Where can I find EAGLE library for nRF52840-CKAA-R WLCSP-93 package?
samuelbaldwin
Does anybody know where I'll be able to find an EAGLE library for the nRF52840 CKAA chip (the WLCSP-93 package)? I've looked around and all other dev boards that have their libraries available all use the 7mm x 7mm QIAA version. This is way too big for the product I'm designing so I need the 3.6mm x 3.6mm smaller package.
  • Hey Jared.
    So basically our team has done the routing based on the above recommendations, but we are unable to find a production house that has the capabilities to support our requirement.
    We basically making a really small PCB. can you support us with this information:?
    1. Via hole dimension,(in our case we need to go for both blind and burried via's since our pcb size is small)
    2. pad to pad clearance trace width
    ( for nRF52840-CKAA-R WLCSP-93 package.)
     All the production houses we have reached out to support a minimum track and gap of 0.075mm and a laser drill of 0.1 mm .  Have we overlooked something? Any suggestions on how my team can move pass this impasse would be great!
    The minimum via size that is used in the reference design is 0.1 mm:
    Even though your design is small I would think it would be possible have the same size vias? Have you seen our nRF52840 dongle designThe pad to pad clearance trace width is entirely dependent on the production house used. It doesn't seem like this would be an issue in your design. I also suggest that you create a new private ticket for a HW review. There is several things of concern in your design, proper grounding for instance. Attach your schematic and PCB hw files in a new ticket for a HW review.
    regards
    Jared
  • Hey,
    Thanks for the suggestion, have updated the team ad will create a new ticket for the same.
