How do you add more than 1 custom UUID?
Hi Nordic DevTeam,
So I already followed this tutorial on how to add custom service UUID.
https://github.com/NordicPlayground/nRF5x-custom-ble-service-tutorial
I have 3 services that I want to add DFU, NUS and Custom, and probably more Custom UUID later.
I kept getting error 12 (NRF_ERROR_DATA_SIZE) on the ble_advertising_init() even though I already updated the #define NRF_SDH_BLE_VS_UUID_COUNT 3 (I assume it's 3 because DFU, NUS and Custom?)
Here's my code :
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
    {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    ble_cus_init_t     cus_init;
    // Initialize NUS.
    // Initialise CUS Service init structure to zero.
    memset(&cus_init, 0, sizeof(cus_init));
    err_code = ble_cus_init(&m_cus, &cus_init);
    // BEGIN Block Added for DFU
    // ONLY ADD THIS BLOCK TO THE EXISTING FUNCTION
    // Initialize the DFU service
    ble_dfu_buttonless_init_t dfus_init =
      .evt_handler = ble_dfu_buttonless_evt_handler
    err_code = ble_dfu_buttonless_init(&dfus_init);
    // END Block Added for DFU
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;// BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    advertising_config_get(&init.config);
    NRF_LOG_INFO("%d", err_code);
What's wrong with my initialisation bit?
  • awneil said:
    IME, finding the right memory size is rather hit and miss: there's no guidance - just a matter of trying more until it works!
    Could you elaborate on what you are referring to here?
    I think the issue with the NRF_ERROR_DATA_SIZE error that coyodha is seeing here might be with the size of the dataset they are trying to advertise.
    When it comes to setting the right RAM start address we've taken some steps in the nrf_sdh_ble.c to make this a little easier by having the debug logging output what you should change the RAM start address to. If you start out by setting the RAM start address unnaturally high before compiling and running it, you'll get the appropriate start address written to the logger, and then you can change it from there. Have you experienced some issues with this?
    I would also argue that calculating the required flash on the one hand is also pretty straight forward, since the size of the SoftDevice is given in its particular specification. On the other hand you will also need to keep control yourself on what else your application uses the flash for.
    There is indeed no guidance for the latter, but it might be helpful to have a look at the device memory layout when working with this, or checking out the FDS / flash storage examples.
    I would love to hear any input or feedback you might have on this, @awneil !
    Karl
  • Could you elaborate on what you are referring to here?
    I was referring to the RAM required for extra Services & Characteristics.
    And it would have been back in SDK v15, IIRC - so maybe things have improved now?
  • Hi Karl,
    You are right, the problem is the size of the advertising data.
    When I just have the NUS service, the program doesn't execute that error.
    Now, I am trying to make sense of what to put in. What's the difference between advertising data and scan response?
        init.advdata.name_type          = BLE_ADVDATA_SHORT_NAME;
        init.advdata.short_name_len     = 3; // Advertise only first 3 letters of name
        init.advdata.uuids_complete.uuid_cnt = 1;
        init.advdata.uuids_complete.p_uuids  = &m_adv_uuids[0];
        init.srdata.uuids_more_available.uuid_cnt = 1;
        init.srdata.uuids_more_available.p_uuids = &m_adv_uuids[1];
        init.config.ble_adv_fast_enabled = true;
    The code above works in my case, but I am actually not sure what I am doing. I can see all the UUID Service in nRF Connect.
    How's the structure for advertising data and scan response?
    I am happy to say that yes, they have indeed improved since then! Slight smile
    You may see this particular change in nrf_sdh_ble.c, in the nrf_sdh_ble_enable function. It now has a more detailed printouts, stating exactly what you should change the RAM start to to make it work.
    Karl
