Is there a way to control the unprovisioned device (a light) with nrf5 sdk for mesh?
Hi support team,
I am a beginner with Nordic nrf5 sdk for mesh.  I begin with the sample light_switch. Currently I want to toggle the status (on/off) of the unprovisioned light by phone APP.
Is there a method to implement it?
I have read the source code and understood the sdk, but not clearly.   I just think that the APP can send the scan request after receiving the advertisement for provisioning service,
and then at light side it will receive the scan request and BLE_GAP_EVT_SCAN_REQ_REPORT event can be handled.   I plan to toggle the status of the unprovisioned light when received
the BLE_GAP_EVT_SCAN_REQ_REPORT  event. Is this method practicable? or Is there another way to implement this functionality?
Any suggestion will be appreciated.
  • Hi Hung,
    Thanks for your answer.
    I understand the way you mentioned.  That is to say that in order to find A4, the phone (nRF Mesh app) needs to connect to every unprovisioned node to identify and try to see if it is the node which I want to provision. If there were many unprovisioned nodes (not just 10), it would not be a good way.
    Is there a way to identify the unprovisioned node without connection?
    I searched and found the similar ticket, How to identify a non provisioned node with the Thingy mesh demo - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com), but didn't find the Link Establishment Request and cannot open the link page "latest mesh sdk" (maybe it's too old). I am using nRF5 sdk for mesh v5.0.0.
    Any suggestion would be very appreciated.
    Thank you.
  • Please correct me if I'm wrong. So the problem here is that all of the nodes look identical from the outside, there is no serial number or anything. And you want to provision a particular node and you don't know the MAC address or the serial number of the node , correct  ?
    If it's the case you can use RSSI (Received Signal Strength Indicator) . So if you want to provision a device, you can just pick it up , and bring it close to the phone. On the phone you only show the device with the RSSI higher than a certain level (very close to the phone). This way you can provision the device without the need to connect to every single one.
  • Hi Hung,
    Thanks so much for your patience for my question. Yes, you're right.
    We're trying to figure out a solution for the situation like this:
    In the manufactory, there are 100 same lights. We plan to create 5 mesh networks and each mesh network will include 20 lights. After these lights are powered up, we will use smartphone (nRF5 mesh app) to provision for every light and make each light into the corresponding network. If connect to every light to identify, maybe it would take too much time, so we meet the original question.
    If there isn't another way, the sample way (connect and identify) we have to use.
  • Have you considered the RSSI solution I mentioned about ? If you want to set 20 pcs the light to one network, you just bring them closer to the phone, then you should be able to select only them.
  • Hi Hung,
    Thanks for your suggestion.
    I noticed that the way (blink) to identify the unprovisioned device is implemented in light_switch example, but not implemented in light_lightness, light_ctl examples. so how to identify the unprovisioned device with these examples? Maybe I missed much about the sdk, but could you pls  give any suggestion? Thank you in advance!
