Wierd hardfault
I have a bit of an odd one, and would appreciate any input.  We have a fairly complex project, which does various things, but some of the time, I get a hardfault.  The issue appears to be a instruction access violation (MMFSR->IACCVIOL = 1).  Working backwards, the code that caused this seems to be the nrfx_coredep_delay_us function (in nrfx_coredep.h).
We're using the 17.0.2 SDK, and the code in question is this, and the PC points to delay_machine_code:
   __ALIGN(16)
    static const uint16_t delay_machine_code[] = {
        0x3800 + NRFX_COREDEP_DELAY_US_LOOP_CYCLES, // SUBS r0, #loop_cycles
        0xd8fd, // BHI .-2
        0x4770  // BX LR
    typedef void (* delay_func_t)(uint32_t);
    const delay_func_t delay_cycles =
        // Set LSB to 1 to execute the code in the Thumb mode.
        (delay_func_t)((((uint32_t)delay_machine_code) | 1));
    uint32_t cycles = time_us * NRFX_DELAY_CPU_FREQ_MHZ;
    delay_cycles(cycles);
I wasn't entirely sure about the way the code is hand-loaded in, so I tried switching to using the DWT instead (since the 53833 supports that).  This produced the same hardfault behaviour, only now it's on
while ((DWT->CYCCNT - cyccnt_initial) < time_cycles)
I suspect there's something else going on here.  Our code does use nrf_delay_ms for certain things that need busy waits, which calls through to the above code, but it only hardfaults some of the time.  As above, we're using SDK 17.0.2, nrf52833 on a custom board.
I'm at a bit of a loss on this one, suggestions welcome?
  • Hi Vidar,
    I've pulled in the Nordic hardfault library, which doesn't seem to point to a stack overrun directly - if I understand correctly, the call to HardFault_process() should pass NULL if it's a stack overrun, and that doesn't seem to be happening.  I get a valud pointer to a debug stack.
    Some quick calculations: this project has a stack size of 8192 bytes (8k), which given RAM starts at 0x20000000, should give a stack placement of 0x2001E000 to 0x20020000 (128kB RAM).  At the point of the hardfault, according to Ozone, the SP (R13) is pointing to 0x2001FF28, which should still be a legal bit of stack.  It's getting close to the edge, mind, which is concerning, but not actually over.
    The pointer the Nordic hardfault library gives me is 0x2001FF80, so a little higher than where Ozone says the SP is, which seems reasonable - I guess it's pointing a little higher up the call chain.
    Unfortunately, we're really tight for RAM in this project, hence the 8kB stack.  This means I can't easily bump up the stack to see if the problem goes away.  Does this look like stack overrun issues, based on the above, or should we hunt elsewhere?
    Your understanding is correct, the pointer will be set to NULL if there is a stack overflow, but only if there is a stack overflow while the hardfault exception is raised. And a stack overrun doesn't necessarily trigger a fault immediately (if at all). To catch a stack overflow early you can use the Stack guard library or try to set a data breakpoint at the bottom of the stack.
    Setting data breakpoint in Ozone
    Did the hardfault handler print the debug messages? It would be interesting to see the CPU register values that were pushed on stack before the hardfault exception.
  • Hi Vidar,
    Unfortunately, having any sort of debugger attached while running prevents the hardfault showing up at all, which would tend to suggest some sort of timing issue.  Using a UART has the same effect.  I can attach to the running chip after the hardfault has happened, to see the state of things, but I can't watch the fault happen (which also means not getting the debug output).
    The stack frame passed to my HardFault_process function looks like this:
    And the CPU registers (according to Ozone) are:
    As the stack guard library uses the MPU, wouldn't it basically show the same symptom, i.e. an instruction access violation, if the stack was triggered?
    I've had a go at the old-fashioned "write DEADBEEF to the stack at start-up" method, and that suggests that this code isn't actually over-running the stack.  At the point a hardfault has ocurred, connecting after the fact via Ozone shows that 0x2001E000 is all DEADBEEF still.  I've also confirmed again via MPU_CTRL that the MPU definitely doesn't think it's enabled.
    So, all in all, it doesn't look like stack overflow is the issue here.  Which brings us back to a wierd hardfault that doesn't seem to have any obvious cause, but occurs repeatably.
    I agree, it doesn't sound like you have had stack overflow, but the PC value (0xFB04F85C) on stack is clearly invalid, so that must be the reason for the hardfault.
    It's intereseting that you're not able to replicate this in debug mode. Have you tried to comment the sleep/idle function in your application to see if that may have the same effect as being in debug mode?
  • Ok, the delay_ms call was a red herring, and obvious in retrospect - that's being called from the hardfault handler (to flash an LED), so it's not where the problem is ocurring.  Doh.
    Commenting it out made it obvious, as then the PC ends up pointing to the nrf_gpio_pin_* functions, which are setting the LEDs.  This also caused the resultant hardfault to change to an IBUSERR instead - the call stack included a call to __WFI(), which is slightly different.
    We do use __WFI() a fair bit to cause the CPU to sleep (and consume less power) when waiting for things to happen.  Most timing is provided via an RTC, plus a few external interrupts.  As above, we don't use a softdevice, so it shouldn't be a problem to call __WFI() directly, but a bit of digging around suggested that the following is better (we do use the FPU):
    static inline void sys_sleep (void)
    #if (__FPU_USED == 1)
      __set_FPSCR(__get_FPSCR() & ~(0x0000009F));
      (void) __get_FPSCR();
      NVIC_ClearPendingIRQ(FPU_IRQn);
      __WFI();
    Replacing the WFI calls with that changed the hardfault to an UNDEFINSTR error instead.  Looking at the top of the call stack, I now seem to be somewhere in the heap, I think?
    So yes, that's probably not a valid instruction.  But how did we end up there in the first place?  That particular address happens to be the m_mem_pool long, from the Nordic mem_manager library (which we use to provide pseudo-dynamic memory allocation).  Looking through mem_manager.c, I don't see anything obvious that could turn into a "JMP &m_mem_pool" or similar - it's a status flags bitmap, so the usage is all setting and checking bits.
    The Hardfault library stack frame snapshot now looks like this:
    with the LR pointing to the WFI instruction in the above sys_sleep code.  So it seems to be something to do with the WFI call.
    Does anything in the above jump out at you as obviously suspicious or worth pulling at some more?
