Hi All,
I am new and trying to connect External BLE Pressure Sensor to NRF52840-DK Board
Do you have any example code for interfacing external BLE sensors that I can refer ?
What you suggest to start with .?
Hi All,
I see. That is demonstrated by the various GATT service clients in the SDK as described in earlier posts. You should look at one of those implementations that fit and do the same, adapting it to your needs.
* Copyright (c) 2012 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_BAS_C)
#include "ble_bas_c.h"
#include "ble_types.h"
#include "ble_db_discovery.h"
#include "ble_gattc.h"
#define NRF_LOG_MODULE_NAME ble_bas_c
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
/**@brief Function for intercepting errors of GATTC and BLE GATT Queue.
* @param[in] nrf_error Error code.
* @param[in] p_ctx Parameter from the event handler.
* @param[in] conn_handle Connection handle.
static void gatt_error_handler(uint32_t nrf_error,
void * p_ctx,
uint16_t conn_handle)
ble_bas_c_t * p_bas_c = (ble_bas_c_t *)p_ctx;
NRF_LOG_DEBUG("A GATT Client error has occurred on conn_handle: 0X%X", conn_handle);
if (p_bas_c->error_handler != NULL)
p_bas_c->error_handler(nrf_error);
/**@brief Function for handling read response events.
* @details This function validates the read response and raises the appropriate
* event to the application.
* @param[in] p_bas_c Pointer to the Battery Service Client Structure.
* @param[in] p_ble_evt Pointer to the SoftDevice event.
static void on_read_rsp(ble_bas_c_t * p_bas_c, ble_evt_t const * p_ble_evt)
const ble_gattc_evt_read_rsp_t * p_response;
// Check if the event is on the link for this instance.
if (p_bas_c->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
return;
p_response = &p_ble_evt->evt.gattc_evt.params.read_rsp;
if (p_response->handle == p_bas_c->peer_bas_db.bl_handle)
ble_bas_c_evt_t evt;
evt.conn_handle = p_ble_evt->evt.gattc_evt.conn_handle;
evt.evt_type = BLE_BAS_C_EVT_BATT_READ_RESP;
evt.params.battery_level = p_response->data[0];
p_bas_c->evt_handler(p_bas_c, &evt);
/**@brief Function for handling Handle Value Notification received from the SoftDevice.
* @details This function handles the Handle Value Notification received from the SoftDevice
* and checks whether it is a notification of the Battery Level measurement from the peer. If
* it is, this function decodes the battery level measurement and sends it to the
* application.
* @param[in] p_ble_bas_c Pointer to the Battery Service Client structure.
* @param[in] p_ble_evt Pointer to the BLE event received.
static void on_hvx(ble_bas_c_t * p_ble_bas_c, ble_evt_t const * p_ble_evt)
if (p_ble_bas_c->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
return;
// Check if this notification is a battery level notification.
if (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_bas_c->peer_bas_db.bl_handle)
if (p_ble_evt->evt.gattc_evt.params.hvx.len == 1)
ble_bas_c_evt_t ble_bas_c_evt;
ble_bas_c_evt.conn_handle = p_ble_evt->evt.gattc_evt.conn_handle;
ble_bas_c_evt.evt_type = BLE_BAS_C_EVT_BATT_NOTIFICATION;
ble_bas_c_evt.params.battery_level = p_ble_evt->evt.gattc_evt.params.hvx.data[0];
p_ble_bas_c->evt_handler(p_ble_bas_c, &ble_bas_c_evt);
void ble_bas_on_db_disc_evt(ble_bas_c_t * p_ble_bas_c, const ble_db_discovery_evt_t * p_evt)
// NRF_LOG_INFO("Entering into the ble_bas_on_db_disc_evt");
// Check if the Battery Service was discovered.
if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE
p_evt->params.discovered_db.srv_uuid.uuid == BLE_UUID_BATTERY_SERVICE
p_evt->params.discovered_db.srv_uuid.type == BLE_UUID_TYPE_BLE)
// Find the CCCD Handle of the Battery Level characteristic.
uint8_t i;
evt.evt_type = BLE_BAS_C_EVT_DISCOVERY_COMPLETE;
evt.conn_handle = p_evt->conn_handle;
for (i = 0; i < p_evt->params.discovered_db.char_count; i++)
if (p_evt->params.discovered_db.charateristics[i].characteristic.uuid.uuid ==
BLE_UUID_BATTERY_LEVEL_CHAR)
// Found Battery Level characteristic. Store CCCD handle and break.
evt.params.bas_db.bl_cccd_handle =
p_evt->params.discovered_db.charateristics[i].cccd_handle;
evt.params.bas_db.bl_handle =
p_evt->params.discovered_db.charateristics[i].characteristic.handle_value;
NRF_LOG_INFO("Battery Service discovered at peer.");
//If the instance has been assigned prior to db_discovery, assign the db_handles.
if (p_ble_bas_c->conn_handle != BLE_CONN_HANDLE_INVALID)
if ((p_ble_bas_c->peer_bas_db.bl_cccd_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_bas_c->peer_bas_db.bl_handle == BLE_GATT_HANDLE_INVALID))
p_ble_bas_c->peer_bas_db = evt.params.bas_db;
p_ble_bas_c->evt_handler(p_ble_bas_c, &evt);
else if (p_evt->evt_type == BLE_DB_DISCOVERY_SRV_NOT_FOUND)
NRF_LOG_INFO("BLE_DB_DISCOVERY_SRV_NOT_FOUND");
NRF_LOG_DEBUG("Battery Service discovery failure at peer. ");
else if (p_evt->evt_type == BLE_DB_DISCOVERY_ERROR)
NRF_LOG_INFO("BLE_DB_DISCOVERY_ERROR");
else if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
NRF_LOG_INFO("BLE_DB_DISCOVERY_COMPLETE");
// Do nothing.
/**@brief Function for creating a message for writing to the CCCD.
static uint32_t cccd_configure(ble_bas_c_t * p_ble_bas_c, bool notification_enable)
NRF_LOG_DEBUG("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d",
p_ble_bas_c->peer_bas_db.bl_cccd_handle,
p_ble_bas_c->conn_handle);
nrf_ble_gq_req_t bas_c_req;
uint8_t cccd[BLE_CCCD_VALUE_LEN];
uint16_t cccd_val = notification_enable ? BLE_GATT_HVX_NOTIFICATION : 0;
cccd[0] = LSB_16(cccd_val);
cccd[1] = MSB_16(cccd_val);
memset(&bas_c_req, 0, sizeof(bas_c_req));
bas_c_req.type = NRF_BLE_GQ_REQ_GATTC_WRITE;
bas_c_req.error_handler.cb = gatt_error_handler;
bas_c_req.error_handler.p_ctx = p_ble_bas_c;
bas_c_req.params.gattc_write.handle = p_ble_bas_c->peer_bas_db.bl_cccd_handle;
bas_c_req.params.gattc_write.len = BLE_CCCD_VALUE_LEN;
bas_c_req.params.gattc_write.p_value = cccd;
bas_c_req.params.gattc_write.offset = 0;
bas_c_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
return nrf_ble_gq_item_add(p_ble_bas_c->p_gatt_queue, &bas_c_req, p_ble_bas_c->conn_handle);
uint32_t ble_bas_c_init(ble_bas_c_t * p_ble_bas_c, ble_bas_c_init_t * p_ble_bas_c_init)
VERIFY_PARAM_NOT_NULL(p_ble_bas_c);
VERIFY_PARAM_NOT_NULL(p_ble_bas_c_init);
ble_uuid_t bas_uuid;
bas_uuid.type = BLE_UUID_TYPE_BLE;
bas_uuid.uuid = BLE_UUID_BATTERY_SERVICE;
p_ble_bas_c->conn_handle = BLE_CONN_HANDLE_INVALID;
p_ble_bas_c->peer_bas_db.bl_cccd_handle = BLE_GATT_HANDLE_INVALID;
p_ble_bas_c->peer_bas_db.bl_handle = BLE_GATT_HANDLE_INVALID;
p_ble_bas_c->evt_handler = p_ble_bas_c_init->evt_handler;
p_ble_bas_c->error_handler = p_ble_bas_c_init->error_handler;
p_ble_bas_c->p_gatt_queue = p_ble_bas_c_init->p_gatt_queue;
return ble_db_discovery_evt_register(&bas_uuid);
/**@brief Function for handling the Disconnected event received from the SoftDevice.
* @details This function checks whether the disconnect event is happening on the link
* associated with the current instance of the module. If the event is happening,
* the function sets the instance's conn_handle to invalid.
static void on_disconnected(ble_bas_c_t * p_ble_bas_c, const ble_evt_t * p_ble_evt)
if (p_ble_bas_c->conn_handle == p_ble_evt->evt.gap_evt.conn_handle)
void ble_bas_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
if ((p_ble_evt == NULL) || (p_context == NULL))
return;
ble_bas_c_t * p_ble_bas_c = (ble_bas_c_t *)p_context;
case BLE_GATTC_EVT_HVX:
on_hvx(p_ble_bas_c, p_ble_evt);
case BLE_GATTC_EVT_READ_RSP:
on_read_rsp(p_ble_bas_c, p_ble_evt);
on_disconnected(p_ble_bas_c, p_ble_evt);
uint32_t ble_bas_c_bl_notif_enable(ble_bas_c_t * p_ble_bas_c)
if (p_ble_bas_c->conn_handle == BLE_CONN_HANDLE_INVALID)
return cccd_configure(p_ble_bas_c, true);
uint32_t ble_bas_c_bl_read(ble_bas_c_t * p_ble_bas_c)
bas_c_req.type = NRF_BLE_GQ_REQ_GATTC_READ;
bas_c_req.params.gattc_read.handle = p_ble_bas_c->peer_bas_db.bl_handle;
uint32_t ble_bas_c_handles_assign(ble_bas_c_t * p_ble_bas_c,
uint16_t conn_handle,
ble_bas_c_db_t * p_peer_handles)
p_ble_bas_c->conn_handle = conn_handle;
if (p_peer_handles != NULL)
p_ble_bas_c->peer_bas_db = *p_peer_handles;
return nrf_ble_gq_conn_handle_register(p_ble_bas_c->p_gatt_queue, conn_handle);
#endif // NRF_MODULE_ENABLED(BLE_BAS_C)
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* @brief BLE Heart Rate Collector application main file.
* This file contains the source code for a sample heart rate collector.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_util.h"
#include "app_error.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "ble_hrs_c.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_log_ctrl.h"
#include "nrf_ble_scan.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_SOC_OBSERVER_PRIO 1 /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
#define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 1 /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size in octets. */
#define SCAN_DURATION_WITELIST 3000 /**< Duration of the scanning in units of 10 milliseconds. */
#define TARGET_UUID BLE_UUID_HEART_RATE_SERVICE /**< Target device uuid that application is looking for. */
/**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
#define UUID16_EXTRACT(DST, SRC) \
do \
(*(DST)) = (SRC)[1]; \
(*(DST)) <<= 8; \
(*(DST)) |= (SRC)[0]; \
} while (0)
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
BLE_HRS_C_DEF(m_hrs_c); /**< Structure used to identify the heart rate client module. */
BLE_BAS_C_DEF(m_bas_c); /**< Structure used to identify the Battery Service client module. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance. */
static uint16_t m_conn_handle; /**< Current connection handle. */
static bool m_whitelist_disabled; /**< True if whitelist has been temporarily disabled. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
.active = 0x01,
#if (NRF_SD_BLE_API_VERSION > 7)
.interval_us = NRF_BLE_SCAN_SCAN_INTERVAL * UNIT_0_625_MS,
.window_us = NRF_BLE_SCAN_SCAN_WINDOW * UNIT_0_625_MS,
#else
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
#endif // (NRF_SD_BLE_API_VERSION > 7)
.filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
.timeout = SCAN_DURATION_WITELIST,
.scan_phys = BLE_GAP_PHY_1MBPS,
/**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
* if these are set to empty strings, the UUIDs defined below will be used
static char const m_target_periph_name[] = ""; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
static bool is_connect_per_addr = false; /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
static ble_gap_addr_t const m_target_periph_addr =
/* Possible values for addr_type:
BLE_GAP_ADDR_TYPE_PUBLIC,
BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
.addr = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}
static void scan_start(void);
/**@brief Function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Heart Rate Service Client and Battery Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
// Bonds are deleted. Start scanning.
scan_start();
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
ret_code_t err_code;
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Nordic_HRM Peripheral is Connected.");
// Discover peer's services.
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
scan_start();
} break;
NRF_LOG_INFO("Disconnected, reason 0x%x.",
p_gap_evt->params.disconnected.reason);
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
case BLE_GAP_EVT_AUTH_KEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
case BLE_GAP_EVT_AUTH_STATUS:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
p_ble_evt->evt.gap_evt.params.auth_status.bonded,
p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
/**@brief SoftDevice SoC event handler.
* @param[in] evt_id SoC event.
* @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
switch (evt_id)
case NRF_EVT_FLASH_OPERATION_SUCCESS:
/* fall through */
case NRF_EVT_FLASH_OPERATION_ERROR:
if (m_memory_access_in_progress)
m_memory_access_in_progress = false;
scan_start();
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
// Register handlers for BLE and SoC events.
NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/** @brief Clear bonding information from persistent storage
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
/**@brief Function for disabling the use of whitelist for scanning.
static void whitelist_disable(void)
if (!m_whitelist_disabled)
NRF_LOG_INFO("Whitelist temporarily disabled.");
m_whitelist_disabled = true;
nrf_ble_scan_stop();
scan_start();
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
whitelist_disable();
/**@brief Heart Rate Collector Handler.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
switch (p_hrs_c_evt->evt_type)
case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_DEBUG("Heart rate service discovered.");
NRF_LOG_INFO("Heart rate service discovered.");
err_code = ble_hrs_c_handles_assign(p_hrs_c,
p_hrs_c_evt->conn_handle,
&p_hrs_c_evt->params.peer_db);
// Initiate bonding.
err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
if (err_code != NRF_ERROR_BUSY)
// Heart rate service discovered. Enable notification of Heart Rate Measurement.
err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
} break;
case BLE_HRS_C_EVT_HRM_NOTIFICATION:
NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0)
uint32_t rr_avg = 0;
for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++)
rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
} break;
/**@brief Battery level Collector Handler.
static void bas_c_evt_handler(ble_bas_c_t * p_bas_c, ble_bas_c_evt_t * p_bas_c_evt)
switch (p_bas_c_evt->evt_type)
case BLE_BAS_C_EVT_DISCOVERY_COMPLETE:
err_code = ble_bas_c_handles_assign(p_bas_c,
p_bas_c_evt->conn_handle,
&p_bas_c_evt->params.bas_db);
// Battery service discovered. Enable notification of Battery Level.
NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
NRF_LOG_INFO("Battery Service discovered. Reading battery level.");
err_code = ble_bas_c_bl_read(p_bas_c);
NRF_LOG_DEBUG("Enabling Battery Level Notification.");
err_code = ble_bas_c_bl_notif_enable(p_bas_c);
} break;
case BLE_BAS_C_EVT_BATT_NOTIFICATION:
NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
case BLE_BAS_C_EVT_BATT_READ_RESP:
NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
* @brief Heart rate collector initialization.
static void hrs_c_init(void)
ble_hrs_c_init_t hrs_c_init_obj;
hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
hrs_c_init_obj.error_handler = service_error_handler;
hrs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
* @brief Battery level collector initialization.
static void bas_c_init(void)
ble_bas_c_init_t bas_c_init_obj;
bas_c_init_obj.evt_handler = bas_c_evt_handler;
bas_c_init_obj.error_handler = service_error_handler;
bas_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_bas_c_init(&m_bas_c, &bas_c_init_obj);
* @brief Database discovery collector initialization.
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(db_init));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Retrieve a list of peer manager peer IDs.
* @param[inout] p_peers The buffer where to store the list of peer IDs.
* @param[inout] p_size In: The size of the @p p_peers buffer.
* Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
pm_peer_id_t peer_id;
uint32_t peers_to_copy;
peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
*p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
*p_size = 0;
while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
p_peers[(*p_size)++] = peer_id;
peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load()
ret_code_t ret;
pm_peer_id_t peers[8];
uint32_t peer_cnt;
memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
// Load all peers from flash and whitelist them.
peer_list_get(peers, &peer_cnt);
ret = pm_whitelist_set(peers, peer_cnt);
APP_ERROR_CHECK(ret);
// Setup the device identies list.
// Some SoftDevices do not support this feature.
ret = pm_device_identities_list_set(peers, peer_cnt);
if (ret != NRF_ERROR_NOT_SUPPORTED)
static void on_whitelist_req(void)
// Whitelist buffers.
ble_gap_addr_t whitelist_addrs[8];
ble_gap_irk_t whitelist_irks[8];
memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
memset(whitelist_irks, 0x00, sizeof(whitelist_irks));
uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
uint32_t irk_cnt = (sizeof(whitelist_irks) / sizeof(ble_gap_irk_t));
// Reload the whitelist and whitelist all peers.
whitelist_load();
// Get the whitelist previously set using pm_whitelist_set().
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
if (((addr_cnt == 0) && (irk_cnt == 0)) ||
(m_whitelist_disabled))
// Don't use whitelist.
err_code = nrf_ble_scan_params_set(&m_scan, NULL);
/**@brief Function to start scanning.
if (nrf_fstorage_is_busy(NULL))
m_memory_access_in_progress = true;
return;
NRF_LOG_INFO("Start Scannig for Nordic_HRM Peripheral");
err_code = nrf_ble_scan_start(&m_scan);
err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for initializing the power management module. */
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED:
NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
p_evt->conn_handle,
p_evt->params.att_mtu_effective);
} break;
case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED:
NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
p_evt->conn_handle,
p_evt->params.data_length);
} break;
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
on_whitelist_req();
m_whitelist_disabled = false;
} break;
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
/**@brief Function for initialization scanning and setting filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.p_scan_param = &m_scan_param;
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
ble_uuid_t uuid =
.uuid = TARGET_UUID,
.type = BLE_UUID_TYPE_BLE,
err_code = nrf_ble_scan_filter_set(&m_scan,
SCAN_UUID_FILTER,
&uuid);
if (strlen(m_target_periph_name) != 0)
SCAN_NAME_FILTER,
m_target_periph_name);
if (is_connect_per_addr)
SCAN_ADDR_FILTER,
m_target_periph_addr.addr);
err_code = nrf_ble_scan_filters_enable(&m_scan,
NRF_BLE_SCAN_ALL_FILTER,
false);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
err_code = nrf_ble_lesc_request_handler();
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
/**@brief Function for starting a scan, or instead trigger it from peer manager (after
* deleting bonds).
* @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
void scanning_start(bool * p_erase_bonds)
// Start scanning for peripherals and initiate connection
// with devices that advertise GATT Service UUID.
if (*p_erase_bonds == true)
// Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
delete_bonds();
scan_start();
bool erase_bonds;
// Initialize.
log_init();
timer_init();
power_management_init();
ble_stack_init();
gatt_init();
peer_manager_init();
db_discovery_init();
hrs_c_init();
bas_c_init();
scan_init();
// Start execution.
NRF_LOG_INFO("Programming Execution Started");
scanning_start(&erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
As per your guidance I was trying to use Battery Service from Above said GATT Service. but could not able to read.
I have used one nRF52840-DK board with ble Peripheral --> ble_app_hrs example
and second nRF52840-DK board with ble Central--> ble_app_hrs_c example.
I am trying to read battery level of Peripheral device in to the central ble_app_hrs_c example.
but with using nRF log info I can see that my BLE_DB_DISCOVERY_ERROR instead of Discovery complete. See Image.
What you suggest here to make it happen ?
I have attached both main.c and ble_bas_c.c
What you have here is basically the BLE Heart Rate Collector Example with some minor changes to logging that does not change the behavior. When I test your modifications against a DK with an unmodified Heart Rate Application it works as expected, so I suspect you did some changes there that broke it.
So you mean are you able to connect BLE_DB_DISCOVERY_COMPLETE at your end ? and read the battery Level ?
Yes
