AWS FOTA Update inconsistent
Hi dev team,
I am using a Thingy91 device along with the NCS v1.5.1.
I used the AWS FOTA example for firmware upgrades and I integrated the example in my code.
The FOTA update works for me but sometimes it hangs. It works for me once and the next time it hangs and says job rejected.
I am attaching the log of the behavior I am seeing. The FOTA works the first time and then when I try to do a FOTA once again, it says job rejected.
FOTA updates once, fails once.txt
I also tried using the AWS_FOTA sample and experienced the same behavior. Can anyone in the team who has used FOTA through AWS try and check this out ?
Adeel.
  • Hi Marte,
    Are you experiencing the VersionMismatch issue if you use a clean version of the AWS FOTA sample, or only with your own application?
    I only experience it with my application. Could it be something related to my version number in my Job document ?
    In this case you can for example disconnect if you do not receive any messages on this topic.
    Where could I call the mqtt_disconnect() function to do this exactly in the AWS_FOTA sample  ? I would like to it in such a way that I disconnect if there is no message on the topic. Can you please help me with this ?
    Adeel.
    The job version that version mismatch reacts to is not the same as fwversion, but the version of the job execution. This will be the field "versionNumber" in a JobExecution object, which can for example look like:
    "execution" : {
        "jobId" : "022",
        "thingName" : "MyThing",
        "jobDocument" : "< contents of job document >",
        "status" : "IN_PROGRESS",
        "queuedAt" : 1489096123309,
        "lastUpdatedAt" : 1489096123309,
        "versionNumber" : 1,
        "executionNumber" : 1234567890
    "clientToken" : "client-1",
    "timestamp" : 1489088524284,
    You can read more about job executions here and here. I have not been able to figure out what might cause this error, as there is not much information about it unfortunately.
    The device will subscribe to the topic, and if it receives a message it will go into the case MQTT_EVT_PUBLISH in mqtt_evt_handler(). It does not check the topic for messages and see if it is empty or if there is a message there. When it subscribes to a topic it will only receive a message when one is sent, and that is when it will react and handle that message. If you want to disconnect if it does not receive any messages on that topic for some time you can create some sort of timer or timeout, and then disconnect if it times out without any new messages being received on the topic.
    Marte
  • Hi Marte,
    Thanks for clarifying this for me. I actually am no longer getting the Version Mismatch error.
    I am getting a different error which i will try to briefly explain to get some inputs from you:
    I am actually connecting to a different server and subscribing to it via MQTT and getting a command from the server. The command is received by the device when it subscribes to the server. I try to initiate my FOTA update through this command (FOTA). When I do it, the FOTA works perfectly once and updates. When I try to do it the next time, I get a Job rejected error inspite of having a job available in the AWS IoT.
    I get an error that I think is mostly due a conflict with the MQTT payload buf.
    2021-05-12T12:05:11.478Z INFO Application data folder: C:\Users\adeel\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2021-05-12T12:05:11.494Z VERBOSE Could not fetch serial number for serial port at COM3
    2021-05-12T12:05:11.494Z VERBOSE Could not fetch serial number for serial port at COM1
    2021-05-12T12:05:11.578Z DEBUG App pc-nrfconnect-linkmonitor v1.1.10 official
    2021-05-12T12:05:11.579Z DEBUG App path: C:\Users\adeel\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2021-05-12T12:05:11.579Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
    2021-05-12T12:05:11.579Z DEBUG nRFConnect path: C:\Users\adeel\AppData\Local\Programs\nrfconnect\resources\app.asar
    2021-05-12T12:05:11.580Z DEBUG HomeDir: C:\Users\adeel
    2021-05-12T12:05:11.580Z DEBUG TmpDir: C:\Users\adeel\AppData\Local\Temp
    2021-05-12T12:05:30.576Z INFO Modem port is opened
    2021-05-12T12:05:30.582Z DEBUG modem >> AT+CFUN?
    2021-05-12T12:05:30.608Z DEBUG modem << +CFUN: 1
    2021-05-12T12:05:30.611Z DEBUG modem << OK
    2021-05-12T12:05:30.628Z DEBUG modem >> AT+CGSN=1
    2021-05-12T12:05:30.637Z DEBUG modem << +CGSN: "352656101119801"
    2021-05-12T12:05:30.639Z DEBUG modem << OK
    2021-05-12T12:05:30.642Z DEBUG modem >> AT+CGMI
    2021-05-12T12:05:30.650Z DEBUG modem << Nordic Semiconductor ASA
    2021-05-12T12:05:30.652Z DEBUG modem << OK
    2021-05-12T12:05:30.659Z DEBUG modem >> AT+CGMM
    2021-05-12T12:05:30.666Z DEBUG modem << nRF9160-SICA
    2021-05-12T12:05:30.668Z DEBUG modem << OK
    2021-05-12T12:05:30.670Z DEBUG modem >> AT+CGMR
    2021-05-12T12:05:30.678Z DEBUG modem << mfw_nrf9160_1.2.2-FOTA-TEST
    2021-05-12T12:05:30.680Z DEBUG modem << OK
    2021-05-12T12:05:30.681Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.2.2-FOTA-TEST] SerNr: 352656101119801
    2021-05-12T12:05:30.683Z DEBUG modem >> AT+CEMODE?
    2021-05-12T12:05:30.690Z DEBUG modem << +CEMODE: 0
    2021-05-12T12:05:30.692Z DEBUG modem << OK
    2021-05-12T12:05:30.699Z DEBUG modem >> AT%XCBAND=?
    2021-05-12T12:05:30.711Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)
    2021-05-12T12:05:30.715Z DEBUG modem << OK
    2021-05-12T12:05:30.730Z DEBUG modem >> AT+CMEE?
    2021-05-12T12:05:30.737Z DEBUG modem << +CMEE: 0
    2021-05-12T12:05:30.739Z DEBUG modem << OK
    2021-05-12T12:05:30.742Z DEBUG modem >> AT+CMEE=1
    2021-05-12T12:05:30.749Z DEBUG modem << OK
    2021-05-12T12:05:30.755Z DEBUG modem >> AT+CNEC?
    2021-05-12T12:05:30.763Z DEBUG modem << +CNEC: 0
    2021-05-12T12:05:30.764Z DEBUG modem << OK
    2021-05-12T12:05:30.768Z DEBUG modem >> AT+CNEC=24
    2021-05-12T12:05:30.775Z DEBUG modem << OK
    2021-05-12T12:05:30.779Z DEBUG modem >> AT+CGEREP?
    2021-05-12T12:05:30.789Z DEBUG modem << +CGEREP: 0,0
    2021-05-12T12:05:30.794Z DEBUG modem << OK
    2021-05-12T12:05:30.798Z DEBUG modem >> AT+CGDCONT?
    2021-05-12T12:05:30.805Z DEBUG modem << OK
    2021-05-12T12:05:30.808Z DEBUG modem >> AT+CGACT?
    2021-05-12T12:05:30.814Z DEBUG modem << OK
    2021-05-12T12:05:30.819Z DEBUG modem >> AT+CGEREP=1
    2021-05-12T12:05:30.826Z DEBUG modem << OK
    2021-05-12T12:05:30.830Z DEBUG modem >> AT+CIND=1,1,1
    2021-05-12T12:05:30.836Z DEBUG modem << OK
    2021-05-12T12:05:30.841Z DEBUG modem >> AT+CEREG=5
    2021-05-12T12:05:30.855Z DEBUG modem << OK
    2021-05-12T12:05:30.859Z DEBUG modem >> AT+CEREG?
    2021-05-12T12:05:30.872Z DEBUG modem << +CEREG: 5,4,"FFFE","FFFFFFFF",9,0,0,"00000000","00000000"
    2021-05-12T12:05:30.873Z DEBUG modem << OK
    2021-05-12T12:05:30.879Z DEBUG modem >> AT%CESQ=1
    2021-05-12T12:05:30.887Z DEBUG modem << OK
    2021-05-12T12:05:30.891Z DEBUG modem >> AT+CESQ
    2021-05-12T12:05:30.900Z DEBUG modem << +CESQ: 99,99,255,255,255,255
    2021-05-12T12:05:30.902Z DEBUG modem << OK
    2021-05-12T12:05:30.907Z DEBUG modem >> AT%XSIM=1
    2021-05-12T12:05:30.913Z DEBUG modem << OK
    2021-05-12T12:05:30.919Z DEBUG modem >> AT%XSIM?
    2021-05-12T12:05:30.926Z DEBUG modem << %XSIM: 0
    2021-05-12T12:05:30.927Z DEBUG modem << OK
    2021-05-12T12:05:33.879Z DEBUG modem << meter_modem_data_init()...
    2021-05-12T12:05:33.880Z DEBUG modem << LTE connection established!
    2021-05-12T12:05:33.911Z DEBUG modem << E: Link data not obtained: 20 -22
    2021-05-12T12:05:33.913Z DEBUG modem << E: Network data not obtained: -22
    2021-05-12T12:05:33.914Z DEBUG modem << Modem Infos:
    2021-05-12T12:05:33.915Z DEBUG modem <<          IP: 10.205.85.10
    2021-05-12T12:05:33.915Z DEBUG modem <<     ue_mode: 0
    2021-05-12T12:05:33.916Z DEBUG modem <<    lte_mode: 0
    2021-05-12T12:05:33.916Z DEBUG modem <<    current_band: 8
    2021-05-12T12:05:33.917Z DEBUG modem <<    area_code: 52015
    2021-05-12T12:05:33.918Z DEBUG modem <<    operator: 26201
    2021-05-12T12:05:33.918Z DEBUG modem <<    dev imei: 352656101119801
    2021-05-12T12:05:33.918Z DEBUG modem <<    modem_firmware:
    2021-05-12T12:05:34.430Z DEBUG modem << DATE_TIME: got time from NTP.
    2021-05-12T12:05:34.432Z DEBUG modem << Initialize cJSON...done!
    2021-05-12T12:05:34.434Z DEBUG modem <<   Using cJSON ver. 1.7.12
    2021-05-12T12:05:44.440Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:05:44.441Z DEBUG modem << work_handler_collect_data started!
    2021-05-12T12:05:44.948Z DEBUG modem << Getting latest time...done!
    2021-05-12T12:05:44.949Z DEBUG modem << Reading out bosch sensor...done!
    2021-05-12T12:05:44.959Z DEBUG modem << Reading out modem info...done!
    2021-05-12T12:05:46.992Z DEBUG modem << Reading out Teros12 sensor...done!
    2021-05-12T12:05:46.993Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:05:46.997Z DEBUG modem << Measured data:
    2021-05-12T12:05:46.999Z DEBUG modem <<        Timer: 2021-05-12 12:05:44
    2021-05-12T12:05:47.000Z DEBUG modem <<  #msg queued: 0
    2021-05-12T12:05:47.002Z DEBUG modem <<  Temperature: 27.000 degC
    2021-05-12T12:05:47.003Z DEBUG modem <<     Pressure: 94.785
    2021-05-12T12:05:47.004Z DEBUG modem <<     Humidity: 28.921
    2021-05-12T12:05:47.005Z DEBUG modem <<     SoilTemp: 0.000 degC
    2021-05-12T12:05:47.006Z DEBUG modem <<    VolWaterC: 0.000
    2021-05-12T12:05:47.006Z DEBUG modem <<   Modem bat.: 4.394 V
    2021-05-12T12:05:47.007Z DEBUG modem <<   Current band: 8
    2021-05-12T12:05:47.008Z DEBUG modem <<         RSRP: -141
    2021-05-12T12:05:47.008Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:05:49.442Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:05:49.444Z DEBUG modem << work_handler_send_data started!
    2021-05-12T12:05:49.445Z DEBUG modem << Length of message queue : 1
    2021-05-12T12:05:49.944Z DEBUG modem << mqtt_meter_init running...
    2021-05-12T12:05:51.632Z DEBUG modem << IPv4 Address 13.80.240.194
    2021-05-12T12:05:51.633Z DEBUG modem << MQTT Meter client id: Meter
    2021-05-12T12:05:51.730Z DEBUG modem << Using device imei: 352656101119801
    2021-05-12T12:05:51.731Z DEBUG modem << mqtt_meter_init finished!
    2021-05-12T12:05:51.735Z DEBUG modem << Starting to send 1 messages:
    2021-05-12T12:05:51.737Z DEBUG modem << Need to send 1 more messages:
    2021-05-12T12:05:51.832Z DEBUG modem << [mqtt_evt_handler:179] MQTT client connected!
    2021-05-12T12:05:51.837Z DEBUG modem << Subscribing to: sensorstest1/nrf352656101119801/command
    2021-05-12T12:05:51.922Z DEBUG modem << [mqtt_evt_handler:287] SUBACK packet id: 1234
    2021-05-12T12:05:52.027Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 40847
    2021-05-12T12:05:52.138Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 20109
    2021-05-12T12:05:52.250Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 4352
    2021-05-12T12:05:52.370Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 58206
    2021-05-12T12:05:52.482Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 51472
    2021-05-12T12:05:52.593Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 60475
    2021-05-12T12:05:52.697Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 41695
    2021-05-12T12:05:52.852Z DEBUG modem << [mqtt_evt_handler:197] MQTT client disconnected 0
    2021-05-12T12:05:52.857Z DEBUG modem << All messages have been send!
    2021-05-12T12:06:44.437Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:06:44.439Z DEBUG modem << work_handler_collect_data started!
    2021-05-12T12:06:44.946Z DEBUG modem << Getting latest time...done!
    2021-05-12T12:06:44.946Z DEBUG modem << Reading out bosch sensor...done!
    2021-05-12T12:06:44.957Z DEBUG modem << Reading out modem info...done!
    2021-05-12T12:06:46.989Z DEBUG modem << Reading out Teros12 sensor...done!
    2021-05-12T12:06:46.990Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:06:46.995Z DEBUG modem << Measured data:
    2021-05-12T12:06:46.996Z DEBUG modem <<        Timer: 2021-05-12 12:06:44
    2021-05-12T12:06:46.998Z DEBUG modem <<  #msg queued: 0
    2021-05-12T12:06:46.999Z DEBUG modem <<  Temperature: 27.020 degC
    2021-05-12T12:06:46.999Z DEBUG modem <<     Pressure: 94.783
    2021-05-12T12:06:47.000Z DEBUG modem <<     Humidity: 29.003
    2021-05-12T12:06:47.000Z DEBUG modem <<     SoilTemp: 0.000 degC
    2021-05-12T12:06:47.001Z DEBUG modem <<    VolWaterC: 0.000
    2021-05-12T12:06:47.001Z DEBUG modem <<   Modem bat.: 4.394 V
    2021-05-12T12:06:47.001Z DEBUG modem <<   Current band: 8
    2021-05-12T12:06:47.002Z DEBUG modem <<         RSRP: -100
    2021-05-12T12:06:47.002Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:07:44.435Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:07:44.436Z DEBUG modem << work_handler_collect_data started!
    2021-05-12T12:07:44.944Z DEBUG modem << Getting latest time...done!
    2021-05-12T12:07:44.945Z DEBUG modem << Reading out bosch sensor...done!
    2021-05-12T12:07:44.955Z DEBUG modem << Reading out modem info...done!
    2021-05-12T12:07:46.987Z DEBUG modem << Reading out Teros12 sensor...done!
    2021-05-12T12:07:46.988Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:07:46.994Z DEBUG modem << Measured data:
    2021-05-12T12:07:46.995Z DEBUG modem <<        Timer: 2021-05-12 12:07:44
    2021-05-12T12:07:46.996Z DEBUG modem <<  #msg queued: 1
    2021-05-12T12:07:46.997Z DEBUG modem <<  Temperature: 26.640 degC
    2021-05-12T12:07:46.997Z DEBUG modem <<     Pressure: 94.783
    2021-05-12T12:07:46.998Z DEBUG modem <<     Humidity: 29.384
    2021-05-12T12:07:46.998Z DEBUG modem <<     SoilTemp: 0.000 degC
    2021-05-12T12:07:46.999Z DEBUG modem <<    VolWaterC: 0.000
    2021-05-12T12:07:47.000Z DEBUG modem <<   Modem bat.: 4.394 V
    2021-05-12T12:07:47.001Z DEBUG modem <<   Current band: 8
    2021-05-12T12:07:47.001Z DEBUG modem <<         RSRP: -100
    2021-05-12T12:07:47.002Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:07:49.438Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:07:49.439Z DEBUG modem << work_handler_send_data started!
    2021-05-12T12:07:49.445Z DEBUG modem << Length of message queue : 2
    2021-05-12T12:07:49.940Z DEBUG modem << mqtt_meter_init running...
    2021-05-12T12:07:49.954Z DEBUG modem << IPv4 Address 13.80.240.194
    2021-05-12T12:07:49.955Z DEBUG modem << MQTT Meter client id: Meter
    2021-05-12T12:07:52.409Z DEBUG modem << Using device imei: 352656101119801
    2021-05-12T12:07:52.411Z DEBUG modem << mqtt_meter_init finished!
    2021-05-12T12:07:52.417Z DEBUG modem << Starting to send 2 messages:
    2021-05-12T12:07:52.418Z DEBUG modem << Need to send 2 more messages:
    2021-05-12T12:07:52.511Z DEBUG modem << [mqtt_evt_handler:179] MQTT client connected!
    2021-05-12T12:07:52.512Z DEBUG modem << Subscribing to: sensorstest1/nrf352656101119801/command
    2021-05-12T12:07:52.634Z DEBUG modem << MQTT PUBLISH result=0 len=4
    2021-05-12T12:07:52.635Z DEBUG modem << Received MQTT Buf:
    2021-05-12T12:07:52.635Z DEBUG modem << FOTA
    2021-05-12T12:07:52.636Z DEBUG modem << Payload buf is : FOTA
    2021-05-12T12:07:52.736Z DEBUG modem << [mqtt_evt_handler:287] SUBACK packet id: 1234
    2021-05-12T12:07:52.841Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 16585
    2021-05-12T12:07:52.946Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 3144
    2021-05-12T12:07:53.066Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 51224
    2021-05-12T12:07:53.169Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 56557
    2021-05-12T12:07:53.281Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 11750
    2021-05-12T12:07:53.394Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 59118
    2021-05-12T12:07:53.548Z DEBUG modem << Need to send 1 more messages:
    2021-05-12T12:07:53.557Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 48968
    2021-05-12T12:07:53.610Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 29619
    2021-05-12T12:07:53.721Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 18647
    2021-05-12T12:07:53.826Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 44297
    2021-05-12T12:07:53.936Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 56929
    2021-05-12T12:07:54.048Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 63531
    2021-05-12T12:07:54.161Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 22827
    2021-05-12T12:07:54.266Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 43565
    2021-05-12T12:07:54.386Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 43866
    2021-05-12T12:07:54.540Z DEBUG modem << [mqtt_evt_handler:197] MQTT client disconnected 0
    2021-05-12T12:07:54.542Z DEBUG modem << All messages have been send!
    2021-05-12T12:08:02.643Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:08:02.644Z DEBUG modem << work_handler_fota started!
    2021-05-12T12:08:03.147Z DEBUG modem << Initializing MQTT AWS broker via mqtt_aws_init()...
    2021-05-12T12:08:05.267Z DEBUG modem << IPv4 Address 18.159.13.101
    2021-05-12T12:08:05.268Z DEBUG modem << MQTT AWS client id: nrf-testing1
    2021-05-12T12:08:11.033Z DEBUG modem << Initializing aws_fota_init()...
    2021-05-12T12:08:11.274Z DEBUG modem << [mqtt_evt_handler:179] MQTT client connected!
    2021-05-12T12:08:11.686Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 55247
    2021-05-12T12:08:12.034Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 59550
    2021-05-12T12:09:12.291Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 16638
    2021-05-12T12:09:14.471Z DEBUG modem << I: Configuring socket timeout (30 s)
    2021-05-12T12:09:14.477Z DEBUG modem << I: Connecting to nrfbuc.s3.eu-central-1.amazonaws.com
    2021-05-12T12:09:14.796Z DEBUG modem << I: Downloading: app_update.bin [0]
    2021-05-12T12:09:14.803Z DEBUG modem << AWS_FOTA_EVT_START, job id = 3
    2021-05-12T12:09:14.805Z DEBUG modem << [mqtt_evt_handler:276] PUBACK packet id: 22132
    2021-05-12T12:09:14.807Z DEBUG modem << E: Job document update was rejected
    2021-05-12T12:09:14.808Z DEBUG modem << E: Job document update was rejected
    2021-05-12T12:09:14.846Z DEBUG modem << [mqtt_evt_handler:197] MQTT client disconnected 0
    2021-05-12T12:09:14.848Z DEBUG modem << Disconnecting MQTT client again again...
    2021-05-12T12:09:14.849Z DEBUG modem << E: Error -5 when getting the payload
    2021-05-12T12:09:14.849Z DEBUG modem << aws_fota_mqtt_evt_handler: Failed! -5
    2021-05-12T12:09:14.851Z DEBUG modem << [mqtt_evt_handler:210] MQTT PUBLISH result=0 len=177
    2021-05-12T12:09:14.852Z DEBUG modem << mqtt_read_publish_payload: Failed! -5
    2021-05-12T12:09:14.852Z DEBUG modem << Disconnecting MQTT client...
    2021-05-12T12:09:14.852Z DEBUG modem << Could not disconnect: -128
    2021-05-12T12:09:14.853Z DEBUG modem << Received AWS Buf: {"state":{"reported":{"nrfcloud__dfu_v1__app_v":"v1.0.0"}}}
    2021-05-12T12:09:14.854Z DEBUG modem << ERROR: mqtt_live -128
    2021-05-12T12:09:14.855Z DEBUG modem << mqtt_aws_run failed!
    2021-05-12T12:09:14.856Z DEBUG modem << ----------------------------------------------------------------
    2021-05-12T12:09:14.857Z DEBUG modem << work_handler_collect_data started!
    2021-05-12T12:09:15.348Z DEBUG modem << Getting latest time...done!
    2021-05-12T12:09:15.359Z DEBUG modem << Reading out bosch sensor...done!
    2021-05-12T12:09:15.360Z DEBUG modem << Reading out modem info...done!
    2021-05-12T12:09:16.153Z DEBUG modem << Reading out Teros12 sensor...I: Downloaded 2048/234807 bytes (0%)
    2021-05-12T12:09:16.162Z DEBUG modem << I: 2 Sectors of 4096 bytes
    2021-05-12T12:09:16.163Z DEBUG modem << I: alloc wra: 0, ff0
    2021-05-12T12:09:16.165Z DEBUG modem << I: data wra: 0, 0
    2021-05-12T12:09:17.390Z DEBUG modem << done!
    2021-05-12T12:09:17.391Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:09:17.398Z DEBUG modem << Measured data:
    2021-05-12T12:09:17.399Z DEBUG modem <<        Timer: 2021-05-12 12:09:14
    2021-05-12T12:09:17.400Z DEBUG modem <<  #msg queued: 0
    2021-05-12T12:09:17.400Z DEBUG modem <<  Temperature: 26.230 degC
    2021-05-12T12:09:17.401Z DEBUG modem <<     Pressure: 94.785
    2021-05-12T12:09:17.401Z DEBUG modem <<     Humidity: 30.000
    2021-05-12T12:09:17.401Z DEBUG modem <<     SoilTemp: 0.000 degC
    2021-05-12T12:09:17.402Z DEBUG modem <<    VolWaterC: 0.000
    2021-05-12T12:09:17.402Z DEBUG modem <<   Modem bat.: 4.394 V
    2021-05-12T12:09:17.402Z DEBUG modem <<   Current band: 8
    2021-05-12T12:09:17.403Z DEBUG modem <<         RSRP: -99
    2021-05-12T12:09:17.403Z DEBUG modem << ++++++++++++++++++++++++++++++++++++++++++++
    2021-05-12T12:09:20.008Z DEBUG modem << I: Downloaded 4096/234807 bytes (1%)
    Could you help me understand where the issue could be ? I have integrated the AWS_FOTA sample (for my FOTA updates) in my application along with the mqtt_simple application (for my MQTT data) as well.
    Adeel
  • Hi Adeel,
    I see you are getting errors -5 and -128. -5 is EIO (input/output error), and -128 is ENOTCONN (socket is not connected). In cellular examples, EIO can be returned if you are sending an AT command to the modem and the function failed to send the command, but I am not certain why you are getting that error in your case.
    Could you get a modem trace of when this happens and attach it here?
    Marte
  • Hi Marte,
    Sorry for the late reply. Actually the issue that I have noticed is that if I keep a job in queue before connecting to the AWS IoT, then the job is not picked up by the Thingy.
    However, if I create the job when the Thingy is subscribed to the AWS , then it works perfectly. So, as a work around for now, I am creating the job when I am subscribing to the FOTA and that works for now.
    What I am curious to see is why does the issue occur when the job is already created and queued in the Job section of AWS IoT:
    Also, could you let me know how to get the modem trace from the Link monitor ?
    Adeel.
