timers in nrf5340
1) In nrf5340 app CPU,  there are only 3 timer I can use, timer0, timer1 and time2, is it right?
2) I want to use four timers in my project, to control two SPI. now I only have 3 timers, what can I do to get the fourth timer? Do I need to use one timer in Net CPU? if yes, how?
Thanks a lot.
Carl
  • Hi Carl,
    Carl Sun said:
    Can the timer from Zephyr be 20 µs?
     No, the Zephyr kernel timer uses the RTC peripheral(32.768 kHz clock), so you get ~30 us resolution, and it's not possible to use (D)PPI with it. So TIMER seems to fit your use-case better.
    Note that with the TIMER, you have 6 capture compare channels, so you might not need to use all TIMERS instances. e.g. use TIMER1 CC[0] for one SPI, and TIMER1 CC[1] for the other SPI. But if that is not possible for your use-case, and you need an additional TIMER, then yes, it looks to be possible to get the network core TIMER to generate events to the application core, by using the interprocessor communication (IPC) peripheral. See figure 3 at this link.
