How to send sensor data using AT commands to a device using Uart in segger embedded studio
Hi, I am new to NRF and segger embedded studio.
So I want to send temperature sensor data connected with nrf52840 DK to the Murata1_SC  device using UART.
The data will be sent using AT Commands.
So how to send AT Commands in Segger embedded studio.
Thank you for the help in advance.
  • See the Product Specification: the nRF52 have flexible pin mapping - with just a couple of restrictions, the UART (and other peripherals) can be routed to any pins.
    The nRF52840 has two hardware UARTs
  • Is this correct
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_uart.h"
    #include <string.h>
    #define RX_PIN_NUMBER 27 //8
    #define TX_PIN_NUMBER 26 //6
    #define CTS_PIN_NUMBER 12 //7
    #define RTS_PIN_NUMBER 11 //5
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    void uart_putstring(const uint8_t *str)
           uint32_t err_code;
           while( str )
                err_code = app_uart_put(( uint8_t*) str++ );
    static void uart_loopback_test()
        uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
        uint8_t   rx_data;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
            uint32_t err_code;
            while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
            err_code = app_uart_get(&rx_data);
            if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
                show_error();
        return;
    char* uart_getstring(char* rx_data)
           uint32_t err_code;
           err_code = app_uart_get(rx_data);
           return rx_data;
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
     //Commands to send data to murata_1sc
        uart_putstring((const char*)"AT\r\n"); //variaible iterate - array iterate
        nrf_delay_ms(100);
         char* output;
        output = uart_getstring(output);
        printf(output);
        uart_putstring((const char*)"AT%AWSIOTCMD=\"PUBLISH\",\"tracker/location\",\"{\"message\":\"Hello from Murata 1SC\"}\"\r\n"); //variaible iterate - array iterate
        nrf_delay_ms(100);
         char* output;
        printf(output);
     //array of commands declare
     char arrr[12][150]  = { " AT\r\n ",
                             " AT%CERTCMD=\"DIR\"%CERTCMD:murata_1sc_cert.pem,cert.pem,privatekey.pem,murata_private.key\r\n ",
                             " AT%CERTCFG=\"ADD\",1,,\"~\",\"murata_1sc_cert.pem\",\"murata_1sc_private.key\"\r\n ",
                             " AT%AWSIOTCFG=\"PROTOCOL\",1200,0\r\n ",
                             " AT%AWSIOTEV=\"ALL\",1\r\n ",
                             " AT%AWSIOTCMD=\"CONNECT\"\r\n ",
                             " AT%AWSIOTCMD=\"PUBLISH\",\"tracker/location\",\"{\"message\":\"Hello from Murata 1SC\"}\"\r\n ",
                             " AT%AWSIOTCMD=\"SUBSCRIBE\",\"tracker/location\"\r\n ",
                             " AT%AWSIOTCMD=\"SUBSCRIBE\",\"$aws/things/murata_1sc/shadow/update\"\r\n ",
                             " AT%AWSIOTCMD=\"PUBLISH\",\"$aws/things/murata_1sc/shadow/update\",\" { \"state\": {\"desired\": { \"color\": \"yellow\" } } }\"\r\n "
     //char outttt[12][100];
     //loopstart
     int i = 0;
     for(i=0;i<13;i++)
        uart_putstring((const char*)arrr[i]); //variaible iterate - array iterate
        nrf_delay_ms(100);
        char* output;
        while( true )
              // wait for timeout or reply complete
              if (output == "ERROR")
               printf("ERROR");
    //print
    //loop end
    From where to check the GPIO pin in nrf
    like
    P1.02
    P1.03
    P1.04
  • I am using hardware pins,but i am able to make communication with device.
  • Hi by using the above code, I am not able to send anything.
    But I tried the following code to send data to Arduino and I am able to send the data.
    #include <stdint.h>
    #include <stdio.h>
    #include "nrf.h"
    #include "bsp.h"
    //#define RX_PIN_NUMBER 27 //8
    //#define TX_PIN_NUMBER 26 //6
    //#define CTS_PIN_NUMBER 12 //7
    //#define RTS_PIN_NUMBER 11 //5
    #define UART_TX_BUFF_SIZE 256
    #define UART_RX_BUFF_SIZE 256
    void uart_err_handle(app_uart_evt_type_t * p)
      uint32_t err_code;
      const app_uart_comm_params_t com_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        UART_HWFC,
        false,
      APP_UART_FIFO_INIT(&com_params, UART_RX_BUFF_SIZE, UART_TX_BUFF_SIZE, uart_err_handle, APP_IRQ_PRIORITY_LOWEST, err_code);
      printf("Hello PC from Nordic\r\n");
      while(true)
        uint8_t cr;
        while(app_uart_get(&cr) != NRF_SUCCESS);//wait here for the character from pc
        if(cr == 'OK')
          bsp_board_leds_on();
          printf("Leds are ON\r\n");
        if(cr == 'ERROR')
          bsp_board_leds_off();
          printf("Leds are OFF\r\n");
    Also, I am confused that by changing these pins
    Could I able to change the hardware UART to Software UART
    Because Hardware UART is used by Debugger
