 followed within 1 millisecond by +CEREG: 2,"0411","00EF090F",7,0,0,"11100000","11100000"). Is there something we can/should be doing to force the modem to begin searching immediately?
Any help would be appreciated!
Thank you,
Jonathan
  • Hi!
    The scenarios described can happen when the device is coming out of airplane mode.
    Furthermore, the modem team let me know that unless this issue is present on MFW 1.3.0 where there are fixes to multi-SIM operation, they will not work on this case.
  • Hi Heidi,
    Thank you for the response. Given this response, we will prioritize adoption of 1.3.0. Can you give any guidance on using 1.3.0 for Revision 1 hardware (nRF9160 SICA B0A)? The release notes currently specify that 1.3.0 should only be used for development and testing; what sort of limitations are there with Revision 1 hardware?
    Similarly, do you expect Verizon certification to happen for 1.3.0? And, if so, what is the timeline on that?
    Thank you,
    Jonathan
  • Hi!
    We recommend all customers transition to nRF9160 SiP Rev 2, as MFW 1.3.0 and nRF9160 SiP Rev 1 will not be a widely certified combination.
    I can make this case private and we can discuss your specific use case (i.e number of chips, reason you can't transition to Rev2) if you would like.
    With regard to Verizon certification, contact your RSM, David Day ([email protected]), for information on this.
    Heidi
    My apologies for taking so long to circle back on this. We've still been seeing some similar issues w/r/t transitioning from CFUN=4 to CFUN=1. I've created a simple firmware image that does repeated cycles to CFUN=4/CFUN=1 and measures the reconnection time, along with traces.
    I've attached a ZIP file with the relevant files.
    • src/main.c and prj.conf are built against v1.6.0 nrf SDK running w/1.3.0 modem firmware.
    • 2021-07-08--083113---putty.log shows the UART output
    • trace-2021-07-08T13-18-51.639Z.bin contains the modem trace
    An example of the timeout is in the logs "Network connection attempt timed out". What's odd is that the reconnections *mostly* happen quite quickly (within 5 seconds). But sometimes they do time out, despite the network conditions seemingly not changing.network-timeout.zip
    Thank you,
    Jonathan
  • The communication for this ticket has been moved to email but I am adding a summary here for future reference.
    The consensus is that the UE is having issues with poor signal levels. They have looked for other causes of disconnection but determined the low signal level as the strongest indicator.
