How to send sensor data using AT commands to a device using Uart in segger embedded studio
Hi, I am new to NRF and segger embedded studio.
So I want to send temperature sensor data connected with nrf52840 DK to the Murata1_SC  device using UART.
The data will be sent using AT Commands.
So how to send AT Commands in Segger embedded studio.
Thank you for the help in advance.
  • i have made this code
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_uart.h"
    #include <string.h>
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    void uart_putstring(const uint8_t *str)
           uint32_t err_code;
           while( str )
                err_code = app_uart_put(( uint8_t*) str++ );
    char* uart_getstring(char* rx_data)
           uint32_t err_code;
           err_code = app_uart_get(rx_data);
           return rx_data;
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
     //Commands to send data to murata_1sc
    //    uart_putstring((const char*)"AT\r\n"); //variaible iterate - array iterate
      //   char* output;
        //output = uart_getstring(output);
         //printf("Hello PC from Nordic Device!!!\r\n");
     //array of commands declare
     char arrr[12][150]  = { " AT\r\n ",
                             " AT%CERTCMD=\"DIR\"%CERTCMD:murata_1sc_cert.pem,cert.pem,privatekey.pem,murata_private.key\r\n ",
                             " AT%CERTCFG=\"ADD\",1,,\"~\",\"murata_1sc_cert.pem\",\"murata_1sc_private.key\"\r\n ",
                             " AT%AWSIOTCFG=\"PROTOCOL\",1200,0\r\n ",
                             " AT%AWSIOTEV=\"ALL\",1\r\n ",
                             " AT%AWSIOTCMD=\"CONNECT\"\r\n ",
                             " AT%AWSIOTCMD=\"PUBLISH\",\"tracker/location\",\"{\"message\":\"Hello from Murata 1SC\"}\"\r\n ",
                             " AT%AWSIOTCMD=\"SUBSCRIBE\",\"tracker/location\"\r\n ",
                             " AT%AWSIOTCMD=\"SUBSCRIBE\",\"$aws/things/murata_1sc/shadow/update\"\r\n ",
                             " AT%AWSIOTCMD=\"PUBLISH\",\"$aws/things/murata_1sc/shadow/update\",\" { \"state\": {\"desired\": { \"color\": \"yellow\" } } }\"\r\n "
     //char outttt[12][100];
     //loopstart
     int i = 0;
     for(i=0;i<13;i++)
        uart_putstring((const char*)arrr[i]); //variaible iterate - array iterate
        char* output;
          while( !timeout && !reply_complete )
              // wait for timeout or reply complete
              if (output == "ERROR")
               printf("ERROR");
    //print
    //loop end
    I am still confused about time out
  • What, exactly, is your confusion?
    Another on ignoring responses when sending commands - only this morning:
    www.avrfreaks.net/.../3144271
  • I have sent AT every commands to the module using TeraTerm software, so some commands took almost 3 to 4 seconds to respond.
    So 4 seconds timout will be fine for this?
  • This should really be documented by the module manufacturer - you need to contact them for details.
    Remember that you have to consider worst case conditions.
    But if your application is OK to wait a whole 4s for a command which should complete "immediately" - then that's fine.
    It's your application - only you can answer that.
  • Yes, I am just testing the timeout with different commands.
    Could me please tell me, how can I make other pins as UART
    Because P0.05 to P0.08 are Hardware UART pins
      how can i make other GPIO pins work as UART like software serial in Arduino
