nrf 5340 for Bluetooth low energy
Hi!
This tutorial is just for current Measuring current. I want the same for latency with code.
I'm working with two nrf5340 for Bluetooth low energy and I want to measure latency value between those cards using oscilloscope. Is there any sample code that I can use to send data  and receive it in the other cord. I want to allow  one bin in the first nrf5340 to write data and a bin in the other nrf5340 to read this data.
2. I also want to measure RSSI. Is is possible to do that using the same method. I mean that I want to measure RSSI when the two cards are connected to each other.
Best regards
  • Try this
    static void scan_filter_match(struct bt_scan_device_info *device_info,
    			      struct bt_scan_filter_match *filter_match,
    			      bool connectable)
    	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
    LOG_INF("Filters matched. RSSI: %d, Address: %s connectable: %d",device_info->recv_info->rssi,
    		log_strdup(addr), connectable);
    The log will be printed in RTT.
