Device does not sleep after disconnection.
I’m trying to measure the current on NRF52840, SDK 17.0.2.
I have modified the HeartRate Measurement example’s advertising parameters as PLper my requirement.
I observe that while my device is advertising, the current is around 40 Micro Amps and the sleep current is 3.2 Micro Amps.
Once I connect and disconnect to the device using NrfConnect, the current is 30 Micro Amps and does not drop back to 3.2 Micro Amps.
Why is my device not going to sleep after disconnection?
Chitra
  • Here is the code.
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @example examples/ble_peripheral/ble_app_hrs/main.c
     * @brief Heart Rate Service Sample Application main file.
     * This file contains the source code for a sample application using the Heart Rate service
     * (and also Battery and Device Information services). This application uses the
     * @ref srvlib_conn_params module.
    #include "app_error.h"
    #include "app_timer.h"
    #include "ble.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "ble_dis.h"
    #include "ble_err.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "ble_hrs.h"
    #include "ble_srv_common.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_lesc.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdm.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "sensorsim.h"
    #include <stdint.h>
    #include <string.h>
    #include <stdlib.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME "Nordic_HRM"                /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL MSEC_TO_UNITS(500, UNIT_0_625_MS)
    #define APP_ADV_DURATION MSEC_TO_UNITS(10000, UNIT_10_MS)
    #define APP_BLE_CONN_CFG_TAG 1  /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(30000) /**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL 81                               /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL 100                              /**< Maximum simulated 7battery level. */
    #define BATTERY_LEVEL_INCREMENT 1                          /**< Increment between each simulated battery level measurement. */
    #define HEART_RATE_MEAS_INTERVAL APP_TIMER_TICKS(10000) /**< Heart rate measurement interval (ticks). */
    #define MIN_HEART_RATE 140                              /**< Minimum heart rate as returned by the simulated measurement function. */
    #define MAX_HEART_RATE 300                              /**< Maximum heart rate as returned by the simulated measurement function. */
    #define HEART_RATE_INCREMENT 10                         /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
    #define SLAVE_LATENCY 0                                    /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)   /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
    #define SEC_PARAM_BOND 1                               /**< Perform bonding. */
    #define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC 1                               /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
    #define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define TICK_CHAR_UUID 0x1701
    #define RATE_CHAR_UUID 0x1702
    #define OWN_CHAR_UUID 0x1703
    typedef struct ble_tag_s ble_tag_t;
    BLE_HRS_DEF(m_hrs);                       /**< Heart rate service instance. */
    BLE_BAS_DEF(m_bas);                       /**< Structure used to identify the battery service. */
    NRF_BLE_GATT_DEF(m_gatt);                 /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                   /**< Context for the Queued Write module.*/
    //BLE_ADVERTISING_DEF(m_advertising);       /**< Advertising module instance. */
    APP_TIMER_DEF(m_battery_timer_id);        /**< Battery timer. */
    APP_TIMER_DEF(m_heart_rate_timer_id);     /**< Heart rate measurement timer. */
    void ble_tag_on_ble_evt(ble_evt_t const *p_ble_evt, void *p_context);
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static bool m_rr_interval_enabled = true;                /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
    static volatile bool advertising_on = true;
    #define TAG_ADV_DATA_ID 0x01
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
    static bool advertising = false;
    static ble_advdata_manuf_data_t manuf_data;
    static ble_gap_adv_params_t adv_params;
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    static void idle_state_handle(void);
    #define TAG_UUID_BASE                               \
      { 0x91, 0xD1, 0xFA, 0x59, 0x93, 0x7D, 0x4E, 0xB2, \
        0xBB, 0x81, 0x36, 0xAF, 0x92, 0x21, 0xF0, 0x8E }
    #define TAG_SERVICE_UUID 0x1700
    static ble_gap_adv_data_t m_adv_data =
            .adv_data =
                    .p_data = m_enc_advdata,
                    .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX},
            .scan_rsp_data =
                    .p_data = m_enc_scan_response_data,
    typedef enum {
      BLE_TAG_EVT_NOTIFICATION_ENABLED,
      BLE_TAG_EVT_NOTIFICATION_DISABLED,
      BLE_TAG_EVT_DISCONNECTED,
      BLE_TAG_EVT_CONNECTED,
      BLE_TAG_EVT_WRITE
    } ble_tag_evt_type_t;
    typedef struct
      ble_tag_evt_type_t evt_type;
      uint8_t const *p_data;
    } ble_tag_evt_t;
    typedef void (*ble_tag_evt_handler_t)(ble_tag_t *p_tag, ble_tag_evt_t *p_evt);
    typedef struct
      ble_tag_evt_handler_t evt_handler;
      uint8_t *p_initial_measurements;
      ble_srv_cccd_security_mode_t custom_value_char_attr_md;
    } ble_tag_init_t;
    struct ble_tag_s {
      uint16_t service_handle;
      ble_gatts_char_handles_t tick_handle;
      ble_gatts_char_handles_t rate_handle;
      ble_gatts_char_handles_t own_handle;
      uint16_t conn_handle;
      uint8_t uuid_type;
    #define BLE_TAG_DEF(_name)          \
      static ble_tag_t _name;           \
      NRF_SDH_BLE_OBSERVER(_name##_obs, \
          BLE_HRS_BLE_OBSERVER_PRIO,    \
          ble_tag_on_ble_evt, &_name)
    BLE_TAG_DEF(m_tag);
    static void application_timers_start(void);
    static void application_timers_stop(void);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void) {
      ret_code_t err_code;
      NRF_LOG_INFO("Erase bonds!");
      err_code = pm_peers_delete();
    void ble_tag_on_ble_evt(ble_evt_t const *p_ble_evt, void *p_context) {
      ble_tag_t *p_tag = (ble_tag_t *)p_context;
      if (p_tag == NULL || p_ble_evt == NULL) {
        return;
      switch (p_ble_evt->header.evt_id) {
      case BLE_GAP_EVT_CONNECTED:
        p_tag->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
         p_tag->conn_handle = BLE_CONN_HANDLE_INVALID;
      case BLE_GATTS_EVT_WRITE:
    void advertising_start(bool erase_bonds) {
      if (erase_bonds) {
        delete_bonds();
      } else {
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        if (err_code != NRF_ERROR_INVALID_STATE &&
            err_code != NRF_ERROR_CONN_COUNT) {
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const *p_evt) {
      pm_handler_on_pm_evt(p_evt);
      pm_handler_flash_clean(p_evt);
      switch (p_evt->evt_id) {
        advertising_start(false);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void *p_context) {
      UNUSED_PARAMETER(p_context);
      // battery_level_update();
        if (!advertising_on) {
        NRF_LOG_INFO("Start advertising");
        advertising_start(NULL);
      } else {
        NRF_LOG_INFO("Stop advertising!!");
        (void)sd_ble_gap_adv_stop(m_adv_handle);
      advertising_on = !advertising_on;
    void advertising_stop(void) {
      err_code = sd_ble_gap_adv_stop(m_adv_handle);
          err_code != NRF_SUCCESS) {
    /**@brief Function for handling the Heart rate measurement timer timeout.
     * @details This function will be called each time the heart rate measurement timer expires.
     *          It will exclude RR Interval data from every third measurement.
    static void heart_rate_meas_timeout_handler(void *p_context) {
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void) {
      // Initialize timer module.
      err_code = app_timer_init();
      // Create timers.
      err_code = app_timer_create(&m_battery_timer_id,
          APP_TIMER_MODE_REPEATED,
          battery_level_meas_timeout_handler);
      err_code = app_timer_create(&m_heart_rate_timer_id,
          heart_rate_meas_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
    static void gap_params_init(void) {
      ble_gap_conn_params_t gap_conn_params;
      gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
      gap_conn_params.slave_latency = SLAVE_LATENCY;
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void) {
      ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    static void nrf_qwr_error_handler(uint32_t nrf_error) {
      APP_ERROR_HANDLER(nrf_error);
    static uint32_t custom_value_char_add(ble_tag_t *p_tag, const ble_tag_init_t *p_tag_init) {
      uint32_t err_code;
      ble_gatts_char_md_t char_md;
      ble_gatts_attr_md_t cccd_md;
      ble_gatts_attr_t attr_char_value;
      ble_uuid_t ble_uuid;
      ble_gatts_attr_md_t attr_md;
      memset(&cccd_md, 0, sizeof(cccd_md));
      BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
      BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
      cccd_md.vloc = BLE_GATTS_VLOC_STACK;
      memset(&char_md, 0, sizeof(char_md));
      char_md.char_props.notify = 0;
      char_md.char_props.read = 0;
      char_md.char_props.write = 1;
      char_md.p_char_user_desc = NULL;
      char_md.p_user_desc_md = NULL;
      char_md.p_cccd_md = &cccd_md;
      char_md.p_sccd_md = NULL;
      memset(&attr_md, 0, sizeof(attr_md));
      attr_md.read_perm = p_tag_init->custom_value_char_attr_md.read_perm;
      attr_md.write_perm = p_tag_init->custom_value_char_attr_md.write_perm;
      attr_md.vloc = BLE_GATTS_VLOC_STACK;
      attr_md.rd_auth = 0;
      attr_md.wr_auth = 0;
      attr_md.vlen = 0;
      ble_uuid.type = p_tag->uuid_type;
      ble_uuid.uuid = TICK_CHAR_UUID;
      memset(&attr_char_value, 0, sizeof(attr_char_value));
      attr_char_value.p_uuid = &ble_uuid;
      attr_char_value.p_attr_md = &attr_md;
      attr_char_value.init_len = 2;
      attr_char_value.init_offs = 0;
      attr_char_value.max_len = sizeof(uint16_t);
      err_code = sd_ble_gatts_characteristic_add(p_tag->service_handle,
          &char_md,
          &attr_char_value,
          &p_tag->tick_handle);
      ble_uuid.uuid = RATE_CHAR_UUID;
      attr_char_value.init_len = 1;
      attr_char_value.max_len = sizeof(uint8_t);
          &char_md,
          &attr_char_value,
          &p_tag->rate_handle);
      ble_uuid.uuid = OWN_CHAR_UUID;
      attr_char_value.init_len = 6;
      attr_char_value.max_len = 6;
          &char_md,
          &attr_char_value,
          &p_tag->own_handle);
      return err_code;
    uint32_t ble_tag_init(ble_tag_t *p_tag, ble_tag_init_t const *p_tag_init) {
      if (p_tag == NULL || p_tag_init == NULL) {
        return NRF_ERROR_NULL;
      memset(p_tag, 0, sizeof(*p_tag));
      uint32_t err_code;
      p_tag->evt_handler = p_tag_init->evt_handler;
      const ble_uuid128_t base_uuid = TAG_UUID_BASE;
      err_code = sd_ble_uuid_vs_add(&base_uuid, &p_tag->uuid_type);
      VERIFY_SUCCESS(err_code);
      ble_uuid.uuid = TAG_SERVICE_UUID;
      err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_tag->service_handle);
      if (err_code != NRF_SUCCESS) {
        return err_code;
      return custom_value_char_add(p_tag, p_tag_init);
    static void on_tag_evt(ble_tag_t *p_tag_service,
        ble_tag_evt_t *p_evt) {
      switch (p_evt->evt_type) {
      case BLE_TAG_EVT_NOTIFICATION_ENABLED:
      case BLE_TAG_EVT_NOTIFICATION_DISABLED:
      case BLE_TAG_EVT_CONNECTED:
      case BLE_TAG_EVT_DISCONNECTED:
     * @details Initialize the Heart Rate, Battery and Device Information services.
    static void services_init(void) {
      ble_tag_init_t tag_init;
      memset(&tag_init, 0, sizeof(tag_init));
      tag_init.evt_handler = on_tag_evt;
      tag_init.p_initial_measurements = NULL;
      BLE_GAP_CONN_SEC_MODE_SET_OPEN(&tag_init.custom_value_char_attr_md.read_perm);
      BLE_GAP_CONN_SEC_MODE_SET_OPEN(&tag_init.custom_value_char_attr_md.write_perm);
      err_code = ble_tag_init(&m_tag, &tag_init);
    /**@brief Function for starting application timers.
    static void application_timers_start(void) {
      // Start application timers.
      err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
      err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
      if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
    /**@brief Function for handling a Connection Parameters error.
    static void conn_params_error_handler(uint32_t nrf_error) {
    static void conn_params_init(void) {
      cp_init.p_conn_params = NULL;
      cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
      cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
      cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
      cp_init.disconnect_on_fail = false;
      cp_init.evt_handler = on_conn_params_evt;
      cp_init.error_handler = conn_params_error_handler;
    static void sleep_mode_enter(void) {
    #if 0
      // Prepare wakeup buttons.
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
      switch (ble_adv_evt) {
      case BLE_ADV_EVT_FAST:
        NRF_LOG_INFO("Fast advertising.");
        #if 0
      case BLE_ADV_EVT_IDLE:
        // sleep_mode_enter();
        idle_state_handle();
    static void ble_stack_init(void) {
      uint32_t ram_start = 0;
      // Enable BLE stack.
      // NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL);
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void) {
      err_code = pm_init();
      sec_param.bond = SEC_PARAM_BOND;
      sec_param.mitm = SEC_PARAM_MITM;
      sec_param.lesc = SEC_PARAM_LESC;
      sec_param.keypress = SEC_PARAM_KEYPRESS;
      sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
      sec_param.oob = SEC_PARAM_OOB;
      sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
      sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
      sec_param.kdist_own.enc = 1;
      sec_param.kdist_own.id = 1;
      sec_param.kdist_peer.enc = 1;
      sec_param.kdist_peer.id = 1;
    static void advertising_init(void) {
      ble_advdata_t advdata;
      uint8_t data[1] = {TAG_ADV_DATA_ID};
      memset(&manuf_data, 0, sizeof(manuf_data));
      manuf_data.company_identifier = 0xFFFF;
      manuf_data.data.p_data = data;
      manuf_data.data.size = 12;
      memset(&advdata, 0, sizeof(advdata));
      advdata.p_manuf_specific_data = &manuf_data;
      err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
      memset(&adv_params, 0, sizeof(adv_params));
      adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
      adv_params.duration = APP_ADV_DURATION;
      adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
      adv_params.p_peer_addr = NULL;
      adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
      adv_params.interval = APP_ADV_INTERVAL;
      adv_params.scan_req_notification = 1;
      err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    static void log_init(void) {
    static void power_management_init(void) {
    static void idle_state_handle(void) {
      //   err_code = nrf_ble_lesc_request_handler();
      //  APP_ERROR_CHECK(err_code);
      if (NRF_LOG_PROCESS() == false) {
        nrf_pwr_mgmt_run();
        // sd_app_evt_wait();
    /**@brief Function for application main entry.
    int main(void) {
      bool erase_bonds;
      // Initialize.
      log_init();
      timers_init();
      //  buttons_leds_init(&erase_bonds);
      power_management_init();
      ble_stack_init();
      gap_params_init();
      gatt_init();
      advertising_init();
      services_init();
      // sensor_simulator_init();
      conn_params_init();
      peer_manager_init();
      // Start execution.
      NRF_LOG_INFO("Heart Rate Sensor example started.");
      advertising_start(erase_bonds);
      application_timers_start();
      // Enter main loop.
      for (;;) {
    Chitra
  • Thanks for posting the code! I tried it with the ble_app_hrs project in nRF SDK 17.0.2. Unfortunately, for some reason I'm not able replicate the high idle current you described. The sleep current was always the same before and after connection.
    Measurements with Power profiler kit:
    System ON Idle (sleep)
    Advertising @ 500 ms intervals with LDO regulator
    Connection @ 400 ms
    Test project
    nRF5_SDK17.0.2_ble_app_hrs_current.zip
     Try to turn off Bluetooth on the phone in case there is a chance that it may still be connected in the background.
    Vidar
  • Have you turned the logging OFF?
    I too see that without turning the LOGGING OFF, the current was 30 Micro Amps
    Chitra
  • I only had logging over RTT enabled. Having the UART backend enabled (NRF_LOG_BACKEND_UART_ENABLED) will increase the sleep current.
    Vidar
