nRF52840 led 5 blinks continuously causing reset and not performing code properly. I tried different USB cables but it still blinks. What could be the reason, is it only causing reset? and what can be done to make it proper?
Thank you
Pankti
Thank you
Pankti
This worked for me. thanks.
What causes this problem?
I have same problem :(
"press the IF BOOT/RESET button while power cycling" not worked for me & led5 blinking continuously !!
Hello Esmaeill,
does the board shows up as "bootloader", after you pressed RESET when powering the board up?
Michael
I think your issue is handled by this case ld5 flashing quickly, board not visible, PCA10056 IF BOOT not work! .
-Amanda H.
