Stack overflow after GPS when integrating SMS and PDU libraries (based on asset tracker v2)
Hello
I have this firmware running in C:\Users\danie\ncs\v1.5.1\nrf\applications\tracker  on the nRF9160-DK, nRF9160 SICA B1 is the marking on the chip
Modem FW is 1.2.3:
See the attached log, it overflows every time there is a GPS lock. Please can you give us some guidance.
Kind regards
Dan
edit: I updated modem firmware to 1.3.0 but issue is still present.
2021-05-20T00:54:08.225Z INFO Application data folder: C:\Users\danie\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
2021-05-20T00:54:08.278Z DEBUG App pc-nrfconnect-toolchain-manager v0.9.1 official
2021-05-20T00:54:08.278Z DEBUG App path: C:\Users\danie\.nrfconnect-apps\node_modules\pc-nrfconnect-toolchain-manager
2021-05-20T00:54:08.278Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
2021-05-20T00:54:08.278Z DEBUG nRFConnect path: C:\Users\danie\AppData\Local\Programs\nrfconnect\resources\app.asar
2021-05-20T00:54:08.279Z DEBUG HomeDir: C:\Users\danie
2021-05-20T00:54:08.279Z DEBUG TmpDir: C:\Users\danie\AppData\Local\Temp
2021-05-20T00:59:50.851Z INFO Modem port is opened
2021-05-20T00:59:54.117Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs2  ***
2021-05-20T00:59:54.147Z DEBUG modem << I: Starting bootloader
2021-05-20T00:59:54.150Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2021-05-20T00:59:54.152Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2021-05-20T00:59:54.155Z DEBUG modem << I: Boot source: none
2021-05-20T00:59:54.157Z DEBUG modem << I: Swap type: none
2021-05-20T00:59:54.202Z DEBUG modem << I: Bootloader chainload address offset: 0x10000
2021-05-20T00:59:54.210Z DEBUG modem << I: Jumping to the first image slot
2021-05-20T00:59:56.329Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs2  ***
2021-05-20T00:59:56.335Z DEBUG modem << [00:00:00.206,420] [0m<inf> event_manager: APP_EVT_START[0m
2021-05-20T00:59:56.355Z DEBUG modem << [00:00:00.226,348] [0m<inf> event_manager: DATA_EVT_CONFIG_INIT[0m
2021-05-20T00:59:56.362Z DEBUG modem << [00:00:00.232,727] [0m<inf> sms: SMS client successfully registered[0m
2021-05-20T00:59:56.368Z DEBUG modem << [00:00:00.239,135] [0m<inf> app_module: Device mode: Passive[0m
2021-05-20T00:59:56.377Z DEBUG modem << [00:00:00.244,934] [0m<inf> app_module: Start movement timeout: 30 seconds interval[0m
2021-05-20T00:59:56.446Z DEBUG modem << [00:00:00.316,711] [0m<inf> event_manager: MODEM_EVT_LTE_CONNECTING[0m
2021-05-20T00:59:57.988Z DEBUG modem << [00:00:01.859,069] [0m<inf> event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
2021-05-20T00:59:57.996Z DEBUG modem << [00:00:01.865,875] [0m<inf> event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
2021-05-20T00:59:59.179Z DEBUG modem << [00:00:03.049,865] [0m<inf> event_manager: MODEM_EVT_LTE_CONNECTED[0m
2021-05-20T00:59:59.186Z DEBUG modem << [00:00:03.056,427] [0m<inf> event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
2021-05-20T00:59:59.194Z DEBUG modem << [00:00:03.063,110] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
2021-05-20T00:59:59.205Z DEBUG modem << [00:00:03.071,228] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
2021-05-20T00:59:59.210Z DEBUG modem << [00:00:03.080,566] [0m<inf> event_manager: CLOUD_EVT_CONNECTING[0m
2021-05-20T01:00:01.948Z DEBUG modem << [00:00:05.819,488] [0m<inf> event_manager: CLOUD_EVT_CONNECTED[0m
2021-05-20T01:00:02.372Z DEBUG modem << [00:00:06.243,103] [0m<inf> event_manager: DATA_EVT_DATE_TIME_OBTAINED[0m
2021-05-20T01:00:02.382Z DEBUG modem << [00:00:06.250,061] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS, MOD_STAT)[0m
2021-05-20T01:00:02.395Z DEBUG modem << [00:00:06.266,510] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:00:02.405Z DEBUG modem << [00:00:06.272,399] [0m<inf> event_manager: GPS_EVT_AGPS_NEEDED[0m
2021-05-20T01:00:02.408Z DEBUG modem << [00:00:06.279,022] [0m<inf> agps: SUPL is initialized[0m
2021-05-20T01:00:02.452Z DEBUG modem << [00:00:06.322,723] [0m<inf> event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2021-05-20T01:00:02.578Z DEBUG modem << [00:00:06.448,486] [0m<inf> event_manager: CLOUD_EVT_CONFIG_RECEIVED[0m
2021-05-20T01:00:02.585Z DEBUG modem << [00:00:06.455,810] [0m<inf> event_manager: DATA_EVT_CONFIG_READY[0m
2021-05-20T01:00:02.591Z DEBUG modem << [00:00:06.462,097] [0m<inf> app_module: Device mode: Passive[0m
2021-05-20T01:00:02.602Z DEBUG modem << [00:00:06.467,864] [0m<inf> app_module: Start movement timeout: 30 seconds interval[0m
2021-05-20T01:00:02.607Z DEBUG modem << [00:00:06.475,708] [1;33m<wrn> data_module: No change in current device configuration[0m
2021-05-20T01:00:02.712Z DEBUG modem << [00:00:06.583,709] [0m<inf> agps: Starting SUPL session[0m
2021-05-20T01:00:05.288Z DEBUG modem << [00:00:09.158,935] [0m<inf> agps: SUPL session finished successfully[0m
2021-05-20T01:00:24.063Z DEBUG modem << [00:00:27.935,089] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:00:24.070Z DEBUG modem << [00:00:27.941,345] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:00:24.076Z DEBUG modem << [00:00:27.947,814] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:00:24.088Z DEBUG modem << [00:00:27.959,625] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:00:24.130Z DEBUG modem << [00:00:28.002,532] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:00:32.603Z DEBUG modem << [00:00:36.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:00:32.612Z DEBUG modem << [00:00:36.482,177] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:00:32.647Z DEBUG modem << [00:00:36.520,172] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:00:34.722Z DEBUG modem << [00:00:38.595,123] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:00:34.729Z DEBUG modem << [00:00:38.601,379] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:00:34.735Z DEBUG modem << [00:00:38.607,849] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:00:34.750Z DEBUG modem << [00:00:38.616,973] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:00:34.786Z DEBUG modem << [00:00:38.659,820] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:01:02.601Z DEBUG modem << [00:01:06.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:01:02.609Z DEBUG modem << [00:01:06.482,177] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:01:02.675Z DEBUG modem << [00:01:06.550,170] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:01:03.761Z DEBUG modem << [00:01:07.636,718] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:01:03.768Z DEBUG modem << [00:01:07.643,005] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:01:03.774Z DEBUG modem << [00:01:07.649,475] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:01:03.784Z DEBUG modem << [00:01:07.658,752] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:01:03.827Z DEBUG modem << [00:01:07.701,599] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:01:32.599Z DEBUG modem << [00:01:36.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:01:32.607Z DEBUG modem << [00:01:36.482,177] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:01:32.673Z DEBUG modem << [00:01:36.550,537] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:01:33.764Z DEBUG modem << [00:01:37.641,448] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:01:33.773Z DEBUG modem << [00:01:37.647,705] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:01:33.780Z DEBUG modem << [00:01:37.654,174] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:01:33.786Z DEBUG modem << [00:01:37.663,452] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:01:33.829Z DEBUG modem << [00:01:37.706,298] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:02:02.596Z DEBUG modem << [00:02:06.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:02:02.605Z DEBUG modem << [00:02:06.482,177] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:02:02.670Z DEBUG modem << [00:02:06.550,201] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:02:03.758Z DEBUG modem << [00:02:07.637,512] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:02:03.767Z DEBUG modem << [00:02:07.643,768] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:02:03.770Z DEBUG modem << [00:02:07.650,238] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:02:03.783Z DEBUG modem << [00:02:07.659,515] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:02:03.822Z DEBUG modem << [00:02:07.702,331] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:02:32.594Z DEBUG modem << [00:02:36.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:02:32.604Z DEBUG modem << [00:02:36.482,147] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:02:32.668Z DEBUG modem << [00:02:36.550,170] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:02:33.749Z DEBUG modem << [00:02:37.630,981] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:02:33.758Z DEBUG modem << [00:02:37.637,237] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:02:33.762Z DEBUG modem << [00:02:37.643,737] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:02:33.771Z DEBUG modem << [00:02:37.652,984] [0m<inf> event_manager: DATA_EVT_DATA_SEND[0m
2021-05-20T01:02:33.814Z DEBUG modem << [00:02:37.695,800] [0m<inf> event_manager: CLOUD_EVT_DATA_ACK[0m
2021-05-20T01:03:02.591Z DEBUG modem << [00:03:06.475,799] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:03:02.600Z DEBUG modem << [00:03:06.482,177] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS)[0m
2021-05-20T01:03:02.666Z DEBUG modem << [00:03:06.550,567] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:03:03.756Z DEBUG modem << [00:03:07.640,533] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:03:03.764Z DEBUG modem << [00:03:07.646,820] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:03:03.769Z DEBUG modem << [00:03:07.653,289] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:04:14.774Z DEBUG modem << [00:04:18.663,818] [1;31m<err> os: ***** USAGE FAULT *****[0m
2021-05-20T01:04:14.781Z DEBUG modem << [00:04:18.669,403] [1;31m<err> os:   Stack overflow (context area not valid)[0m
2021-05-20T01:04:14.790Z DEBUG modem << [00:04:18.676,635] [1;31m<err> os: r0/a1:  0x00043b10  r1/a2:  0x81000200  r2/a3:  0x33f6e7fe[0m
2021-05-20T01:04:14.799Z DEBUG modem << [00:04:18.685,333] [1;31m<err> os: r3/a4:  0x21483084 r12/ip:  0x8db7fbb9 r14/lr:  0x68188137[0m
2021-05-20T01:04:14.804Z DEBUG modem << [00:04:18.694,061] [1;31m<err> os:  xpsr:  0x291ea000[0m
2021-05-20T01:04:14.816Z DEBUG modem << [00:04:18.699,279] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
2021-05-20T01:04:14.830Z DEBUG modem << [00:04:18.709,716] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000002  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
2021-05-20T01:04:14.836Z DEBUG modem << [00:04:18.720,184] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
2021-05-20T01:04:14.849Z DEBUG modem << [00:04:18.730,621] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
2021-05-20T01:04:14.852Z DEBUG modem << [00:04:18.741,088] [1;31m<err> os: fpscr:  0x2002b9e0[0m
2021-05-20T01:04:14.865Z DEBUG modem << [00:04:18.746,307] [1;31m<err> os: Faulting instruction address (r15/pc): 0x3f5fa9f9[0m
2021-05-20T01:04:14.868Z DEBUG modem << [00:04:18.754,241] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[0m
2021-05-20T01:04:14.880Z DEBUG modem << [00:04:18.762,176] [1;31m<err> os: Current thread: 0x20017150 (unknown)[0m
2021-05-20T01:04:14.882Z DEBUG modem << [00:04:18.769,256] [0m<inf> event_manager: UTIL_EVT_SHUTDOWN_REQUEST[0m
2021-05-20T01:04:14.887Z DEBUG modem << [00:04:18.776,062] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:04:14.899Z DEBUG modem << [00:04:18.782,287] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
2021-05-20T01:04:14.901Z DEBUG modem << [00:04:18.788,482] [0m<inf> event_manager: UI_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:14.906Z DEBUG modem << [00:04:18.794,677] [0m<inf> event_manager: GPS_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:14.917Z DEBUG modem << [00:04:18.801,116] [0m<inf> event_manager: APP_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:14.919Z DEBUG modem << [00:04:18.807,647] [0m<inf> event_manager: CLOUD_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:14.931Z DEBUG modem << [00:04:18.814,331] [0m<inf> event_manager: SENSOR_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:15.765Z DEBUG modem << [00:04:19.654,724] [0m<inf> event_manager: CLOUD_EVT_DISCONNECTED[0m
2021-05-20T01:04:15.780Z DEBUG modem << [00:04:19.661,956] [0m<inf> event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
2021-05-20T01:04:15.783Z DEBUG modem << [00:04:19.668,548] [1;33m<wrn> modules_common: data: Message could not be enqueued, error code: -35[0m
2021-05-20T01:04:15.797Z DEBUG modem << [00:04:19.677,764] [1;31m<err> data_module: Message could not be enqueued[0m
2021-05-20T01:04:15.799Z DEBUG modem << [00:04:19.684,875] [0m<inf> event_manager: DATA_EVT_ERROR - Error code -35[0m
2021-05-20T01:04:18.602Z DEBUG modem << [00:04:22.492,095] [0m<inf> event_manager: MODEM_EVT_SHUTDOWN_READY[0m
2021-05-20T01:04:35.094Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs2  ***
2021-05-20T01:04:35.103Z DEBUG modem << I: Starting bootloader
2021-05-20T01:04:35.105Z DEBUG modem << I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2021-05-20T01:04:35.110Z DEBUG modem << I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
2021-05-20T01:04:35.112Z DEBUG modem << I: Boot source: none
2021-05-20T01:04:35.114Z DEBUG modem << I: Swap type: none
2021-05-20T01:04:35.180Z DEBUG modem << I: Bootloader chainload address offset: 0x10000
2021-05-20T01:04:35.188Z DEBUG modem << I: Jumping to the first image slot
2021-05-20T01:04:35.569Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs2  ***
2021-05-20T01:04:35.578Z DEBUG modem << [00:00:00.206,481] [0m<inf> event_manager: APP_EVT_START[0m
2021-05-20T01:04:35.602Z DEBUG modem << [00:00:00.232,482] [0m<inf> event_manager: DATA_EVT_CONFIG_INIT[0m
2021-05-20T01:04:35.609Z DEBUG modem << [00:00:00.238,922] [0m<inf> sms: SMS client successfully registered[0m
2021-05-20T01:04:35.614Z DEBUG modem << [00:00:00.245,330] [0m<inf> app_module: Device mode: Passive[0m
2021-05-20T01:04:35.624Z DEBUG modem << [00:00:00.251,159] [0m<inf> app_module: Start movement timeout: 30 seconds interval[0m
2021-05-20T01:04:35.691Z DEBUG modem << [00:00:00.322,021] [0m<inf> event_manager: MODEM_EVT_LTE_CONNECTING[0m
2021-05-20T01:04:37.022Z DEBUG modem << [00:00:01.652,069] [0m<inf> event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
2021-05-20T01:04:37.031Z DEBUG modem << [00:00:01.658,905] [0m<inf> event_manager: MODEM_EVT_LTE_CELL_UPDATE[0m
2021-05-20T01:04:37.893Z DEBUG modem << [00:00:02.523,620] [0m<inf> event_manager: MODEM_EVT_LTE_CONNECTED[0m
2021-05-20T01:04:37.901Z DEBUG modem << [00:00:02.530,212] [0m<inf> event_manager: MODEM_EVT_LTE_PSM_UPDATE[0m
2021-05-20T01:04:37.909Z DEBUG modem << [00:00:02.536,895] [1;33m<wrn> cloud_module: Cloud connection establishment in progress[0m
2021-05-20T01:04:37.922Z DEBUG modem << [00:00:02.545,013] [1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful[0m
2021-05-20T01:04:37.925Z DEBUG modem << [00:00:02.554,351] [0m<inf> event_manager: CLOUD_EVT_CONNECTING[0m
2021-05-20T01:04:40.589Z DEBUG modem << [00:00:05.220,520] [0m<inf> event_manager: CLOUD_EVT_CONNECTED[0m
2021-05-20T01:04:40.849Z DEBUG modem << [00:00:05.481,445] [0m<inf> app_module: Sms received:  -> [0m
2021-05-20T01:04:41.097Z DEBUG modem << [00:00:05.727,020] [0m<inf> event_manager: DATA_EVT_DATE_TIME_OBTAINED[0m
2021-05-20T01:04:41.107Z DEBUG modem << [00:00:05.733,978] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (GNSS, MOD_STAT)[0m
2021-05-20T01:04:41.118Z DEBUG modem << [00:00:05.749,603] [0m<inf> event_manager: GPS_EVT_ACTIVE[0m
2021-05-20T01:04:41.124Z DEBUG modem << [00:00:05.755,493] [0m<inf> event_manager: GPS_EVT_AGPS_NEEDED[0m
2021-05-20T01:04:41.136Z DEBUG modem << [00:00:05.762,207] [0m<inf> agps: SUPL is initialized[0m
2021-05-20T01:04:41.177Z DEBUG modem << [00:00:05.806,793] [0m<inf> event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY[0m
2021-05-20T01:04:41.262Z DEBUG modem << [00:00:05.892,639] [0m<inf> event_manager: CLOUD_EVT_CONFIG_RECEIVED[0m
2021-05-20T01:04:41.270Z DEBUG modem << [00:00:05.899,963] [0m<inf> event_manager: DATA_EVT_CONFIG_READY[0m
2021-05-20T01:04:41.275Z DEBUG modem << [00:00:05.906,250] [0m<inf> app_module: Device mode: Passive[0m
2021-05-20T01:04:41.285Z DEBUG modem << [00:00:05.912,017] [0m<inf> app_module: Start movement timeout: 30 seconds interval[0m
2021-05-20T01:04:41.291Z DEBUG modem << [00:00:05.920,104] [1;33m<wrn> data_module: No change in current device configuration[0m
2021-05-20T01:04:41.411Z DEBUG modem << [00:00:06.041,198] [0m<inf> app_module: Sms received: 19499104550 -> Test[0m
2021-05-20T01:04:41.425Z DEBUG modem << [00:00:06.056,640] [0m<inf> agps: Starting SUPL session[0m
2021-05-20T01:04:43.848Z DEBUG modem << [00:00:08.478,881] [0m<inf> agps: SUPL session finished successfully[0m
2021-05-20T01:05:00.626Z DEBUG modem << [00:00:25.258,605] [0m<inf> event_manager: GPS_EVT_DATA_READY[0m
2021-05-20T01:05:00.637Z DEBUG modem << [00:00:25.264,862] [0m<inf> event_manager: DATA_EVT_DATA_READY[0m
2021-05-20T01:05:00.640Z DEBUG modem << [00:00:25.271,423] [0m<inf> event_manager: GPS_EVT_INACTIVE[0m
2021-05-20T01:05:00.648Z DEBUG modem << [00:00:25.280,975] [1;31m<err> os: ***** USAGE FAULT *****[0m
2021-05-20T01:05:00.663Z DEBUG modem << [00:00:25.286,560] [1;31m<err> os:   Stack overflow (context area not valid)[0m
2021-05-20T01:05:00.665Z DEBUG modem << [00:00:25.293,823] [1;31m<err> os: r0/a1:  0x00043b10  r1/a2:  0x81000200  r2/a3:  0xe0000000[0m
2021-05-20T01:05:00.678Z DEBUG modem << [00:00:25.302,520] [1;31m<err> os: r3/a4:  0x3fb976b4 r12/ip:  0x00000000 r14/lr:  0x00000000[0m
2021-05-20T01:05:00.679Z DEBUG modem << [00:00:25.311,218] [1;31m<err> os:  xpsr:  0x00000000[0m
2021-05-20T01:05:00.696Z DEBUG modem << [00:00:25.316,467] [1;31m<err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000[0m
2021-05-20T01:05:00.698Z DEBUG modem << [00:00:25.326,904] [1;31m<err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000[0m
2021-05-20T01:05:00.714Z DEBUG modem << [00:00:25.337,371] [1;31m<err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000[0m
2021-05-20T01:05:00.720Z DEBUG modem << [00:00:25.347,839] [1;31m<err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000[0m
2021-05-20T01:05:00.735Z DEBUG modem << [00:00:25.358,276] [1;31m<err> os: fpscr:  0x2002b9e0[0m
2021-05-20T01:05:00.736Z DEBUG modem << [00:00:25.363,525] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00000000[0m
2021-05-20T01:05:00.750Z DEBUG modem << [00:00:25.371,459] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0[0m
2021-05-20T01:05:00.752Z DEBUG modem << [00:00:25.379,364] [1;31m<err> os: Current thread: 0x20017150 (unknown)[0m
2021-05-20T01:05:00.764Z DEBUG modem << [00:00:25.386,291] [0m<inf> event_manager: UTIL_EVT_SHUTDOWN_REQUEST[0m
2021-05-20T01:05:00.766Z DEBUG modem << [00:00:25.393,005] [0m<inf> event_manager: UI_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:00.767Z DEBUG modem << [00:00:25.399,230] [0m<inf> event_manager: GPS_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:00.784Z DEBUG modem << [00:00:25.405,670] [0m<inf> event_manager: APP_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:00.785Z DEBUG modem << [00:00:25.412,170] [0m<inf> event_manager: CLOUD_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:00.799Z DEBUG modem << [00:00:25.418,853] [0m<inf> event_manager: SENSOR_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:05.882Z DEBUG modem << [00:00:30.513,580] [0m<inf> event_manager: CLOUD_EVT_DISCONNECTED[0m
2021-05-20T01:05:05.888Z DEBUG modem << [00:00:30.520,507] [0m<inf> event_manager: MODEM_EVT_LTE_DISCONNECTED[0m
2021-05-20T01:05:06.037Z DEBUG modem << [00:00:30.669,769] [0m<inf> event_manager: MODEM_EVT_SHUTDOWN_READY[0m
2021-05-20T01:05:09.627Z INFO Modem port is closed
