Unknown function at <address> starts executing during the ISR's execution</address>
So...I have an idle task running then a UART interrupt fires upon a character being sent over the serial, and somewhere during the execution of the ISR, it attempts to execute an "unknown" function as shown in the call stack here
And here's the corresponding ASM code which I have no idea about cause I can't trace it.
Pressing the execute debugger button still executes the same function 0x774. Is it in sleep mode?
  • morpho said:
    Do you know how to verify the resetting of MSP? Initially when I run the program, it's set to `0x20040000` and when the IRQ is fired, it doesn't reset back to the same address
    It is only "reset" when the first task starts. After that, it behaves just as normal stack. I am not sure what you want to verify, but you can check the stack pointer from the debugger.
    morpho said:
    Is this is the .hex file located under components\softdevice\SoftDevice\hex?
    Yes (though the path is a bit different with different variants). All BLE projects use the SoftDevice.
    morpho said:
    I'm using Segger IDE and this link only has info on other IDEs.
    This is independent of which IDE / toolchain you use.
    morpho said:
    But all i'm doing is using one of the freertos apps and making changes on top of it, and running/debugging it
    There are several example apps in the SDK, both using a SoftDevice and not using it. Please check if you are using a SoftDevice (and thus MBR) or not, as that is key to know if 0x744 is within something we provide (the MBR) or the app you built yourself. If it is in the MBR as I assumed, it is in the interrupt vector table, so related to interrupt forwarding. See Exception model in the SoftDevice specification.
  • It is only "reset" when the first task starts. After that, it behaves just as normal stack. I am not sure what you want to verify, but you can check the stack pointer from the debugger.
    Yeah but that's what I'm trying to do: to figure out how to actually see this behavior by navigating MSP. As described, the initial value is `0x20040000` at the start of main. Is it supposed to reset back to `0x20040000` once the task starts?
    Sorry, you didn't seem to answer my dumb question: how do you verify if the softdevice is being used on my device?
    What is the start address of your application? If it is at 0x0, then you are not using MBR or SoftDevice. If it is higher than that, you are typically using the SoftDevice (even if it is not enabled, it will forward interrupts to your application). If you let me know which example project you have based your app on I can check for you. To be frank I think you need to read up a bit on the overall architecture before digging into such details as it seems to me you may be missing the over all understanding that should be in place first.
    Update: I see i referred to 0x744 instead of 0x774 and that typo stuck in this thread. However, both are within the interrupt forwarding code of the MBR, so that is certainly what is going on.
  • MSP, as mentioned earlier, at the start of the application is 0x20040000, which according to your description, means I'm using a SoftDevice?
    I'm building stuff on top of ble_app_hrs_freertos project. And I agree with you on learning about the softdevice architecture itself.
    No.
    That project uses the SoftDevice, and thus MBR. Then we can conclude that 0x774 is from the interrupt forwarding code in the MBR, so all seems good.
