Socket API "send" hangs when sending multiple TCP messages
   I am developing an application that requires communication between two nrf52840-based devices. There is a scenario in my application where the devices needs to exchange multiple TCP packets, however after transmitting nearly 50 messages, send API hangs. The inter-message transmission interval is 70-200 ms. I am using TCP over IEEE 802.15.4 with POSIX names enabled. My application's message size 14-byte. I would be really thankful for your help.
Omer
  • Thanks for the logs! I couldn't manage to find any obvious problems in them. Could you share the applications here so that I can have a look?
    This could possible be an overflow issue. Does it happen after the same number of messages every time?
    Carl Richard
  • Thanks for your reply. Unfortunately, I will not be able to share my application code here due to restrictions.
    The problem nearly starts to happen after the same number of messages, but the number is not exactly the same very time. Can I suggest you to please use net/sockets echo client server example and transmit messages in an loop, you may reproduce the same problem?
    Omer
  • Hi Carl,
       I have tested echo-client/server example by transmitting data packets in a loop. I can now confirm that the blocking behavior is reproduced in the echo-client/server example as well. I have attached the source files and proj.conf file. Please note that I am using nRF Connect SDK Version 1.3.0, however I have also tested on over nRF Connect Version 1.5.0.  6472.prj.conf
    #include <zephyr.h>
    #include <errno.h>
    #include <stdio.h>
    #include <net/socket.h>
    #include <linker/sections.h>
    #include <shell/shell.h>
    #include <net/net_core.h>
    #define MY_PORT 4242
    #define PEER_PORT 4242
    void main()
        printk("Starting the Process ... \n") ;
    	struct sockaddr_in6 addr6, addr_peer;
    	int sock_id = 0 ;
    	int ret = 0 ;
    	char msg[] = "HELLO\n" ;
        char msg1[100] ;
    	memset(&addr6, 0, sizeof(addr6));
    	addr6.sin6_family = AF_INET6;
    	addr6.sin6_port = htons(MY_PORT);
    	inet_pton(AF_INET6, CONFIG_NET_CONFIG_MY_IPV6_ADDR,
    			  &addr6.sin6_addr);
    	sock_id = socket(AF_INET6, SOCK_DGRAM, IPPROTO_UDP);
    	if(sock_id == -1)
    		printk("Error in creating socket \n") ;
    		return ;
    	ret = bind(sock_id, (struct sockaddr *) &addr6, sizeof(addr6)) ;
    	if(ret < 0)
    			printk("Error in Binding the Socket \n") ;
    			return ;
    	while(true)
    		(void) memset(&addr_peer, 0, sizeof(addr_peer));
    		addr_peer.sin6_family = AF_INET6;
    		addr_peer.sin6_port = htons(PEER_PORT);
    		inet_pton(AF_INET6, CONFIG_NET_CONFIG_PEER_IPV6_ADDR,
    			  &addr_peer.sin6_addr);
            ret = sendto(sock_id, msg, sizeof(msg), 0, (struct sockaddr *)&addr_peer, sizeof(addr_peer)) ;
    		if(ret < 0)
    			printk("Error in Transmitting the Message \n");
    			return ;
    			printk("The message has been transmitted \n") ;
    			ret = recv(sock_id, (void*) msg1, sizeof(msg1), 0) ;
    			printk("%s\n" ,msg) ;
    			/*stop_time = k_cycle_get_32();
    			cycles_spent = stop_time - start_time;
    			nanoseconds_spent = k_cyc_to_ns_ceil32(cycles_spent) ; //SYS_CLOCK_HW_CYCLES_TO_NS(cycles_spent);*/
    		memset(msg1, sizeof(msg1), 0) ;
    		k_msleep(1000) ;
    	return ;
    #include <zephyr.h>
    #include <errno.h>
    #include <stdio.h>
    void main()
    	int sock_id = 0 ;
    	int ret = 0 ;
    	char msg[100] ;
    	(void)memset(&addr6, 0, sizeof(addr6));
    			  &addr6.sin6_addr);
    	if(sock_id == -1)
    		return ;
    	while(true)
    		/* Continously send message to a server after every 5 seconds */
    		ret = recv(sock_id, (void*) msg, sizeof(msg), 0) ;
    		if(ret < 0)
    			printk("Error in Receiving a Message \n");
    			return ;
    			printk("%s\n", msg) ;
    			if(ret < 0 )
    					printk("Error in transmitting message \n") ;
    	close(sock_id) ;
    	return ;
  • Hello again, Omer!
    Apologies for the delayed answer and thanks for the additional information! It seems like this might be a bug on our side. I'll report this internally and will get back to you soon.
    Carl Richard
  • Hi again!
    The developers are looking into this now. In the meantime, could you try to increase the following buffers and see if that give you better results?
    CONFIG_NET_PKT_RX_COUNT
    CONFIG_NET_PKT_TX_COUNT
    CONFIG_NET_BUF_RX_COUNT
    CONFIG_NET_BUF_TX_COUNT
    And for some clarification; I see that TCP isn't enabled in the echo samples you tested last. Hence, we can assume that this isn't related to the TCP/UDP operation and rather some lower level issue. Agree?
    Carl Richard
