How to test the Radio on the hardware
We have a custom board designed based on N51822, CEAAB0 and we have used the chip antenna from ST BAL-NRF01D3. When we have flashed our proximity code to the device, we will not able to see the device advertising from the Master Control Panel. Kindly suggest, how to test the RF channel is working on our custom hardware? If possible share the step by step procedure from debugging from the hardware to the software.
  • For the CEAA version of the chip, I think the BAL-NRF02D3 might be required. To my knowledge, the BAL-NRF01D3 is reserved for the QFAA version of the chip.
    Nordic, can someone please comment if this is the case or not?
    Good luck, Jamie
    Good luck, Jamie
  • It's easier when you post unrelated questions separately instead of hijacking another one.
    The PAN item definitely applies, but only actions that require an external crystal that will be affected if you don't do this. If you have trouble integrating the workaround, please post a separate question.
    However, based on your description, it seems most likely that your low-frequency source is either wrong or does not work correctly. Did you check points 2 and 3 above?
    As for the softdevice function definitions, you will not find any source for them, since they're implemented inside the softdevice. You will however find the function declaration in the header file. With Keil, you can jump to this using "Go to reference".
    If you have further questions, I'd be happy if you could post new ones, preferably separating unrelated ones. :-)
