About the bug of download_test demo。
I added FOTA_DOWNLOAD and MCU_BOOT to my project.Then I want to use http to download a file, and an EBADMSG error occurs at this time.
I reproduced this problem in the download_test demo.
The code has not been changed, just modified prj.conf. Here is my prj.conf
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_NATIVE=n
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MODEM_KEY_MGMT=y
CONFIG_LTE_LINK_CONTROL=y
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_SAMPLE_FILE_CUSTOM=y
CONFIG_SAMPLE_FILE_URL="http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100"
# LTE link control
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_LEGACY_PCO_MODE=y
# FOTA library
CONFIG_FOTA_DOWNLOAD=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_BOOTLOADER_MCUBOOT=y
# DFU Target
CONFIG_DFU_TARGET=y
Application log:
[22:25:50.810]收←◆I: Bootloader chainload address offset: 0x10000
I: Jumping to the first image slot
[22:26:01.080]收←◆*** Booting Zephyr OS build v2.4.99-ncs1  ***
Flash regions		Domain		Permissions
00 02 0x00000 0x18000 	Secure		rwxl
03 31 0x18000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
[22:26:01.291]收←◆SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0x1c200
SPM: NS MSP at 0x200183d0
SPM: NS reset vector at 0x1f10d
SPM: prepare to jump to Non-Secure image.
Download client sample started
[22:26:01.610]收←◆Waiting for network..
[22:26:07.682]收←◆OK
[22:26:08.294]收←◆Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
[22:26:08.893]收←◆Error -77 during download
I did some tests. When I commented out CONFIG_DFU_TARGET=y, everything became normal. But FOTA is gone, this is not the result I want.
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
# LTE link control
# FOTA library
# Image manager
CONFIG_FLASH=y
# DFU Target
#CONFIG_DFU_TARGET=y
Application log:
[22:50:40.129]收←◆I: Bootloader chainload address offset: 0x10000
[22:50:41.848]收←◆*** Booting Zephyr OS build v2.4.99-ncs1  ***
[22:50:42.058]收←◆SRAM region		Domain		Permissions
SPM: NS MSP at 0x200182f0
[22:50:42.377]收←◆Waiting for network..
[22:50:47.374]收←◆OK
[22:50:47.823]收←◆Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
[22:50:49.448]收←◆[  88% ] |============================================      | (2048/2304 bytes)[ 100% ] |==================================================| (2304/2304 bytes)
Download completed in 1639 ms @ 1405 bytes per sec, total 2304 bytes
Bye
This seems to be related to CONFIG_DFU_TARGET=y, but I can’t see any problems in the code. Can you help me analyze the problem?
  • I've already done a comparative for the content-range header you mentioned. The reason that the content-range header is different is caused by the 76th line of code in http.c. When CONFIG_DFU_TARGET=y, CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS will be enabled.
    #define GET_HTTP_TEMPLATE                                                      \
    	"GET /%s HTTP/1.1\r\n"                                                 \
    	"Host: %s\r\n"                                                         \
    	"Range: bytes=%u-\r\n"                                                 \
    	"Connection: keep-alive\r\n"                                           \
    	"\r\n"
    #define GET_HTTPS_TEMPLATE                                                     \
    	"Host: %s\r\n"                                                         \
    	"Range: bytes=%u-%u\r\n"                                               \
    	"\r\n"
    /* We use range requests only for HTTPS, due to memory limitations.
     * When using HTTP, we request the whole resource to minimize
     * network usage (only one request/response are sent).
    if (client->proto == IPPROTO_TLS_1_2
       || IS_ENABLED(CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS)) {
    	len = snprintf(client->buf,
    		CONFIG_DOWNLOAD_CLIENT_BUF_SIZE,
    		GET_HTTPS_TEMPLATE, file, host, client->progress, off);
    } else {
    		GET_HTTP_TEMPLATE, file, host, client->progress);
    But the real reason is not caused by the content-range header. Below is my log comparing different situations.
    CONFIG_DFU_TARGET=y
    Range: bytes=0-
    Waiting for network.. [00:00:00.209,136] <inf> lte_lc: Using legacy LTE PCO mode...
    OK
    [00:00:05.343,811] <dbg> download_client.client_connect: Port not specified, using default: 80
    [00:00:05.343,841] <dbg> download_client.client_connect: family: 1, type: 1, proto: 6
    [00:00:05.344,238] <inf> download_client: Configuring socket timeout (30 s)
    [00:00:05.344,238] <inf> download_client: Connecting to http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
    [00:00:05.344,268] <dbg> download_client.client_connect: fd 1, addrlen 8, fam IPv4, port 80
    [00:00:07.872,772] <dbg> download_client: HTTP request
                                              47 45 54 20 2f 51 47 50  53 5f 31 2e 44 41 54 3f |GET /QGP S_1.DAT?
                                              76 65 6e 64 6f 72 3d 47  4f 54 4f 50 26 70 72 6f |vendor=G OTOP&pro
                                              6a 65 63 74 3d 4b 75 69  69 6b 6c 4e 41 71 6f 72 |ject=Kui iklNAqor
                                              6d 38 53 52 64 61 57 50  51 69 47 62 5a 36 6c 6b |m8SRdaWP QiGbZ6lk
                                              45 6c 4d 36 2d 4b 7a 4e  52 49 61 75 5f 74 6a 45 |ElM6-KzN RIau_tjE
                                              26 64 65 76 69 63 65 5f  69 64 3d 31 30 30 20 48 |&device_ id=100 H
                                              54 54 50 2f 31 2e 31 0d  0a 48 6f 73 74 3a 20 77 |TTP/1.1. .Host: w
                                              70 65 70 6f 64 6f 77 6e  6c 6f 61 64 2e 6d 65 64 |pepodown load.med
                                              69 61 74 65 6b 2e 63 6f  6d 0d 0a 52 61 6e 67 65 |iatek.co m..Range
                                              3a 20 62 79 74 65 73 3d  30 2d 0d 0a 43 6f 6e 6e |: bytes= 0-..Conn
                                              65 63 74 69 6f 6e 3a 20  6b 65 65 70 2d 61 6c 69 |ection:  keep-ali
                                              76 65 0d 0a 0d 0a                                |ve....
    [00:00:07.873,077] <inf> download_client: Downloading: http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100 [0]
    Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device[00:00:07.873,260] <dbg> download_client.download_thread: Receiving up to 2048 bytes at 0x200146fc...
    [00:00:15.863,220] <dbg> download_client.download_thread: Read 708 bytes from socket
    [00:00:15.863,311] <dbg> download_client.http_header_parse: GET header size: 426
    [00:00:15.863,342] <dbg> download_client: HTTP response
                                              48 54 54 50 2f 31 2e 31  20 32 30 30 20 4f 4b 0d |HTTP/1.1  200 OK.
                                              0a 43 6f 6e 74 65 6e 74  2d 54 79 70 65 3a 20 61 |.Content -Type: a
                                              70 70 6c 69 63 61 74 69  6f 6e 2f 6f 63 74 65 74 |pplicati on/octet
                                              2d 73 74 72 65 61 6d 0d  0a 43 6f 6e 74 65 6e 74 |-stream. .Content
                                              2d 4c 65 6e 67 74 68 3a  20 32 33 30 34 0d 0a 43 |-Length:  2304..C
                                              6f 6e 6e 65 63 74 69 6f  6e 3a 20 6b 65 65 70 2d |onnectio n: keep-
                                              61 6c 69 76 65 0d 0a 44  61 74 65 3a 20 54 68 75 |alive..D ate: Thu
                                              2c 20 30 33 20 4a 75 6e  20 32 30 32 31 20 30 33 |, 03 Jun  2021 03
                                              3a 32 38 3a 35 32 20 47  4d 54 0d 0a 45 54 61 67 |:28:52 G MT..ETag
                                              3a 20 22 33 37 38 34 63  62 62 31 39 30 61 62 34 |: "3784c bb190ab4
                                              61 66 33 30 66 32 39 33  36 39 66 35 30 36 33 34 |af30f293 69f50634
                                              64 37 66 22 0d 0a 53 65  72 76 65 72 3a 20 6e 67 |d7f"..Se rver: ng
                                              69 6e 78 2f 31 2e 31 30  2e 31 0d 0a 58 2d 50 6f |inx/1.10 .1..X-Po
                                              77 65 72 65 64 2d 42 79  3a 20 45 78 70 72 65 73 |wered-By : Expres
                                              73 0d 0a 58 2d 43 61 63  68 65 3a 20 4d 69 73 73 |s..X-Cac he: Miss
                                              20 66 72 6f 6d 20 63 6c  6f 75 64 66 72 6f 6e 74 | from cl oudfront
                                              0d 0a 56 69 61 3a 20 31  2e 31 20 62 64 39 34 36 |..Via: 1 .1 bd946
                                              32 62 63 38 38 36 66 66  37 34 30 35 61 63 30 61 |2bc886ff 7405ac0a
                                              39 35 32 35 35 34 36 32  38 33 34 2e 63 6c 6f 75 |95255462 834.clou
                                              64 66 72 6f 6e 74 2e 6e  65 74 20 28 43 6c 6f 75 |dfront.n et (Clou
                                              64 46 72 6f 6e 74 29 0d  0a 58 2d 41 6d 7a 2d 43 |dFront). .X-Amz-C
                                              66 2d 50 6f 70 3a 20 48  4b 47 36 32 2d 43 31 0d |f-Pop: H KG62-C1.
                                              0a 58 2d 41 6d 7a 2d 43  66 2d 49 64 3a 20 65 42 |.X-Amz-C f-Id: eB
                                              6e 67 34 71 2d 73 4e 48  31 63 69 5a 52 77 6c 67 |ng4q-sNH 1ciZRwlg
                                              74 48 57 38 2d 61 79 47  61 42 45 51 2d 66 64 65 |tHW8-ayG aBEQ-fde
                                              4b 58 44 46 43 31 66 39  45 47 76 76 76 36 52 4a |KXDFC1f9 EGvvv6RJ
                                              63 43 59 41 3d 3d 0d 0a  0d 0a                   |cCYA==.. ..
    [00:00:15.863,494] <err> download_client: Server did not honor partial content request
    CONFIG_DFU_TARGET=y
    Range: bytes=0-2047
    Waiting for network.. [00:00:00.209,045] <inf> lte_lc: Using legacy LTE PCO mode...
    OK
    [00:00:07.034,637] <dbg> download_client.client_connect: Port not specified, using default: 80
    [00:00:07.034,637] <dbg> download_client.client_connect: family: 1, type: 1, proto: 6
    [00:00:07.035,064] <inf> download_client: Configuring socket timeout (30 s)
    [00:00:07.035,064] <inf> download_client: Connecting to http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
    [00:00:07.035,064] <dbg> download_client.client_connect: fd 1, addrlen 8, fam IPv4, port 80
    [00:00:09.483,673] <dbg> download_client: HTTP request
                                              3a 20 62 79 74 65 73 3d  30 2d 32 30 34 37 0d 0a |: bytes= 0-2047..
                                              43 6f 6e 6e 65 63 74 69  6f 6e 3a 20 6b 65 65 70 |Connecti on: keep
                                              2d 61 6c 69 76 65 0d 0a  0d 0a                   |-alive.. ..
    [00:00:09.483,947] <inf> download_client: Downloading: http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100 [0]
    Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device[00:00:17.579,040] <dbg> download_client.download_thread: Read 708 bytes from socket
    [00:00:17.579,132] <dbg> download_client.http_header_parse: GET header size: 426
    [00:00:17.579,162] <dbg> download_client: HTTP response
                                              3a 32 36 3a 34 36 20 47  4d 54 0d 0a 45 54 61 67 |:26:46 G MT..ETag
                                              0d 0a 56 69 61 3a 20 31  2e 31 20 38 34 31 30 34 |..Via: 1 .1 84104
                                              65 31 33 30 65 30 37 63  64 39 38 32 65 34 35 38 |e130e07c d982e458
                                              36 35 63 36 34 37 31 66  38 64 62 2e 63 6c 6f 75 |65c6471f 8db.clou
                                              0a 58 2d 41 6d 7a 2d 43  66 2d 49 64 3a 20 34 69 |.X-Amz-C f-Id: 4i
                                              39 71 62 61 51 6c 4e 39  51 52 37 5f 44 37 6f 4d |9qbaQlN9 QR7_D7oM
                                              4f 59 45 31 44 4c 4e 57  57 6e 49 73 59 52 42 52 |OYE1DLNW WnIsYRBR
                                              58 44 42 30 69 32 53 46  69 71 56 77 46 54 6f 35 |XDB0i2SF iqVwFTo5
                                              66 59 69 77 3d 3d 0d 0a  0d 0a                   |fYiw==.. ..
    [00:00:17.579,315] <err> download_client: Server did not honor partial content request
    CONFIG_DFU_TARGET=n
    Range: bytes=0-
    OK
    [00:00:04.935,455] <dbg> download_client.client_connect: Port not specified, using default: 80
    [00:00:04.935,485] <dbg> download_client.client_connect: family: 1, type: 1, proto: 6
    [00:00:04.935,882] <inf> download_client: Configuring socket timeout (30 s)
    [00:00:04.935,882] <inf> download_client: Connecting to http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
    [00:00:04.935,913] <dbg> download_client.client_connect: fd 1, addrlen 8, fam IPv4, port 80
    [00:00:07.464,355] <dbg> download_client: HTTP request
    [00:00:07.464,660] <inf> download_client: Downloading: http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100 [0]
    Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device[00:00:07.464,874] <dbg> download_client.download_thread: Receiving up to 2048 bytes at 0x200146fc...
    [00:00:15.472,839] <dbg> download_client.download_thread: Read 708 bytes from socket
    [00:00:15.472,930] <dbg> download_client.http_header_parse: GET header size: 426
    [00:00:15.472,961] <dbg> download_client: HTTP response
                                              3a 32 32 3a 31 32 20 47  4d 54 0d 0a 45 54 61 67 |:22:12 G MT..ETag
                                              0d 0a 56 69 61 3a 20 31  2e 31 20 64 33 63 34 35 |..Via: 1 .1 d3c45
                                              31 34 61 34 39 34 31 37  37 38 32 63 35 61 65 34 |14a49417 782c5ae4
                                              35 33 38 63 66 30 65 33  65 61 64 2e 63 6c 6f 75 |538cf0e3 ead.clou
                                              0a 58 2d 41 6d 7a 2d 43  66 2d 49 64 3a 20 65 56 |.X-Amz-C f-Id: eV
                                              31 39 58 50 44 47 5a 5f  73 66 6b 4c 55 70 54 74 |19XPDGZ_ sfkLUpTt
                                              75 66 50 68 6e 57 37 4c  4d 55 38 6f 74 65 6f 65 |ufPhnW7L MU8oteoe
                                              54 70 6b 53 4f 4c 75 42  33 31 6b 76 6a 74 45 4e |TpkSOLuB 31kvjtEN
                                              4d 47 7a 51 3d 3d 0d 0a  0d 0a                   |MGzQ==.. ..
    [00:00:15.473,144] <dbg> download_client.http_header_parse: File size = 2304
    [00:00:15.473,236] <dbg> download_client.http_parse: Copying 282 payload bytes
    [00:00:15.473,266] <dbg> download_client.download_thread: Receiving up to 1766 bytes at 0x20014816...
    =--- 88 messages dropped ---
    =======================| (2304/2304 bytes)[00:00:18.709,716] <inf> download_client: Download complete
    Download completed in 11261 ms @ 204 bytes per sec, total 2304 bytes
    Bye
    CONFIG_DFU_TARGET=n
    Range: bytes=0-2047
    OK
    [00:00:07.387,786] <dbg> download_client.client_connect: Port not specified, using default: 80
    [00:00:07.387,817] <dbg> download_client.client_connect: family: 1, type: 1, proto: 6
    [00:00:07.388,214] <inf> download_client: Configuring socket timeout (30 s)
    [00:00:07.388,244] <inf> download_client: Connecting to http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100
    [00:00:07.388,244] <dbg> download_client.client_connect: fd 1, addrlen 8, fam IPv4, port 80
    [00:00:09.920,104] <dbg> download_client: HTTP request
    [00:00:09.920,379] <inf> download_client: Downloading: http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device_id=100 [0]
    Downloading http://wpepodownload.mediatek.com/QGPS_1.DAT?vendor=GOTOP&project=KuiiklNAqorm8SRdaWPQiGbZ6lkElM6-KzNRIau_tjE&device[00:00:17.934,204] <dbg> download_client.download_thread: Read 708 bytes from socket
    [00:00:17.934,295] <dbg> download_client.http_header_parse: GET header size: 426
    [00:00:17.934,356] <dbg> download_client: HTTP response
                                              3a 31 37 3a 34 36 20 47  4d 54 0d 0a 45 54 61 67 |:17:46 G MT..ETag
                                              0d 0a 56 69 61 3a 20 31  2e 31 20 61 33 36 34 30 |..Via: 1 .1 a3640
                                              31 61 65 36 35 65 30 37  66 34 30 37 61 63 32 35 |1ae65e07 f407ac25
                                              35 62 61 32 35 38 66 63  64 31 35 2e 63 6c 6f 75 |5ba258fc d15.clou
                                              0a 58 2d 41 6d 7a 2d 43  66 2d 49 64 3a 20 4e 39 |.X-Amz-C f-Id: N9
                                              77 66 38 34 42 65 65 67  58 50 56 4c 61 4f 49 6b |wf84Beeg XPVLaOIk
                                              55 30 43 68 65 4d 30 33  37 6a 57 6a 52 4e 4a 63 |U0CheM03 7jWjRNJc
                                              2d 67 54 35 5f 4c 51 6b  73 64 45 38 57 6e 7a 58 |-gT5_LQk sdE8WnzX
                                              32 71 72 67 3d 3d 0d 0a  0d 0a                   |2qrg==.. ..
    [00:00:17.934,509] <dbg> download_client.http_header_parse: File size = 2304
    [00:00:17.934,600] <dbg> download_client.http_parse: Copying 282 payload bytes
    [00:00:17.934,631] <dbg> download_client.download_thread: Receiving up to 1766 bytes at 0x20014816...
    =======================| (2304/2304 bytes)[00:00:21.162,078] <inf> download_client: Download complete
    Download completed in 11259 ms @ 204 bytes per sec, total 2304 bytes
    Bye
  • The download_client still checks for the content-range header, regardless of if you send it or not.
    The reason for the check is that CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS is set. The reason it is set is because CONFIG_DFU_TARGET_MODEM_DELTA (which is enabled by default) is implying CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS. So if you set either of those options to 'n', it should work with CONFIG_DFU_TARGET enabled.
  • Yes, you are right! When I set CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=n, it works normally.
    Thank you!
