MCUBoot: Image in the primary slot is not valid!
Hi Nordic Team,
I have a custom application running based on nRF NCS 1.5.0 with MCUboot enabled.
I'm having an issue where MCUboot simply doesn't jump to the application.
This comes and goes when I add/remove code from my main application... but with no noticible pattern. I wonder if image size is a factor and thing are overlapping in Flash image...
only using 42% of Flash for app.
1> Memory region Used Size Region Size %age Used
1> FLASH: 207828 B 495104 B 41.98%
1> SRAM: 66368 B 256 KB 25.32%
1> IDT_LIST: 88 B 2 KB 4.30%
Running partition manager report on build...\partitions.yml
I believe this is the standard setup where MCUboot take up to 48K and 2 app banks
flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB) |
+---0xc000: mcuboot_primary (0x79000 - 484kB)-----+
| 0xc000: mcuboot_pad (0x200 - 512B) |
+---0xc200: mcuboot_primary_app (0x78e00 - 483kB)-+
| 0xc200: app (0x78e00 - 483kB) |
| 0x85000: mcuboot_secondary (0x79000 - 484kB) |
| 0xfe000: settings_storage (0x2000 - 8kB) |
sram_primary (0x40000 - 256kB):
| 0x20000000: sram_primary (0x40000 - 256kB) |
I can get more debug but here's some I got via enabling minimal logging via RTT in MCUboot.conf
*** Booting Zephyr OS build v2.4.99-ncs1 ***
I: Starting bootloader
I: det pin = 12 rc = 1
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
E: Image in the primary slot is not valid!
E: fih_rc=1, succ=0
E: Unable to find bootable image
One clue is.... I started a bit of investigation into "merged.hex" and how it is created. I was surprised to see mergehex.py combines 4 different images with argument "--overlap=replace"
C:\Python38\python.exe C:/depot/ncs/zephyr/scripts/mergehex.py -o C:/depot/application/build_nrf52840dk_nrf52840/zephyr/merged.hex --overlap=replace C:/depot/application/build_nrf52840dk_nrf52840/mcuboot/zephyr/zephyr.hex C:/depot/application/build_nrf52840dk_nrf52840/zephyr/mcuboot_primary.hex C:/depot/application/build_nrf52840dk_nrf52840/zephyr/zephyr.hex C:/depot/application/build_nrf52840dk_nrf52840/zephyr/app_signed.hex
When I looked at those 4 images there is a LOT of overlap. Shouldn't the final image just consist of mcuboot image and app_signed?
For example: "app_signed.hex" and "zephyr.hex" are almost identical, they start the same but app_signed.hex has signature at the end which is normal, see below for similarities at start.
This is strange to me why zephyr.hex needs to be included in the mergehex while app_signed has everything as far as the app goes, or is there a piece that I am missing?
This is just one clue, but I haven't determined if this is causing the MCUboot not jumping to app. In other times when it does work, the overlap/replace redundancies are still in place. So I'm not sure if this is the cause.
Thanks for your assistance in advance, this is blocking progress of development for us.
