FEM Support For Radio Test Example on custom board
I needed assistance to get the SKY66112-11 FEM working with the Radio Test Example, for certification testing (FCC, CE etc). I am using the NCS 1.5.1 SDK. I have followed the following link. I am using a custom board with nRF52832 SoC and it has the LFXO present.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_radio_fem.html#ug-radio-fem
I have made changes to the Configuration file of the project and added the device tree node as mentioned in the following forum post.
https://devzone.nordicsemi.com/f/nordic-q-a/74433/ncs-v1-5-1-pa-lna-support-for-bluetooth/306783#306783
Are there any addition changes required beside these to be done to get the FEM working? For instance I need to initialize the other 2 control gpios on the FEM which are of fixed logic levels, how should i go ahead adding those to the project?
Also are the any changes required to be done in the main application file itself of the Radio Test code to add support for the MPSL lib or just the project configuration settings are enough?
PS: Just wanted to mention that I tried running the Radio Test Example directly without adding the support for the FEM and that works as expected. So this tells me that the COM lines gpio changes I did in the dts file worked as it should and the crystal is fine too.
Thanks in Advance
