mesh integration on existing firmware -- Program dwells on unknown function
I just recently began implementing the mesh stack into an existing application, using mesh v3.2 and nrf sdk 15.2.
Integration works well by using the integration guide provided in the infocenter, but the mesh doesn't start after initializiation.
in detail I basically tried implementing the mesh_main.c file from the sdk_coexist proximity example, initialization seems to work alright, my services are still visible on LightBlue but as soo as I start the mesh stack my programs will suspend on an unknown function 0x978. This doesn't happen in the SoftDevice but rather at the end of the nrf_mesh_enable function. Debugging doesn't give me an error either, the program basically just stops.
Any hints on what is going on here? I copied most of the configuration from the proximity coexist example as flash_placement specs and configurations from the app_config file, only some settings have to stay the same as before.
Im using a nrf52840 and SD140 6.1.0
Would appreciate any kind of help!
