Controlling LTE link when using lwm2m carrier library
I'm trying to update our LTE connection library to use the LwM2M Carrier library to be prepared for carrier certification and I am not seeing any way to request that the modem move to the Online, Offline or Power Off states.
This is needed because I need to enable and disable the cellular radio to allow a Bluetooth radio to come on or off.  My current scheme uses the "lte_lc_connect" and "lte_lc_offline" functions from the "lte_link_control" library.
Is there a way to support this with how the LwM2M Carrier library works currently?
I am on NRF Connect SDK v1.5.0
Thank you!
  • Does the library have some kind of check with the carrier to see if it needs to go through the bootstrap/registration process?
    What I am seeing is the CEREG notification indicating the modem is attached causes the lwm2m library to immediately send out the LTE_READY event.
    I am trying to make sure my library can support the case where that CEREG notification instead causes the library to bootstrap/register and I should expect to see the LTE_READY event come out later.
  • Hi, and sorry for the late reply.
    Yes, the device keeps track of whether or not it needs to bootstrap.
    As long as you wait for the LTE_READY event after enabling LTE, you should be fine.
