NFC doesn't work when the softdevice is enabled
I'm using the sdk v17.0.2 with softdevice s140 with a custom PCB shipping the nrf52840.
I'm facing an issue where I cannot enable NFC and softdevice at the same time.
When the NFC is enabled and the softdevice is not, the my tag can be read from an Android smartphone. But I soon I enable the softdevice (with nrf_sdh_enable_request), the tag cannot be read anymore.
There is my very simple example:
#include "nfc_ndef_msg.h"
#include "nfc_t2t_lib.h"
#include "nfc_text_rec.h"
#include <app_error.h>
#include <nrf_log.h>
#include <nrf_pwr_mgmt.h>
#include <nrf_sdh.h>
#include <string.h>
#define MAX_REC_COUNT 3 /**< Maximum records count. */
/* Text message in English with its language code. */
/** @snippet [NFC text usage_1] */
static const uint8_t en_payload[] = {
        'H', 'e', 'l', 'l', 'o', ' ', 'W', 'o', 'r', 'l', 'd', '!'};
static const uint8_t en_code[] = {'e', 'n'};
/* Buffer used to hold an NFC NDEF message. */
uint8_t m_ndef_msg_buf[256];
 * @brief Callback function for handling NFC events.
static void nfc_callback(void *p_context, nfc_t2t_event_t event, const uint8_t *p_data, size_t data_length) {
    (void) p_context;
    switch (event) {
        case NFC_T2T_EVENT_FIELD_ON:
            //bsp_board_led_on(BSP_BOARD_LED_0);
            NRF_LOG_INFO("NFC Field ON");
        case NFC_T2T_EVENT_FIELD_OFF:
            //bsp_board_led_off(BSP_BOARD_LED_0);
            NRF_LOG_INFO("NFC Field OFF");
static ret_code_t welcome_msg_encode(uint8_t *p_buffer, uint32_t *p_len) {
    /** @snippet [NFC text usage_2] */
    ret_code_t err_code;
    /* Create NFC NDEF text record description in English */
    NFC_NDEF_TEXT_RECORD_DESC_DEF(nfc_en_text_rec,
                                  UTF_8,
                                  en_code,
                                  sizeof(en_code),
                                  en_payload,
                                  sizeof(en_payload));
    /* Create NFC NDEF message description, capacity - MAX_REC_COUNT records */
    /** @snippet [NFC text usage_3] */
    NFC_NDEF_MSG_DEF(nfc_text_msg, MAX_REC_COUNT);
    /* Add text records to NDEF text message */
    /** @snippet [NFC text usage_4] */
    err_code = nfc_ndef_msg_record_add(&NFC_NDEF_MSG(nfc_text_msg),
                                       &NFC_NDEF_TEXT_RECORD_DESC(nfc_en_text_rec));
    VERIFY_SUCCESS(err_code);
    /** @snippet [NFC text usage_5] */
    err_code = nfc_ndef_msg_encode(&NFC_NDEF_MSG(nfc_text_msg),
                                   p_buffer,
                                   p_len);
    return err_code;
int main() {
    uint32_t len = sizeof(m_ndef_msg_buf);
    ret_code_t err_code = 0;
    // uncomment this and the NFC won't work anymore
    //Set up NFC
    err_code = nfc_t2t_setup(nfc_callback, NULL);
    //Encode welcome message
    err_code = welcome_msg_encode(m_ndef_msg_buf, &len);
    //Set created message as the NFC payload
    err_code = nfc_t2t_payload_set(m_ndef_msg_buf, len);
    //Start sensing NFC field
    err_code = nfc_t2t_emulation_start();
    NRF_LOG_INFO("in done...");
    while (1) {}
I found a similar issue here [1] but the fix doesn't work for me.
There is my linker script file:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  FLASH (rx) : ORIGIN = 0x27000, LENGTH = 0xc9000
  RAM (rwx) :  ORIGIN = 0x20002C00, LENGTH = 0x3d400
  uicr_bootloader_start_address (r) : ORIGIN = 0x10001014, LENGTH = 0x4
SECTIONS
  . = ALIGN(4);
  .uicr_bootloader_start_address :
    PROVIDE(__start_uicr_bootloader_start_address = .);
    KEEP(*(SORT(.uicr_bootloader_start_address*)))
    PROVIDE(__stop_uicr_bootloader_start_address = .);
  } > uicr_bootloader_start_address
SECTIONS
  . = ALIGN(4);
  .mem_section_dummy_ram :
  .log_dynamic_data :
    PROVIDE(__start_log_dynamic_data = .);
    KEEP(*(SORT(.log_dynamic_data*)))
    PROVIDE(__stop_log_dynamic_data = .);
  } > RAM
  .log_filter_data :
    PROVIDE(__start_log_filter_data = .);
    KEEP(*(SORT(.log_filter_data*)))
    PROVIDE(__stop_log_filter_data = .);
  } > RAM
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
} INSERT AFTER .data;
SECTIONS
  .mem_section_dummy_rom :
  .sdh_ble_observers :
    PROVIDE(__start_sdh_ble_observers = .);
    KEEP(*(SORT(.sdh_ble_observers*)))
    PROVIDE(__stop_sdh_ble_observers = .);
  } > FLASH
  .sdh_soc_observers :
    PROVIDE(__start_sdh_soc_observers = .);
    KEEP(*(SORT(.sdh_soc_observers*)))
    PROVIDE(__stop_sdh_soc_observers = .);
  } > FLASH
  .pwr_mgmt_data :
    PROVIDE(__start_pwr_mgmt_data = .);
    KEEP(*(SORT(.pwr_mgmt_data*)))
    PROVIDE(__stop_pwr_mgmt_data = .);
  } > FLASH
  .log_const_data :
    PROVIDE(__start_log_const_data = .);
    KEEP(*(SORT(.log_const_data*)))
    PROVIDE(__stop_log_const_data = .);
  } > FLASH
  .sdh_req_observers :
    PROVIDE(__start_sdh_req_observers = .);
    KEEP(*(SORT(.sdh_req_observers*)))
    PROVIDE(__stop_sdh_req_observers = .);
  } > FLASH
  .sdh_state_observers :
    PROVIDE(__start_sdh_state_observers = .);
    KEEP(*(SORT(.sdh_state_observers*)))
    PROVIDE(__stop_sdh_state_observers = .);
  } > FLASH
  .sdh_stack_observers :
    PROVIDE(__start_sdh_stack_observers = .);
    KEEP(*(SORT(.sdh_stack_observers*)))
    PROVIDE(__stop_sdh_stack_observers = .);
  } > FLASH
  .log_backends :
    PROVIDE(__start_log_backends = .);
    KEEP(*(SORT(.log_backends*)))
    PROVIDE(__stop_log_backends = .);
  } > FLASH
    .nrf_balloc :
    PROVIDE(__start_nrf_balloc = .);
    KEEP(*(.nrf_balloc))
    PROVIDE(__stop_nrf_balloc = .);
  } > FLASH
} INSERT AFTER .text
INCLUDE "nrf_common.ld"
I still do not understand if I need to register soc event with NRF_SDH_BLE_OBSERVER. Do the nfc_t2t handle it?
[1] https://devzone.nordicsemi.com/f/nordic-q-a/42141/nrf52832---nfc-stops-working-when-softdevice-is-enabled
Best,
Joël
