Mesh LE Coded
Hello everybody
I have some nrf52840-DKs and other boards with the same module and I want to create a LE Coded mesh with these boards, I am aware that the BLE Mesh standard is for BLE Legacy it's just a proof of concept as LE Coded has given us good results in the same environment. I have seen that this is something that has been commented on several times in this forum. I have tried to use the patch that is commented in this old thread but it does not seem to work for me, apart from the modifications discussed there I also changed the power, this seems to work because I see a notable difference between using RADIO_POWER_NRF_0DBM and RADIO_POWER_NRF_POS8DBM which tells me that it is changing the power even though with the regular SDK I use softdevice to change these parameters instead of modify these registers.
However with the rest of the changes it is only works without the last change but seems to be the same as I test with 2 DKs at same position and orientations and results are almost the same Coded or Legacy. If I set the last change (5th element in radio_mode_to_us_per_byte[] from 128 to 64.) gives me an error.
app_error_weak.c,  105, Mesh assert at 0x0003BB20 (:0)
This belong to the following line
nordic_sdk/sdk_mesh/mesh/bearer/src/bearer_handler.c:162 (discriminator 1)
Which is also commented here
I don't know what the problem could be, I believe I have set all correctly, maybe in newer versions of the Mesh SDK something has been changed and this patch doesn't work.
I'm testing with the mesh sensor example, the SDK version is 17.0.2 and the SDK for Mesh is 5. The code of the project is attached as well
Another doubt I have is if I understood the mesh architecture correctly, there is on one hand the communication between the different nodes of the mesh (which I try to change to Coded) and on the other hand an advertisement that through the nodes that works as a proxy it serves as an entry point to the mesh for e.g. a mobile device.
I have a One Plus 8T with which I tested long range beacon and ble uart coded and it works flawlessly. My idea was that the advertisement of the mesh should also be Le Coded to take advantage of the support of the smartphone. I didn't test it too much I tried to change in mesh_adv.c the primary and secondary PHY for Coded along with some change of buffers sizes and intervals but it didn't work, I understand that the main problem to deal with Coded is the bigger preamble and time on air of the frames. In any case this last one is secondary if it is possible to do it perfect if not I simply connect by serial another board that forward the information in beacon long range or something Le Coded that the mobile can read perfectly.
Thanks in advance
Best regards
  • OK, I think I should approach the experiments in a different way. As I understand it, the advantage of coded is that it puts more data in the header which allows you to decode the signal over a longer distance using the same power.  In other words, for example, if in legacy you receive a packet with -98 dbm at one point and move a bit further away and don't receive anything, with coded it is possible to receive it with -105 dbm (it will depend on the sensitivity of the board). My idea is to test in places that are a bit at the limit with legacy to see if it is better received with coded but it is probably better to focus on packet reception than on rssi as it is done here.
    I don't know very well why last week I received that difference in values, it's true that humidity and those things affect the propagation, especially for centrimetric waves, but now I'm receiving those values and they are very good so it doesn't seem to be in a critical area of reception and in that case I shouldn't see any difference between coded and legacy, it may even be worse in coded, I checked this with the smartphone with examples of advertising, I guess it may be because with coded it has 8x more time on air.
    So what I would do is to reduce the power and find places where it is more at the limit and maybe measure the packets received with one or the other.  The problem is that when I test examples of the normal SDK I can see on the mobile what kind of advertising it is. For mesh I'm a bit more blind, the only thing I can do to make sure I'm using coded is to move at least one node around and see that the reception distance is greater, because the RSSI is not a reliable parameter for this case either.
    Yes, I guess it is probably better to focus on packet reception rather than relying on RSSI. Like you said is not really a reliable parameter as it depends of a lot of factors in your environment(like radio interference, signal/multi-path reflections, and loss in the antenna layouts).
    On another note, like you mentioned above long range/Coded PHY is not supported in the mesh specification. The idea with a mesh network is that you should be able to cover more ground by adding more nodes to the network. By using the relay feature you can get a longer range.
  • Well these results are more convincing.
    I think this is a clear confirmation that I am using coded which I think is not related to the way I provisioned them, probably due to a different particular error.
    ble_P2-na.pdfble_P1-na.pdf
    It shows how at -15 and -12 dBm with coded it receives many more packets (at -12 it doesn't lose any) while with legacy it only received 1 at -15 and lost 57% at -12. This is also interesting for some energy harvesting projects where we have modules running at -40 dbm.
    The point is that I was quite confused by the RSSI of the DK, I'm not a telecom expert but bluetooth has an operating range where you move away a bit and it drops considerably but then stays there as you move away (arround -80,-90 dBm) and this is something I've seen on nRF5x based boards as well as other bluetooth modules, but with the DK the RSSI seems more linear, maybe it's calculated differently? I know that the main difference in the range is due the PA/LNA module of the DK because the pcb antenna is not a big deal either. It is curious that the sensitivity for 1M is only -95 dBm according to datasheet.
    In any case this part was the urgent one. I'm going to mark it as solved and I'll continue with the second part, depending on the progress I get I can comment it here.
