regarding the distance for the bluetooth range for scan and advertisement for nrf52840
Hi Nordic,
I am using the two nrf52840 units to test adv and scanning in a pair for the development. I am using BLE_GAP_PHY_CODED for both scan and advertisement. But when I test it, seems the package lost get very high when distance is longer than 70 meters. Any way to improve it? Also, is it possible to use the antenna signal amplifer for improve the receiving and advertisement distance?
    • There is a mistake for  init.evt_handler = on_adv_evt; is stated twice. I have fixed this part
    • for BLE_GAP_EVT_CONNECTED case in the ble_evt_handler() function:  1. I am using the "bsp_indication_set" to control the LED blinking to indicate the connection status. 2. sd_ble_gap_rssi_start is used to check the connection signal strength RSSI 3. nrf_ble_qwr_conn_handle_assign to do the connection handling
        uint32_t err_code;
    	int8_t tx_power = 8; //niklas
            case BLE_GAP_EVT_CONNECTED:
                //NRF_LOG_INFO("Connected");
    	    status=1;
    	    status_connected=1;
                #ifdef UART_LOG_ENABLE1
                printf("Connect");nrf_delay_ms(1);
                //interrupt_pin_init();//niklas
                //reference https://jimmywongiot.com/2019/11/30/how-to-get-the-rssi-change-on-the-nrf5-sdk/
                //https://devzone.nordicsemi.com/f/nordic-q-a/69366/regarding-about-the-connection-rssi-for-signal-strength
                err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,1,2);//niklas
    	    //err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, tx_power); //niklas
    	    //APP_ERROR_CHECK(err_code);
                ble_connect_fg = 1;
            //case BLE_GAP_EVT_RSSI_CHANGED:
            //     rssi_value=p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
            //     printf("RSSI=%d\n",p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
    	    status=2;
    	    status_connected=2;
                NRF_LOG_INFO("Disconnected");
                printf("Disc");nrf_delay_ms(1);
    			if(nrf_gpio_pin_read(PIN_INTERRUPT))
    			 printf("In AA");nrf_delay_ms(1);
    			 //in_pin_handler();
                //advertising_start();
                ble_connect_fg = 0;
                status=3;
                //NRF_LOG_DEBUG("PHY update request.");
                printf("PHY update request.");nrf_delay_ms(1);
                ble_gap_phys_t const phys =
                #ifdef LONG_RANGE_ENABLE
                    .rx_phys = BLE_GAP_PHY_CODED,//BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_CODED,//BLE_GAP_PHY_AUTO,
                #ifdef SHORT_RANGE_ENABLE
                    .rx_phys = BLE_GAP_PHY_1MBPS,//BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_1MBPS,//BLE_GAP_PHY_AUTO,
            } break;
    		     status=5;
                // Pairing not supported
    		    status=6;
            case BLE_GATTC_EVT_TIMEOUT:
    			status=7;
            case BLE_GATTS_EVT_TIMEOUT:
    		    status=8;
    		    status=9;
                // No implementation needed.
    The 32.768kHz crystal  I am using type is Epson Q13FC1350000200. The load capacitor, I am using the 12pf CC0402FRNPO9BN120 from Yageo for C4 and C5 in the picture below.
  • Do you know the specific load capacitance of the crystal you're using? According to the Epson Q13FC1350000200 datasheet CL can be 7, 9 or 12.5pF, and it it's the latter, you might wanna consider larger capacitors (20pF), as we generally go by this formula where Ccap is the best capacitor value for a crystal: Ccap = CL * 2 - 4pF. Although it seems strange that this would affect the range of your application. Do you have an nRf52840 DK available to test on, to see if you get the same range out of a DK as the modules?
    Do you see any disconnect reason when the devices disconnect at the maximum range (280 meters)? Are you seeing the expected timeout or some other error? Also, what RSSI values are you seeing at the higher ranges?
    Simon
