regarding the distance for the bluetooth range for scan and advertisement for nrf52840
Hi Nordic,
I am using the two nrf52840 units to test adv and scanning in a pair for the development. I am using BLE_GAP_PHY_CODED for both scan and advertisement. But when I test it, seems the package lost get very high when distance is longer than 70 meters. Any way to improve it? Also, is it possible to use the antenna signal amplifer for improve the receiving and advertisement distance?
  • Yes I know that. But normally it will not always be blocked for one channel for advertisement in our application. So that we want to make one channel advertisement and scanning works for the long range application(400meters)
  • Still doesn't explain why you don't just do it the normal way - with all three channels?
  • Please try removing this channel masking, as Coded PHY uses secondary advertising channels for the AUX_ADV_IND packets. Please read more on the technical aspects of Coded PHY here to get a better view of how the Coded PHY packets are set up.
    You can also try the example projects I linked to in my previous reply, which should let you get a considerably better range than what you're able to with the Uncoded PHYs.
    Simon
  • Thank you for your reply. I have tested a bit on your suggestion for the BLE uart example with both Peripheral  and Central side with long distance setup as you suggested. But the distance test result still around 280meters in the open area.
    Any suggestions to me?
    Peripheral side code is shown below
        ret_code_t             err_code;
        int8_t tx_power = 8;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = false;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_enabled      = true;
        init.config.ble_adv_fast_interval     = APP_ADV_INTERVAL;
        init.config.ble_adv_fast_timeout      = APP_ADV_DURATION;
         init.config.ble_adv_primary_phy       = BLE_GAP_PHY_CODED;
         init.config.ble_adv_secondary_phy     = BLE_GAP_PHY_CODED;
         init.config.ble_adv_extended_enabled  = true;
        err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV , m_advertising.adv_handle, tx_power);
        uint32_t err_code;
    	int8_t tx_power = 8; //niklas
            case BLE_GAP_EVT_CONNECTED:
                //NRF_LOG_INFO("Connected");
    	    status=1;
    	    status_connected=1;
                #ifdef UART_LOG_ENABLE1
                printf("Connect");nrf_delay_ms(1);
                //interrupt_pin_init();//niklas
                //reference https://jimmywongiot.com/2019/11/30/how-to-get-the-rssi-change-on-the-nrf5-sdk/
                //https://devzone.nordicsemi.com/f/nordic-q-a/69366/regarding-about-the-connection-rssi-for-signal-strength
                err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,1,2);//niklas
    	    //err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, tx_power); //niklas
    	    //APP_ERROR_CHECK(err_code);
                ble_connect_fg = 1;
            //case BLE_GAP_EVT_RSSI_CHANGED:
            //     rssi_value=p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
            //     printf("RSSI=%d\n",p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
    	    status=2;
    	    status_connected=2;
                NRF_LOG_INFO("Disconnected");
                printf("Disc");nrf_delay_ms(1);
    			if(nrf_gpio_pin_read(PIN_INTERRUPT))
    			 printf("In AA");nrf_delay_ms(1);
    			 //in_pin_handler();
                //advertising_start();
                ble_connect_fg = 0;
                status=3;
                //NRF_LOG_DEBUG("PHY update request.");
                printf("PHY update request.");nrf_delay_ms(1);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_CODED,//BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_CODED,//BLE_GAP_PHY_AUTO,
            } break;
    		     status=5;
                // Pairing not supported
    		    status=6;
            case BLE_GATTC_EVT_TIMEOUT:
    			status=7;
            case BLE_GATTS_EVT_TIMEOUT:
    		    status=8;
    		    status=9;
                // No implementation needed.
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
    The central side code is below also
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.p_scan_param = &m_scan_params;
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
        // Setting filters for scanning.
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
    static void scan_start(void)
        ret_code_t ret;
        ret = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, BLE_CONN_HANDLE_INVALID, 8);
        APP_ERROR_CHECK(ret);
        ret = nrf_ble_scan_start(&m_scan);
        //ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
  • Well, the range seems to be getting better at least. Are you testing on nRF52840 Development Kits, or custom boards? It might be related to your antenna or matching circuit if this is a custom board.
    Simon
